STAAD.Pro Advanced CONNECT Edition - Version 22.05.00.131
RCDC CONNECT Edition Version 09.04.00.128
When I use the RCDC module within STAAD it imports the members sizes accurately but it does not bring in all of the active load case values for beams and columns, only a small portion of them.
FLAKER_REV6.STD
It appears the cases that are not importing into RCDC are those that include "Repeat Loads"
Repeat loads now can be read by RCDC easily. You need to first assign load types to all the primary load cases and then add them. Then go to load combination page and click on add from analysis and all load combinations from repeat load will be shown there.
Hope this helps.
Hello !
Even after assigning the load types to primary load cases , the ÄDD FROM ANALYSIS" option is not responding. Please help
Can you please upload the .std file here?
Okay. In the interim, can you please let us know whether is there any design command in RCDC to obtain the bending moment values of beam from face of columns?
Also, "Update analysis" command in file menu is not functioning only for column design , whereas its not functioning for Beam design, hence the modified parameters need to be given from the scratch. Please help on this isuue as well. Thank you
