Lateral displacemente of semirigid diaphragm
I'm trying to verify the drift of a one-story ware house with tilt-up concrete panels and steel deck roof.
I followed all the information that I found on the forum, but I still have a few questions:
First I calculated the properties and displacement  as referenced here: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/18657/example-calculating-semirigid-diaphragm-e .
I used E' and the deck thickness on the properties, as can be seen here:
I'm using the same load from RAM on my hand calculation, and the same properties, so the results should at least be close. But unfortunately thats not the case.
From the hand calculation, I found a 1.3in displacement, while in RAM I found 0.55in.
I don't understand what I'm missing. Even though the results may be different, they are supposed to be similar, correct?
Appreciate any help!
Murilo Santos
