RAM - Openings in Concrete Walls
I am adding openings in a lateral concrete shear wall at the ground level and the foundation is lowered by 1.2m below the ground level.  When I add the openings in the elevation mode and place the doors with a Y elevation of 1.2m the doors show up at the ground floor level.  However when I go into a 3D view the doors are shown above the ground level and are penetrating the first floor level.  When running the wall design in the concrete module the opening are shown at the same location as the 3d view in modeler.  At the ground floor should the Y elevation be based off of the top of footing elevation or the ground floor elevation?
