Is it ok if I used the section wizard to draw a cold formed section (Channel section with lips ) and then calculate the section properties using the Section wizard, and after that I copied those properties and paste them into the section database table of Channel with lips table ?? Or IF I calculate the section properties using the section wizard this means that those properties will be based on an equivalent Hot Rolleed I Section and are not adequate to be used Channel with lips cold form section design ??Would appreciate if someone can quide me on that
Yes you can calculate properties of coldformed sections using Freesketch.
