Hi guys, I have a problem. I am using master/slave command to model expansion joints. I have multiple joints in the structure, however only one is not behaving normaly. Master/slave command is used to restrict movement in FX and FY.
Master slave command working properly:
Master slave not working properly:
Both are coded the same way in STAAD. What is causing the difference? I have over 400 master/slave commands, is that the limitation? Thanks for the help. Below are the full STAAD code and the master slave code only.
full STAAD file.txt
SLAVE FX FY MASTER 4048 JOINT 4116 SLAVE FX FY MASTER 4049 JOINT 4117 SLAVE FX FY MASTER 4050 JOINT 4118 SLAVE FX FY MASTER 4051 JOINT 4119 SLAVE FX FY MASTER 4052 JOINT 4120 SLAVE FX FY MASTER 4053 JOINT 4121 SLAVE FX FY MASTER 4054 JOINT 4122 SLAVE FX FY MASTER 4055 JOINT 4123 SLAVE FX FY MASTER 4056 JOINT 4124 SLAVE FX FY MASTER 4057 JOINT 4125 SLAVE FX FY MASTER 4058 JOINT 4126 SLAVE FX FY MASTER 4059 JOINT 4127 SLAVE FX FY MASTER 4060 JOINT 4128 SLAVE FX FY MASTER 4061 JOINT 4129 SLAVE FX FY MASTER 4062 JOINT 4130 SLAVE FX FY MASTER 4063 JOINT 4131 SLAVE FX FY MASTER 4064 JOINT 4132 SLAVE FX FY MASTER 4065 JOINT 4133 SLAVE FX FY MASTER 4066 JOINT 4134 SLAVE FX FY MASTER 4067 JOINT 4135 SLAVE FX FY MASTER 4068 JOINT 4136 SLAVE FX FY MASTER 4069 JOINT 4137 SLAVE FX FY MASTER 4070 JOINT 4138 SLAVE FX FY MASTER 4071 JOINT 4139 SLAVE FX FY MASTER 4072 JOINT 4140 SLAVE FX FY MASTER 4073 JOINT 4141 SLAVE FX FY MASTER 4074 JOINT 4142 SLAVE FX FY MASTER 4075 JOINT 4143 SLAVE FX FY MASTER 4076 JOINT 4144 SLAVE FX FY MASTER 4077 JOINT 4145 SLAVE FX FY MASTER 4078 JOINT 4146 SLAVE FX FY MASTER 4079 JOINT 4147 SLAVE FX FY MASTER 4080 JOINT 4148 SLAVE FX FY MASTER 4081 JOINT 4149 SLAVE FX FY MASTER 4082 JOINT 4150 SLAVE FX FY MASTER 4083 JOINT 4151 SLAVE FX FY MASTER 4084 JOINT 4152 SLAVE FX FY MASTER 4085 JOINT 4153 SLAVE FX FY MASTER 4086 JOINT 4154 SLAVE FX FY MASTER 4087 JOINT 4155 SLAVE FX FY MASTER 4088 JOINT 4156 SLAVE FX FY MASTER 4089 JOINT 4157 SLAVE FX FY MASTER 4090 JOINT 4158 SLAVE FX FY MASTER 4091 JOINT 4159 SLAVE FX FY MASTER 4092 JOINT 4160 SLAVE FX FY MASTER 4093 JOINT 4161 SLAVE FX FY MASTER 4094 JOINT 4162 SLAVE FX FY MASTER 4095 JOINT 4163 SLAVE FX FY MASTER 4096 JOINT 4164 SLAVE FX FY MASTER 4097 JOINT 4165 SLAVE FX FY MASTER 4098 JOINT 4166 SLAVE FX FY MASTER 4099 JOINT 4167 SLAVE FX FY MASTER 4100 JOINT 4168 SLAVE FX FY MASTER 4101 JOINT 4169 SLAVE FX FY MASTER 4102 JOINT 4170 SLAVE FX FY MASTER 4103 JOINT 4171 SLAVE FX FY MASTER 4104 JOINT 4172 SLAVE FX FY MASTER 4105 JOINT 4173 SLAVE FX FY MASTER 4106 JOINT 4174 SLAVE FX FY MASTER 4107 JOINT 4175 SLAVE FX FY MASTER 4108 JOINT 4176 SLAVE FX FY MASTER 4109 JOINT 4177 SLAVE FX FY MASTER 4110 JOINT 4178 SLAVE FX FY MASTER 4111 JOINT 4179 SLAVE FX FY MASTER 4112 JOINT 4180 SLAVE FX FY MASTER 4113 JOINT 4181 SLAVE FX FY MASTER 4114 JOINT 4182 SLAVE FX FY MASTER 4115 JOINT 4183 *EXPANSION JOINT 2 *FOR EXCEL ONLY FIRST NODE IS LOWER NUMBER IN YELLOW SLAVE FX FY MASTER 8264 JOINT 8332 SLAVE FX FY MASTER 8265 JOINT 8333 SLAVE FX FY MASTER 8266 JOINT 8334 SLAVE FX FY MASTER 8267 JOINT 8335 SLAVE FX FY MASTER 8268 JOINT 8336 SLAVE FX FY MASTER 8269 JOINT 8337 SLAVE FX FY MASTER 8270 JOINT 8338 SLAVE FX FY MASTER 8271 JOINT 8339 SLAVE FX FY MASTER 8272 JOINT 8340 SLAVE FX FY MASTER 8273 JOINT 8341 SLAVE FX FY MASTER 8274 JOINT 8342 SLAVE FX FY MASTER 8275 JOINT 8343 SLAVE FX FY MASTER 8276 JOINT 8344 SLAVE FX FY MASTER 8277 JOINT 8345 SLAVE FX FY MASTER 8278 JOINT 8346 SLAVE FX FY MASTER 8279 JOINT 8347 SLAVE FX FY MASTER 8280 JOINT 8348 SLAVE FX FY MASTER 8281 JOINT 8349 SLAVE FX FY MASTER 8282 JOINT 8350 SLAVE FX FY MASTER 8283 JOINT 8351 SLAVE FX FY MASTER 8284 JOINT 8352 SLAVE FX FY MASTER 8285 JOINT 8353 SLAVE FX FY MASTER 8286 JOINT 8354 SLAVE FX FY MASTER 8287 JOINT 8355 SLAVE FX FY MASTER 8288 JOINT 8356 SLAVE FX FY MASTER 8289 JOINT 8357 SLAVE FX FY MASTER 8290 JOINT 8358 SLAVE FX FY MASTER 8291 JOINT 8359 SLAVE FX FY MASTER 8292 JOINT 8360 SLAVE FX FY MASTER 8293 JOINT 8361 SLAVE FX FY MASTER 8294 JOINT 8362 SLAVE FX FY MASTER 8295 JOINT 8363 SLAVE FX FY MASTER 8296 JOINT 8364 SLAVE FX FY MASTER 8297 JOINT 8365 SLAVE FX FY MASTER 8298 JOINT 8366 SLAVE FX FY MASTER 8299 JOINT 8367 SLAVE FX FY MASTER 8300 JOINT 8368 SLAVE FX FY MASTER 8301 JOINT 8369 SLAVE FX FY MASTER 8302 JOINT 8370 SLAVE FX FY MASTER 8303 JOINT 8371 SLAVE FX FY MASTER 8304 JOINT 8372 SLAVE FX FY MASTER 8305 JOINT 8373 SLAVE FX FY MASTER 8306 JOINT 8374 SLAVE FX FY MASTER 8307 JOINT 8375 SLAVE FX FY MASTER 8308 JOINT 8376 SLAVE FX FY MASTER 8309 JOINT 8377 SLAVE FX FY MASTER 8310 JOINT 8378 SLAVE FX FY MASTER 8311 JOINT 8379 SLAVE FX FY MASTER 8312 JOINT 8380 SLAVE FX FY MASTER 8313 JOINT 8381 SLAVE FX FY MASTER 8314 JOINT 8382 SLAVE FX FY MASTER 8315 JOINT 8383 SLAVE FX FY MASTER 8316 JOINT 8384 SLAVE FX FY MASTER 8317 JOINT 8385 SLAVE FX FY MASTER 8318 JOINT 8386 SLAVE FX FY MASTER 8319 JOINT 8387 SLAVE FX FY MASTER 8320 JOINT 8388 SLAVE FX FY MASTER 8321 JOINT 8389 SLAVE FX FY MASTER 8322 JOINT 8390 SLAVE FX FY MASTER 8323 JOINT 8391 SLAVE FX FY MASTER 8324 JOINT 8392 SLAVE FX FY MASTER 8325 JOINT 8393 SLAVE FX FY MASTER 8326 JOINT 8394 SLAVE FX FY MASTER 8327 JOINT 8395 SLAVE FX FY MASTER 8328 JOINT 8396 SLAVE FX FY MASTER 8329 JOINT 8397 SLAVE FX FY MASTER 8330 JOINT 8398 SLAVE FX FY MASTER 8331 JOINT 8399 *EXPANSION JOINT 3 *FOR EXCEL ONLY FIRST NODE IS LOWER NUMBER IN YELLOW SLAVE FX FY MASTER 13015 JOINT 13094 SLAVE FX FY MASTER 13016 JOINT 13095 SLAVE FX FY MASTER 13017 JOINT 13096 SLAVE FX FY MASTER 13018 JOINT 13097 SLAVE FX FY MASTER 13019 JOINT 13098 SLAVE FX FY MASTER 13020 JOINT 13099 SLAVE FX FY MASTER 13021 JOINT 13100 SLAVE FX FY MASTER 13022 JOINT 13101 SLAVE FX FY MASTER 13023 JOINT 13102 SLAVE FX FY MASTER 13024 JOINT 13103 SLAVE FX FY MASTER 13025 JOINT 13104 SLAVE FX FY MASTER 13026 JOINT 13105 SLAVE FX FY MASTER 13027 JOINT 13106 SLAVE FX FY MASTER 13028 JOINT 13107 SLAVE FX FY MASTER 13029 JOINT 13108 SLAVE FX FY MASTER 13030 JOINT 13109 SLAVE FX FY MASTER 13031 JOINT 13110 SLAVE FX FY MASTER 13032 JOINT 13111 SLAVE FX FY MASTER 13033 JOINT 13112 SLAVE FX FY MASTER 13034 JOINT 13113 SLAVE FX FY MASTER 13035 JOINT 13114 SLAVE FX FY MASTER 13036 JOINT 13115 SLAVE FX FY MASTER 13037 JOINT 13116 SLAVE FX FY MASTER 13038 JOINT 13117 SLAVE FX FY MASTER 13039 JOINT 13118 SLAVE FX FY MASTER 13040 JOINT 13119 SLAVE FX FY MASTER 13041 JOINT 13120 SLAVE FX FY MASTER 13042 JOINT 13121 SLAVE FX FY MASTER 13043 JOINT 13122 SLAVE FX FY MASTER 13044 JOINT 13123 SLAVE FX FY MASTER 13045 JOINT 13124 SLAVE FX FY MASTER 13046 JOINT 13125 SLAVE FX FY MASTER 13047 JOINT 13126 SLAVE FX FY MASTER 13048 JOINT 13127 SLAVE FX FY MASTER 13049 JOINT 13128 SLAVE FX FY MASTER 13050 JOINT 13129 SLAVE FX FY MASTER 13051 JOINT 13130 SLAVE FX FY MASTER 13052 JOINT 13131 SLAVE FX FY MASTER 13053 JOINT 13132 SLAVE FX FY MASTER 13054 JOINT 13133 SLAVE FX FY MASTER 13055 JOINT 13134 SLAVE FX FY MASTER 13056 JOINT 13135 SLAVE FX FY MASTER 13057 JOINT 13136 SLAVE FX FY MASTER 13058 JOINT 13137 SLAVE FX FY MASTER 13059 JOINT 13138 SLAVE FX FY MASTER 13060 JOINT 13139 SLAVE FX FY MASTER 13061 JOINT 13140 SLAVE FX FY MASTER 13062 JOINT 13141 SLAVE FX FY MASTER 13063 JOINT 13142 SLAVE FX FY MASTER 13064 JOINT 13143 SLAVE FX FY MASTER 13065 JOINT 13144 SLAVE FX FY MASTER 13066 JOINT 13145 SLAVE FX FY MASTER 13067 JOINT 13146 SLAVE FX FY MASTER 13068 JOINT 13147 SLAVE FX FY MASTER 13069 JOINT 13148 SLAVE FX FY MASTER 13070 JOINT 13149 SLAVE FX FY MASTER 13071 JOINT 13150 SLAVE FX FY MASTER 13072 JOINT 13151 SLAVE FX FY MASTER 13073 JOINT 13152 SLAVE FX FY MASTER 13074 JOINT 13153 SLAVE FX FY MASTER 13075 JOINT 13154 SLAVE FX FY MASTER 13076 JOINT 13155 SLAVE FX FY MASTER 13077 JOINT 13156 SLAVE FX FY MASTER 13078 JOINT 13157 SLAVE FX FY MASTER 13079 JOINT 13158 SLAVE FX FY MASTER 13080 JOINT 13159 SLAVE FX FY MASTER 13081 JOINT 13160 SLAVE FX FY MASTER 13082 JOINT 13161 SLAVE FX FY MASTER 13083 JOINT 13162 SLAVE FX FY MASTER 13084 JOINT 13163 SLAVE FX FY MASTER 13085 JOINT 13164 SLAVE FX FY MASTER 13086 JOINT 13165 SLAVE FX FY MASTER 13087 JOINT 13166 SLAVE FX FY MASTER 13088 JOINT 13167 SLAVE FX FY MASTER 13089 JOINT 13168 SLAVE FX FY MASTER 13090 JOINT 13169 SLAVE FX FY MASTER 13091 JOINT 13170 SLAVE FX FY MASTER 13092 JOINT 13171 SLAVE FX FY MASTER 13093 JOINT 13172 *EXPANSION JOINT 4 *FOR EXCEL ONLY FIRST NODE IS LOWER NUMBER IN YELLOW SLAVE FX FY MASTER 17913 JOINT 17992 SLAVE FX FY MASTER 17914 JOINT 17993 SLAVE FX FY MASTER 17915 JOINT 17994 SLAVE FX FY MASTER 17916 JOINT 17995 SLAVE FX FY MASTER 17917 JOINT 17996 SLAVE FX FY MASTER 17918 JOINT 17997 SLAVE FX FY MASTER 17919 JOINT 17998 SLAVE FX FY MASTER 17920 JOINT 17999 SLAVE FX FY MASTER 17921 JOINT 18000 SLAVE FX FY MASTER 17922 JOINT 18001 SLAVE FX FY MASTER 17923 JOINT 18002 SLAVE FX FY MASTER 17924 JOINT 18003 SLAVE FX FY MASTER 17925 JOINT 18004 SLAVE FX FY MASTER 17926 JOINT 18005 SLAVE FX FY MASTER 17927 JOINT 18006 SLAVE FX FY MASTER 17928 JOINT 18007 SLAVE FX FY MASTER 17929 JOINT 18008 SLAVE FX FY MASTER 17930 JOINT 18009 SLAVE FX FY MASTER 17931 JOINT 18010 SLAVE FX FY MASTER 17932 JOINT 18011 SLAVE FX FY MASTER 17933 JOINT 18012 SLAVE FX FY MASTER 17934 JOINT 18013 SLAVE FX FY MASTER 17935 JOINT 18014 SLAVE FX FY MASTER 17936 JOINT 18015 SLAVE FX FY MASTER 17937 JOINT 18016 SLAVE FX FY MASTER 17938 JOINT 18017 SLAVE FX FY MASTER 17939 JOINT 18018 SLAVE FX FY MASTER 17940 JOINT 18019 SLAVE FX FY MASTER 17941 JOINT 18020 SLAVE FX FY MASTER 17942 JOINT 18021 SLAVE FX FY MASTER 17943 JOINT 18022 SLAVE FX FY MASTER 17944 JOINT 18023 SLAVE FX FY MASTER 17945 JOINT 18024 SLAVE FX FY MASTER 17946 JOINT 18025 SLAVE FX FY MASTER 17947 JOINT 18026 SLAVE FX FY MASTER 17948 JOINT 18027 SLAVE FX FY MASTER 17949 JOINT 18028 SLAVE FX FY MASTER 17950 JOINT 18029 SLAVE FX FY MASTER 17951 JOINT 18030 SLAVE FX FY MASTER 17952 JOINT 18031 SLAVE FX FY MASTER 17953 JOINT 18032 SLAVE FX FY MASTER 17954 JOINT 18033 SLAVE FX FY MASTER 17955 JOINT 18034 SLAVE FX FY MASTER 17956 JOINT 18035 SLAVE FX FY MASTER 17957 JOINT 18036 SLAVE FX FY MASTER 17958 JOINT 18037 SLAVE FX FY MASTER 17959 JOINT 18038 SLAVE FX FY MASTER 17960 JOINT 18039 SLAVE FX FY MASTER 17961 JOINT 18040 SLAVE FX FY MASTER 17962 JOINT 18041 SLAVE FX FY MASTER 17963 JOINT 18042 SLAVE FX FY MASTER 17964 JOINT 18043 SLAVE FX FY MASTER 17965 JOINT 18044 SLAVE FX FY MASTER 17966 JOINT 18045 SLAVE FX FY MASTER 17967 JOINT 18046 SLAVE FX FY MASTER 17968 JOINT 18047 SLAVE FX FY MASTER 17969 JOINT 18048 SLAVE FX FY MASTER 17970 JOINT 18049 SLAVE FX FY MASTER 17971 JOINT 18050 SLAVE FX FY MASTER 17972 JOINT 18051 SLAVE FX FY MASTER 17973 JOINT 18052 SLAVE FX FY MASTER 17974 JOINT 18053 SLAVE FX FY MASTER 17975 JOINT 18054 SLAVE FX FY MASTER 17976 JOINT 18055 SLAVE FX FY MASTER 17977 JOINT 18056 SLAVE FX FY MASTER 17978 JOINT 18057 SLAVE FX FY MASTER 17979 JOINT 18058 SLAVE FX FY MASTER 17980 JOINT 18059 SLAVE FX FY MASTER 17981 JOINT 18060 SLAVE FX FY MASTER 17982 JOINT 18061 SLAVE FX FY MASTER 17983 JOINT 18062 SLAVE FX FY MASTER 17984 JOINT 18063 SLAVE FX FY MASTER 17985 JOINT 18064 SLAVE FX FY MASTER 17986 JOINT 18065 SLAVE FX FY MASTER 17987 JOINT 18066 SLAVE FX FY MASTER 17988 JOINT 18067 SLAVE FX FY MASTER 17989 JOINT 18068 SLAVE FX FY MASTER 17990 JOINT 18069 SLAVE FX FY MASTER 17991 JOINT 18070 *EXPANSION JOINT 5 *FOR EXCEL ONLY FIRST NODE IS LOWER NUMBER IN YELLOW SLAVE FX FY MASTER 22729 JOINT 22805 SLAVE FX FY MASTER 22730 JOINT 22806 SLAVE FX FY MASTER 22731 JOINT 22807 SLAVE FX FY MASTER 22732 JOINT 22808 SLAVE FX FY MASTER 22733 JOINT 22809 SLAVE FX FY MASTER 22734 JOINT 22810 SLAVE FX FY MASTER 22735 JOINT 22811 SLAVE FX FY MASTER 22736 JOINT 22812 SLAVE FX FY MASTER 22737 JOINT 22813 SLAVE FX FY MASTER 22738 JOINT 22814 SLAVE FX FY MASTER 22739 JOINT 22815 SLAVE FX FY MASTER 22740 JOINT 22816 SLAVE FX FY MASTER 22741 JOINT 22817 SLAVE FX FY MASTER 22742 JOINT 22818 SLAVE FX FY MASTER 22743 JOINT 22819 SLAVE FX FY MASTER 22744 JOINT 22820 SLAVE FX FY MASTER 22745 JOINT 22821 SLAVE FX FY MASTER 22746 JOINT 22822 SLAVE FX FY MASTER 22747 JOINT 22823 SLAVE FX FY MASTER 22748 JOINT 22824 SLAVE FX FY MASTER 22749 JOINT 22825 SLAVE FX FY MASTER 22750 JOINT 22826 SLAVE FX FY MASTER 22751 JOINT 22827 SLAVE FX FY MASTER 22752 JOINT 22828 SLAVE FX FY MASTER 22753 JOINT 22829 SLAVE FX FY MASTER 22754 JOINT 22830 SLAVE FX FY MASTER 22755 JOINT 22831 SLAVE FX FY MASTER 22756 JOINT 22832 SLAVE FX FY MASTER 22757 JOINT 22833 SLAVE FX FY MASTER 22758 JOINT 22834 SLAVE FX FY MASTER 22759 JOINT 22835 SLAVE FX FY MASTER 22760 JOINT 22836 SLAVE FX FY MASTER 22761 JOINT 22837 SLAVE FX FY MASTER 22762 JOINT 22838 SLAVE FX FY MASTER 22763 JOINT 22839 SLAVE FX FY MASTER 22764 JOINT 22840 SLAVE FX FY MASTER 22765 JOINT 22841 SLAVE FX FY MASTER 22766 JOINT 22842 SLAVE FX FY MASTER 22767 JOINT 22843 SLAVE FX FY MASTER 22768 JOINT 22844 SLAVE FX FY MASTER 22769 JOINT 22845 SLAVE FX FY MASTER 22770 JOINT 22846 SLAVE FX FY MASTER 22771 JOINT 22847 SLAVE FX FY MASTER 22772 JOINT 22848 SLAVE FX FY MASTER 22773 JOINT 22849 SLAVE FX FY MASTER 22774 JOINT 22850 SLAVE FX FY MASTER 22775 JOINT 22851 SLAVE FX FY MASTER 22776 JOINT 22852 SLAVE FX FY MASTER 22777 JOINT 22853 SLAVE FX FY MASTER 22778 JOINT 22854 SLAVE FX FY MASTER 22779 JOINT 22855 SLAVE FX FY MASTER 22780 JOINT 22856 SLAVE FX FY MASTER 22781 JOINT 22857 SLAVE FX FY MASTER 22782 JOINT 22858 SLAVE FX FY MASTER 22783 JOINT 22859 SLAVE FX FY MASTER 22784 JOINT 22860 SLAVE FX FY MASTER 22785 JOINT 22861 SLAVE FX FY MASTER 22786 JOINT 22862 SLAVE FX FY MASTER 22787 JOINT 22863 SLAVE FX FY MASTER 22788 JOINT 22864 SLAVE FX FY MASTER 22789 JOINT 22865 SLAVE FX FY MASTER 22790 JOINT 22866 SLAVE FX FY MASTER 22791 JOINT 22867 SLAVE FX FY MASTER 22792 JOINT 22868 SLAVE FX FY MASTER 22793 JOINT 22869 SLAVE FX FY MASTER 22794 JOINT 22870 SLAVE FX FY MASTER 22795 JOINT 22871 SLAVE FX FY MASTER 22796 JOINT 22872 SLAVE FX FY MASTER 22797 JOINT 22873 SLAVE FX FY MASTER 22798 JOINT 22874 SLAVE FX FY MASTER 22799 JOINT 22875 SLAVE FX FY MASTER 22800 JOINT 22876 SLAVE FX FY MASTER 22801 JOINT 22877 SLAVE FX FY MASTER 22802 JOINT 22878 SLAVE FX FY MASTER 22803 JOINT 22879 SLAVE FX FY MASTER 22804 JOINT 22880 *EXPANSION JOINT 6 *FOR EXCEL ONLY FIRST NODE IS LOWER NUMBER IN YELLOW SLAVE FX FY MASTER 27517 JOINT 27585 SLAVE FX FY MASTER 27518 JOINT 27586 SLAVE FX FY MASTER 27519 JOINT 27587 SLAVE FX FY MASTER 27520 JOINT 27588 SLAVE FX FY MASTER 27521 JOINT 27589 SLAVE FX FY MASTER 27522 JOINT 27590 SLAVE FX FY MASTER 27523 JOINT 27591 SLAVE FX FY MASTER 27524 JOINT 27592 SLAVE FX FY MASTER 27525 JOINT 27593 SLAVE FX FY MASTER 27526 JOINT 27594 SLAVE FX FY MASTER 27527 JOINT 27595 SLAVE FX FY MASTER 27528 JOINT 27596 SLAVE FX FY MASTER 27529 JOINT 27597 SLAVE FX FY MASTER 27530 JOINT 27598 SLAVE FX FY MASTER 27531 JOINT 27599 SLAVE FX FY MASTER 27532 JOINT 27600 SLAVE FX FY MASTER 27533 JOINT 27601 SLAVE FX FY MASTER 27534 JOINT 27602 SLAVE FX FY MASTER 27535 JOINT 27603 SLAVE FX FY MASTER 27536 JOINT 27604 SLAVE FX FY MASTER 27537 JOINT 27605 SLAVE FX FY MASTER 27538 JOINT 27606 SLAVE FX FY MASTER 27539 JOINT 27607 SLAVE FX FY MASTER 27540 JOINT 27608 SLAVE FX FY MASTER 27541 JOINT 27609 SLAVE FX FY MASTER 27542 JOINT 27610 SLAVE FX FY MASTER 27543 JOINT 27611 SLAVE FX FY MASTER 27544 JOINT 27612 SLAVE FX FY MASTER 27545 JOINT 27613 SLAVE FX FY MASTER 27546 JOINT 27614 SLAVE FX FY MASTER 27547 JOINT 27615 SLAVE FX FY MASTER 27548 JOINT 27616 SLAVE FX FY MASTER 27549 JOINT 27617 SLAVE FX FY MASTER 27550 JOINT 27618 SLAVE FX FY MASTER 27551 JOINT 27619 SLAVE FX FY MASTER 27552 JOINT 27620 SLAVE FX FY MASTER 27553 JOINT 27621 SLAVE FX FY MASTER 27554 JOINT 27622 SLAVE FX FY MASTER 27555 JOINT 27623 SLAVE FX FY MASTER 27556 JOINT 27624 SLAVE FX FY MASTER 27557 JOINT 27625 SLAVE FX FY MASTER 27558 JOINT 27626 SLAVE FX FY MASTER 27559 JOINT 27627 SLAVE FX FY MASTER 27560 JOINT 27628 SLAVE FX FY MASTER 27561 JOINT 27629 SLAVE FX FY MASTER 27562 JOINT 27630 SLAVE FX FY MASTER 27563 JOINT 27631 SLAVE FX FY MASTER 27564 JOINT 27632 SLAVE FX FY MASTER 27565 JOINT 27633 SLAVE FX FY MASTER 27566 JOINT 27634 SLAVE FX FY MASTER 27567 JOINT 27635 SLAVE FX FY MASTER 27568 JOINT 27636 SLAVE FX FY MASTER 27569 JOINT 27637 SLAVE FX FY MASTER 27570 JOINT 27638 SLAVE FX FY MASTER 27571 JOINT 27639 SLAVE FX FY MASTER 27572 JOINT 27640 SLAVE FX FY MASTER 27573 JOINT 27641 SLAVE FX FY MASTER 27574 JOINT 27642 SLAVE FX FY MASTER 27575 JOINT 27643 SLAVE FX FY MASTER 27576 JOINT 27644 SLAVE FX FY MASTER 27577 JOINT 27645 SLAVE FX FY MASTER 27578 JOINT 27646 SLAVE FX FY MASTER 27579 JOINT 27647 SLAVE FX FY MASTER 27580 JOINT 27648 SLAVE FX FY MASTER 27581 JOINT 27649 SLAVE FX FY MASTER 27582 JOINT 27650 SLAVE FX FY MASTER 27583 JOINT 27651 SLAVE FX FY MASTER 27584 JOINT 27652 *EXPANSION JOINT 7 *FOR EXCEL ONLY FIRST NODE IS LOWER NUMBER IN YELLOW SLAVE FX FY MASTER 31793 JOINT 31725 SLAVE FX FY MASTER 31794 JOINT 31726 SLAVE FX FY MASTER 31795 JOINT 31727 SLAVE FX FY MASTER 31796 JOINT 31728 SLAVE FX FY MASTER 31797 JOINT 31729 SLAVE FX FY MASTER 31798 JOINT 31730 SLAVE FX FY MASTER 31799 JOINT 31731 SLAVE FX FY MASTER 31800 JOINT 31732 SLAVE FX FY MASTER 31801 JOINT 31733 SLAVE FX FY MASTER 31802 JOINT 31734 SLAVE FX FY MASTER 31803 JOINT 31735 SLAVE FX FY MASTER 31804 JOINT 31736 SLAVE FX FY MASTER 31805 JOINT 31737 SLAVE FX FY MASTER 31806 JOINT 31738 SLAVE FX FY MASTER 31807 JOINT 31739 SLAVE FX FY MASTER 31808 JOINT 31740 SLAVE FX FY MASTER 31809 JOINT 31741 SLAVE FX FY MASTER 31810 JOINT 31742 SLAVE FX FY MASTER 31811 JOINT 31743 SLAVE FX FY MASTER 31812 JOINT 31744 SLAVE FX FY MASTER 31813 JOINT 31745 SLAVE FX FY MASTER 31814 JOINT 31746 SLAVE FX FY MASTER 31815 JOINT 31747 SLAVE FX FY MASTER 31816 JOINT 31748 SLAVE FX FY MASTER 31817 JOINT 31749 SLAVE FX FY MASTER 31818 JOINT 31750 SLAVE FX FY MASTER 31819 JOINT 31751 SLAVE FX FY MASTER 31820 JOINT 31752 SLAVE FX FY MASTER 31821 JOINT 31753 SLAVE FX FY MASTER 31822 JOINT 31754 SLAVE FX FY MASTER 31823 JOINT 31755 SLAVE FX FY MASTER 31824 JOINT 31756 SLAVE FX FY MASTER 31825 JOINT 31757 SLAVE FX FY MASTER 31826 JOINT 31758 SLAVE FX FY MASTER 31827 JOINT 31759 SLAVE FX FY MASTER 31828 JOINT 31760 SLAVE FX FY MASTER 31829 JOINT 31761 SLAVE FX FY MASTER 31830 JOINT 31762 SLAVE FX FY MASTER 31831 JOINT 31763 SLAVE FX FY MASTER 31832 JOINT 31764 SLAVE FX FY MASTER 31833 JOINT 31765 SLAVE FX FY MASTER 31834 JOINT 31766 SLAVE FX FY MASTER 31835 JOINT 31767 SLAVE FX FY MASTER 31836 JOINT 31768 SLAVE FX FY MASTER 31837 JOINT 31769 SLAVE FX FY MASTER 31838 JOINT 31770 SLAVE FX FY MASTER 31839 JOINT 31771 SLAVE FX FY MASTER 31840 JOINT 31772 SLAVE FX FY MASTER 31841 JOINT 31773 SLAVE FX FY MASTER 31842 JOINT 31774 SLAVE FX FY MASTER 31843 JOINT 31775 SLAVE FX FY MASTER 31844 JOINT 31776 SLAVE FX FY MASTER 31845 JOINT 31777 SLAVE FX FY MASTER 31846 JOINT 31778 SLAVE FX FY MASTER 31847 JOINT 31779 SLAVE FX FY MASTER 31848 JOINT 31780 SLAVE FX FY MASTER 31849 JOINT 31781 SLAVE FX FY MASTER 31850 JOINT 31782 SLAVE FX FY MASTER 31851 JOINT 31783 SLAVE FX FY MASTER 31852 JOINT 31784 SLAVE FX FY MASTER 31853 JOINT 31785 SLAVE FX FY MASTER 31854 JOINT 31786 SLAVE FX FY MASTER 31855 JOINT 31787 SLAVE FX FY MASTER 31856 JOINT 31788 SLAVE FX FY MASTER 31857 JOINT 31789 SLAVE FX FY MASTER 31858 JOINT 31790 SLAVE FX FY MASTER 31859 JOINT 31791 SLAVE FX FY MASTER 31860 JOINT 31792
You have used FX and FY direction as master/slave connections. This means that the displacement in lateral X direction and vertical Y direction between each master node and slave node will be the same. Are you getting different displacements between each master and slave node in X or Y direction? In general, the model is not symmetrical, so I think it is expected that displaced shape at different parts of the structure is different.
I do have different displacements in X and Y (see image below). The whole 7th expansion joint (node 31793 to 31792) is not working properly.
This is despite being coded the very same way as the others.
A slight variation in displacements between the master and slave nodes is expected as displacements at slave nodes are equal to the displacement of the master node plus a rigid rotation. This is mentioned in STAAD.Pro Help section Technical Reference of STAAD Commands > TR.28 Rigid Diaphragm Modeling > TR.28.1 Master/Slave Specification.
Agreed, but how come other master/slave isn't behaving the same way for all the expansion joints? See below working/not working. It's the same code.
How can the same code make results so different? Also note, FZ is supposed to be free, yet distance between master and slave nodes are constant (meaning FZ is rigid).
