Hi
I am a new user after Limcon has finally shut down.
I have watched training videos but they are all using American codes.
I had a lot of trouble assigning a connection to a HBBB joint only to find that this isn't supported for Australia yet. I an now having similar problems with a CVR joint. Is it another case of nothing available yet?
If so is there a list/matrix available that shows which templates (connections?) will work with which joint when designing to AS4100?
Apologies if terms are incorrect but as I say I am new.
CVR joint is also not available in AS410 code. Yes, you can get a list of that. Once you open the RAM Connection STandalone application, click on "FILE" located in the left hand corner. Now click on HELP and it will show you RAM Connection Manual. Download the PDF version and in the CHAPTER 2 of that document, you will see full list for all the codes.
Hope this helps.
