Can anybody help me?
When I check reaction on my MSTower file, the asterisk symbols (*) just appear in the results. What should I do to make the result appear?
Thanks in advance.
zip.rar
This looks like an issue fitting the numbers into the space available. I can look at this if you zip your MStower files and attach them to this query?
Hi, I have attached the files to this query.That would be great if you can take a look at it.
t looks like the maximum number of digits reported is 10, including the decimal point and these values have more than 10, for example for 400, MX is 2030963.671. I will look to see if anything can be done to change this and get back to you.
Answer Verified By: Andi Bumantara
Unfortunately this can't be changed. Please note that the values you are obtaining for these loads are very high and should be reviewed.
Ahh, okay.. Thankyou for your help
