CB column base plate RAM connection
Hi
below two queries need to be resolved please.
1) I am trying to assign the area of anchored washer plate which is used to calculate the Abrg. (as highlighted below), the anchored washer plate is function of "k" either circular or square. Is there any way to provide input to RAM.
2) stiffener to optimize the base plate thickness cannot be customized, is there any way to reduce or increase the thickness of baseplate stiffeners. And any possibility of changing the arrangement other than the options provided in the drop down menu.
Thanks in advance.
regards
