Hi Good day!
I am having a problem with the printing of my Design Calculation Report,
when it is already generating the design calculation report an error message pops out. See attached.
Error Translation:
Microsoft.NET Framework
An unhandled exception has occurred in a component of your application. If you click Continue, the application ignores this error and tries to continue. Click Exit 1 to exit the application immediately. The item has already been added. Dictionary key 2985 Added key 2985.
When "continue" is selected it just generates the report forever.
What should be done? Thank you for your help
Hiplease share RCDC file to check issue.
