India Section S type ISMB's are Not selectable from Section Database in StaadPro Connect 22.05.00.131
While using StaadPro Connect edition 22.05.00.131 latest update, under Analytical Modeling workflow, I am unable to select member properties from section database - type Indian Section S-type.
All records except one ISMB100, are greyed out. Snapshot attached.
It is noteworthy while using Physical modelling workflow, Section from India S-type can be assigned but after merging /creating Analytical model, an error pops up for "Steel table property is not found in table check syntax". Other section from Indian are selectable. Video attached.
I can even see all these S type S sections from section database (India- Rolled- steel-Indian Profile- S Shape). I tried by opening same S-Section sections using "Bentley.Structural.PropertyCatalog.ManagementStudio.exe", every thing is visible.
Since these S type are moslty used, working is hindered.
PLEASE CHECK and inform whether I revert to older update ? Or Shall I try anything else?
StaadPro Sections are Greyed out, not selectable except one
Parents Reply Children
