I am exporting mdb file from etab . But it got too much smaller size than usual. And I got results from rcdc depending upon that file . But results are not proper for column. So kindly suggest solution on that.
Hiplease make sure that all the design settings like concrete grade and sizes of members are same for comparison.also make sure that the effective length factor calculation in E-tabs and RCDC should be same to compare results.i would request you to check all above parameters before comparing results from E-tabs and RCDC. if all parameters are same, generally results are matching. still , if you have aby issues, please share result outputs of E-tabs and RCDC for comparison and mark your comments to understand your query better.
