it is takeing very long time for transfer of file from staad pro to structural synchroniserr to create rpository???
thanks it helped . But when the file is exported from ISM to RAMSS the system opens in feet system although I have selected SI system. What will be the reason ?
When you use the ISM - New from Repository command there is a point at which you name the new .rss file. In that New file dialog are the units.
You can always change the units in Ram Manager later, with Criteria - Units (in fact you might have to reset this for all new files after import)
Answer Verified By: Nand Kumar
