Hi, I'm trying using excel vba to model but am having some problems. My staad pro ce is Version 22.01.00.38. Here are some tests which I followed from openSTAAD help.
TEST 1
Sub Test01()
Dim objOpenSTAAD As Object Dim fCoordX As Double Dim fCoordY As Double Dim fCoordZ As Double Dim nNodeNo As Variant
Set objOpenSTAAD = GetObject(, "StaadPro.OpenSTAAD")
fCoordX = 3 fCoordY = 2 fCoordZ = 3 nNodeNo = OSGeometryUI.AddNode(fCoordX, fCoordY, fCoordZ) -------> ERROR Set objOpenSTAAD = Nothing
End Sub
ERROR: Run-time error '424': Object required
TEST 2
Sub Test02()
fCoordX = 3 fCoordY = 2 fCoordZ = 3 OSGeometryUI.CreateNode(10, fCoordX, fCoordY, fCoordZ) Set objOpenSTAAD = Nothing
ERROR: Expected: =
TEST 3
Sub Test03() Dim lNodeCount As Variant lNodeCount = OSGeometryUI.GetNodeCount()End Sub
I noted there is a "void" in the front of the function title in openSTAAD help, what does this mean? Does it mean the function can't use anymore?
Test 1: Modified Code
Dim objOpenSTAAD As Object Dim fCoordX As Double Dim fCoordY As Double Dim fCoordZ As Double Dim nNodeNo As Long
nNodeNo = objOpenSTAAD.Geometry.AddNode(fCoordX, fCoordY, fCoordZ)
Set objOpenSTAAD = NothingEnd Sub
Test 2 Modified Code:
objOpenSTAAD.Geometry.CreateNode 10, fCoordX, fCoordY, fCoordZ
Test 3 Modified Code:
Sub Test03()Set objOpenSTAAD = GetObject(, "StaadPro.OpenSTAAD")
Dim lNodeCount As Long
lNodeCount = objOpenSTAAD.Geometry.GetNodeCountEnd Sub
