RAM Concrete - Moment Calculation
Is the support for the beam assumed to be at the face of the column for beams?
Therefore, for a simply supported beam (pinned - pinned) will the max moment be the same as calculating the moment based on the clear span as opposed to centerline to centerline?
To add to this...
(some of this may be model specific and I can create a ticket if needed)
  1. I have all beams pinned in the major axis. However, I still have moments in the columns. The columns are fixed top and bottom. The deck is a one-way concrete deck. What the moment from?
  2. If I change the top of the columns to pinned, I get excessive deflections (I'm surprised there isn't a stability error thrown). Typically, I would think something is "spinning" but I'm not sure if that is the case. Any ideas here?
