Dear Team,We have observed a discrepancy in RCDC where reinforcement shown in schedule and detail drawing wont match for combined wall. Sharing screen shot of the same for your reference. Kindly let us know which one is correct and why is the difference in two outputs. Thank you.
HiRCDC identifies the combined wall when there are more than one walls are intersecting or overlapping each other. as some part of each wall overlaps each other, the common portion is detailed as explained in help content. /cfs-file/__key/communityserver-discussions-components-files/5932/combined-wall_5F00_help-content.pdfin your case, the column overlaps the wall portion and it is identified as part of combined wall. So the length of wall is adjusted as per common portion.
Answer Verified By: Abhijeet Gundaye
