STAAD PRO WARNING ISSUE DUE TI INACTIVE MEMBER
Dear Team,
I have an issue to solve my STAAD Pro analysis , I believe my Support Reactions Results are ok  but still continually getting Warning sign when I assign the inactive Member as follows .
 WARNING : THE LOAD ON INACTIVE MEMBER #   1448   WILL NOT BE
             CONSIDERED FOR END FORCE CALCULATIONS (LOAD #     1)
Plz help me to solve the issue , I hope this is because of some Syntax issues ,
I am attaching the model for your reference.
https://communities.bentley.com/p/secure_file_upload
Thank you in advance.
Anas
  • You have assigned and INACTIVE member specification to some of the members and this command makes those members to be excluded from the calculations during analysis. At the same time, you are assigning some loading in LC1 and LC2 for these members which were inactivated. So this warning message says, that the load which was assigned to those inactivated members will not be considered during the analysis.
    I think you can ignore these warnings as long as you understand that loading on inactivate members are not considered during the analysis for LC1 and LC2.
