I am trying to analyse a structure and I am getting the Intel (r) Visual Fortran Runtime error. The file that I am working on is in my local drive and not in any network drive. Also, I have tried copying and pasting the .std file in another location (C Drive). But there is no help. I am uploading the staad file in the secure server.
This issue seems to be related to the SELECT command used in your model. If you comment this commend out, the model runs fine. I will report this defect to the development team in order to address this issue in the upcoming STAAD.Pro version.
Okay. So this means that the SELECT OPTIMIZED command cannot be used as of now in my model. Thanks for the help.
Check the remained disk volume, if lack or not.
We have exactly the same error - please let me know when you get a resolution
We are using V22.08
