Is it possible to send an analyzed STAAD model to a colleague, ? So that when he opens the STAAD model he could navigate immediately to the post-processor without the need to run the analysis each time he opens the file ?
Yes.. You need to send the full zipped file to that colleague.
For example, create a new folder. put the .std fille there. Run the file in your system. Now close STAAD. Zip the full folder and share with your colleague. He need to unzip it and use it.
Answer Verified By: Saed Al-Halteh
In addition to what Abhisek mentioned, you can also create an Archive of the model which will contain all required data. The process is explained in STAAD.Pro Help section Data Files and Interoperability > I. Archives.
Dear Abhisek,Dear Modestas, Thanks alot for your continuous support. Much appreciated.
