Illegal framing configuration detected on beam -1
Hi, I get the following error when running analysis in Steel Beam module:
"Illegal framing configuration detected on beam -1". The error is caused at the wall.
Several things are happening in the area in question. It is inside corner of the building where the basement wall turns the corner. Also, there is an expansion joint at each end of the wall. See screenshot below.
Any help would be appreciated.
  • Hi, I'm having the same error when creating the framing tables in RAM Frame. The error has appeared after adding walls down to a lift pit. Reading this post, I've now split the slab edge so that I can offset the slab edge from the wall ends - however this hasn't resolved the error. I wondered if someone might take a look in case there's something else I've missed (I'll upload a file to the Secure Fil Upload). Thanks in advance.
