I am installed Staad Pro V.8 in a new Pc but I can not activate (Active 0 Staad Pro)
How can I fix this problem. I have Site Activation Key from 14 Oct. 2011.
Please If one could help me, because I have a project to finish.
It may be that the license is used by some other machine. You can check this information in the SELECTserver administration site and check in the license back to the server by following these instructions: https://communities.bentley.com/products/licensing/w/licensing__wiki/2781/viewing-and-checking-in-licenses-using-the-site-administration-page-tnPlease note that STAAD.Pro V8i is not supported anymore and it is recommended to upgrade to STAAD.Pro CONNECT Edition as soon as possible.
If you do not have administrative access in the selectserver site; please find the steps to check-in & checking out licenses from the user's machine.
https://communities.bentley.com/products/licensing/w/licensing__wiki/6013/client-check-in-and-out-instructions-for-xm-and-higher-tn
