how to connect beam to column
how to connect beam to column.  column size is 4m x .850m, baem size 0.750m x 0.400m.
see the attach file image. Yellow line is the column.
  • I think column of dimensions 4x0.85 should be model as a wall by using the plate elements. That wall should be meshed to get the most accurate results. The beam can be connected to a wall by sharing a common node between the plate and beam.
  • Can you help me how to do it i don't know how to model shearwall in StaadPro Connect addition here is the command file
    INPUT WIDTH 79
    UNIT METER KN
    JOINT COORDINATES
    1 0 0 4.91; 2 0 0 1.08; 3 0 0 -5.935; 6 4.62 0 4.91; 7 4.62 0 -5.935;
    8 4.62 0 -9.735; 9 4.62 0 9.82; 10 11.74 0 4.91; 11 11.74 0 -5.935;
    12 11.74 0 -9.735; 13 11.74 0 9.82; 14 20.65 0 4.91; 15 20.65 0 -5.935;
    16 20.65 0 -9.735; 17 20.65 0 9.82; 18 27.77 0 4.91; 19 27.77 0 -5.935;
    20 27.77 0 -9.735; 22 32.25 0 4.91; 23 32.25 0 -5.935; 24 32.25 0 1.08;
    30 4.62 -3 -9.735; 31 4.62 -3 9.82; 42 27.77 -3 -9.735; 46 0 0 -2.4275;
    47 32.25 0 -2.4275; 48 -1.95 0 4.91; 49 -1.95 0 -5.935; 50 34.2 0 4.91;
    51 34.2 0 -5.935; 52 24.92 0 4.91; 53 24.92 0 9.82; 54 27.77 0 7.365;
    56 4.62 0 1.08; 57 11.74 0 1.08; 58 20.65 0 1.08; 59 27.77 0 1.08;
    60 4.62 0 -2.4275; 61 11.74 0 -2.428; 62 20.65 0 -2.428; 63 27.77 0 -2.428;
    464 2.31 0 -5.935; 465 11.74 0 -7.835; 466 20.65 0 -7.835; 467 30.01 0 -5.935;
    468 2.31 0 4.91; 469 11.74 0 7.365; 470 20.65 0 7.365; 471 30.01 0 4.91;
    552 2.31 -3 -5.935; 553 11.74 -3 -7.835; 554 20.65 -3 -7.835;
    555 30.01 -3 -5.935; 556 2.31 -3 4.91; 557 11.74 -3 7.365; 558 20.65 -3 7.365;
    559 30.01 -3 4.91; 560 0 3 4.91; 561 0 3 1.08; 562 0 3 -5.935; 563 4.62 3 4.91;
    564 4.62 3 -5.935; 565 4.62 3 -9.735; 566 4.62 3 9.82; 567 11.74 3 4.91;
    568 11.74 3 -5.935; 569 11.74 3 -9.735; 570 11.74 3 9.82; 571 20.65 3 4.91;
    572 20.65 3 -5.935; 573 20.65 3 -9.735; 574 20.65 3 9.82; 575 27.77 3 4.91;
    576 27.77 3 -5.935; 577 27.77 3 -9.735; 579 32.25 3 4.91; 580 32.25 3 -5.935;
    581 32.25 3 1.08; 582 0 3 -2.4275; 583 32.25 3 -2.4275; 584 -1.95 3 4.91;
    585 -1.95 3 -5.935; 586 34.2 3 4.91; 587 34.2 3 -5.935; 588 24.92 3 4.91;
    589 24.92 3 9.82; 592 4.62 3 1.08; 593 11.74 3 1.08; 594 20.65 3 1.08;
    595 27.77 3 1.08; 596 4.62 3 -2.4275; 597 11.74 3 -2.428; 598 20.65 3 -2.428;
    599 27.77 3 -2.428; 600 2.31 3 -5.935; 601 11.74 3 -7.835; 602 20.65 3 -7.835;
    603 30.01 3 -5.935; 604 2.31 3 4.91; 605 11.74 3 7.365; 606 20.65 3 7.365;
    607 30.01 3 4.91; 608 0 6 4.91; 609 0 6 1.08; 610 0 6 -5.935; 611 4.62 6 4.91;
    612 4.62 6 -5.935; 613 4.62 6 -9.735; 614 4.62 6 9.82; 615 11.74 6 4.91;
    616 11.74 6 -5.935; 617 11.74 6 -9.735; 618 11.74 6 9.82; 619 20.65 6 4.91;
    620 20.65 6 -5.935; 621 20.65 6 -9.735; 622 20.65 6 9.82; 623 27.77 6 4.91;
    624 27.77 6 -5.935; 625 27.77 6 -9.735; 627 32.25 6 4.91; 628 32.25 6 -5.935;
    629 32.25 6 1.08; 630 0 6 -2.4275; 631 32.25 6 -2.4275; 632 -1.95 6 4.91;
    633 -1.95 6 -5.935; 634 34.2 6 4.91; 635 34.2 6 -5.935; 636 24.92 6 4.91;
    637 24.92 6 9.82; 640 4.62 6 1.08; 641 11.74 6 1.08; 642 20.65 6 1.08;
    643 27.77 6 1.08; 644 4.62 6 -2.4275; 645 11.74 6 -2.428; 646 20.65 6 -2.428;
    647 27.77 6 -2.428; 648 2.31 6 -5.935; 649 11.74 6 -7.835; 650 20.65 6 -7.835;
    651 30.01 6 -5.935; 652 2.31 6 4.91; 653 11.74 6 7.365; 654 20.65 6 7.365;
    655 30.01 6 4.91; 656 0 9 4.91; 657 0 9 1.08; 658 0 9 -5.935; 659 4.62 9 4.91;
    660 4.62 9 -5.935; 661 4.62 9 -9.735; 662 4.62 9 9.82; 663 11.74 9 4.91;
    664 11.74 9 -5.935; 665 11.74 9 -9.735; 666 11.74 9 9.82; 667 20.65 9 4.91;
    668 20.65 9 -5.935; 669 20.65 9 -9.735; 670 20.65 9 9.82; 671 27.77 9 4.91;
    672 27.77 9 -5.935; 673 27.77 9 -9.735; 675 32.25 9 4.91; 676 32.25 9 -5.935;
    677 32.25 9 1.08; 678 0 9 -2.4275; 679 32.25 9 -2.4275; 680 -1.95 9 4.91;
    681 -1.95 9 -5.935; 682 34.2 9 4.91; 683 34.2 9 -5.935; 684 24.92 9 4.91;
    685 24.92 9 9.82; 688 4.62 9 1.08; 689 11.74 9 1.08; 690 20.65 9 1.08;
    691 27.77 9 1.08; 692 4.62 9 -2.4275; 693 11.74 9 -2.428; 694 20.65 9 -2.428;
    695 27.77 9 -2.428; 696 2.31 9 -5.935; 697 11.74 9 -7.835; 698 20.65 9 -7.835;
    699 30.01 9 -5.935; 700 2.31 9 4.91; 701 11.74 9 7.365; 702 20.65 9 7.365;
    703 30.01 9 4.91; 704 0 12 4.91; 705 0 12 1.08; 706 0 12 -5.935;
    707 4.62 12 4.91; 708 4.62 12 -5.935; 709 4.62 12 -9.735; 710 4.62 12 9.82;
    711 11.74 12 4.91; 712 11.74 12 -5.935; 713 11.74 12 -9.735; 714 11.74 12 9.82;
    715 20.65 12 4.91; 716 20.65 12 -5.935; 717 20.65 12 -9.735; 718 20.65 12 9.82;
    719 27.77 12 4.91; 720 27.77 12 -5.935; 721 27.77 12 -9.735; 723 32.25 12 4.91;
    724 32.25 12 -5.935; 725 32.25 12 1.08; 726 0 12 -2.4275; 727 32.25 12 -2.4275;
    728 -1.95 12 4.91; 729 -1.95 12 -5.935; 730 34.2 12 4.91; 731 34.2 12 -5.935;
    732 24.92 12 4.91; 733 24.92 12 9.82; 736 4.62 12 1.08; 737 11.74 12 1.08;
    738 20.65 12 1.08; 739 27.77 12 1.08; 740 4.62 12 -2.4275; 741 11.74 12 -2.428;
    742 20.65 12 -2.428; 743 27.77 12 -2.428; 744 2.31 12 -5.935;
    745 11.74 12 -7.835; 746 20.65 12 -7.835; 747 30.01 12 -5.935;
    748 2.31 12 4.91; 749 11.74 12 7.365; 750 20.65 12 7.365; 751 30.01 12 4.91;
    752 0 15 4.91; 753 0 15 1.08; 754 0 15 -5.935; 755 4.62 15 4.91;
    756 4.62 15 -5.935; 757 4.62 15 -9.735; 758 4.62 15 9.82; 759 11.74 15 4.91;
    760 11.74 15 -5.935; 761 11.74 15 -9.735; 762 11.74 15 9.82; 763 20.65 15 4.91;
    764 20.65 15 -5.935; 765 20.65 15 -9.735; 766 20.65 15 9.82; 767 27.77 15 4.91;
    768 27.77 15 -5.935; 769 27.77 15 -9.735; 771 32.25 15 4.91;
    772 32.25 15 -5.935; 773 32.25 15 1.08; 774 0 15 -2.4275; 775 32.25 15 -2.4275;
    776 -1.95 15 4.91; 777 -1.95 15 -5.935; 778 34.2 15 4.91; 779 34.2 15 -5.935;
    780 24.92 15 4.91; 781 24.92 15 9.82; 784 4.62 15 1.08; 785 11.74 15 1.08;
    786 20.65 15 1.08; 787 27.77 15 1.08; 788 4.62 15 -2.4275; 789 11.74 15 -2.428;
    790 20.65 15 -2.428; 791 27.77 15 -2.428; 792 2.31 15 -5.935;
    793 11.74 15 -7.835; 794 20.65 15 -7.835; 795 30.01 15 -5.935;
    796 2.31 15 4.91; 797 11.74 15 7.365; 798 20.65 15 7.365; 799 30.01 15 4.91;
    800 0 18 4.91; 801 0 18 1.08; 802 0 18 -5.935; 803 4.62 18 4.91;
    804 4.62 18 -5.935; 805 4.62 18 -9.735; 806 4.62 18 9.82; 807 11.74 18 4.91;
    808 11.74 18 -5.935; 809 11.74 18 -9.735; 810 11.74 18 9.82; 811 20.65 18 4.91;
    812 20.65 18 -5.935; 813 20.65 18 -9.735; 814 20.65 18 9.82; 815 27.77 18 4.91;
    816 27.77 18 -5.935; 817 27.77 18 -9.735; 819 32.25 18 4.91;
    820 32.25 18 -5.935; 821 32.25 18 1.08; 822 0 18 -2.4275; 823 32.25 18 -2.4275;
    824 -1.95 18 4.91; 825 -1.95 18 -5.935; 826 34.2 18 4.91; 827 34.2 18 -5.935;
    828 24.92 18 4.91; 829 24.92 18 9.82; 832 4.62 18 1.08; 833 11.74 18 1.08;
    834 20.65 18 1.08; 835 27.77 18 1.08; 836 4.62 18 -2.4275; 837 11.74 18 -2.428;
    838 20.65 18 -2.428; 839 27.77 18 -2.428; 840 2.31 18 -5.935;
    841 11.74 18 -7.835; 842 20.65 18 -7.835; 843 30.01 18 -5.935;
    844 2.31 18 4.91; 845 11.74 18 7.365; 846 20.65 18 7.365; 847 30.01 18 4.91;
    848 0 21 4.91; 849 0 21 1.08; 850 0 21 -5.935; 851 4.62 21 4.91;
    852 4.62 21 -5.935; 853 4.62 21 -9.735; 854 4.62 21 9.82; 855 11.74 21 4.91;
    856 11.74 21 -5.935; 857 11.74 21 -9.735; 858 11.74 21 9.82; 859 20.65 21 4.91;
    860 20.65 21 -5.935; 861 20.65 21 -9.735; 862 20.65 21 9.82; 863 27.77 21 4.91;
    864 27.77 21 -5.935; 865 27.77 21 -9.735; 867 32.25 21 4.91;
    868 32.25 21 -5.935; 869 32.25 21 1.08; 870 0 21 -2.4275; 871 32.25 21 -2.4275;
    872 -1.95 21 4.91; 873 -1.95 21 -5.935; 874 34.2 21 4.91; 875 34.2 21 -5.935;
    876 24.92 21 4.91; 877 24.92 21 9.82; 880 4.62 21 1.08; 881 11.74 21 1.08;
    882 20.65 21 1.08; 883 27.77 21 1.08; 884 4.62 21 -2.4275; 885 11.74 21 -2.428;
    886 20.65 21 -2.428; 887 27.77 21 -2.428; 888 2.31 21 -5.935;
    889 11.74 21 -7.835; 890 20.65 21 -7.835; 891 30.01 21 -5.935;
    892 2.31 21 4.91; 893 11.74 21 7.365; 894 20.65 21 7.365; 895 30.01 21 4.91;
    896 0 24 4.91; 897 0 24 1.08; 898 0 24 -5.935; 899 4.62 24 4.91;
    900 4.62 24 -5.935; 901 4.62 24 -9.735; 902 4.62 24 9.82; 903 11.74 24 4.91;
    904 11.74 24 -5.935; 905 11.74 24 -9.735; 906 11.74 24 9.82; 907 20.65 24 4.91;
    908 20.65 24 -5.935; 909 20.65 24 -9.735; 910 20.65 24 9.82; 911 27.77 24 4.91;
    912 27.77 24 -5.935; 913 27.77 24 -9.735; 915 32.25 24 4.91;
    916 32.25 24 -5.935; 917 32.25 24 1.08; 918 0 24 -2.4275; 919 32.25 24 -2.4275;
    920 -1.95 24 4.91; 921 -1.95 24 -5.935; 922 34.2 24 4.91; 923 34.2 24 -5.935;
    924 24.92 24 4.91; 925 24.92 24 9.82; 928 4.62 24 1.08; 929 11.74 24 1.08;
    930 20.65 24 1.08; 931 27.77 24 1.08; 932 4.62 24 -2.4275; 933 11.74 24 -2.428;
    934 20.65 24 -2.428; 935 27.77 24 -2.428; 936 2.31 24 -5.935;
    937 11.74 24 -7.835; 938 20.65 24 -7.835; 939 30.01 24 -5.935;
    940 2.31 24 4.91; 941 11.74 24 7.365; 942 20.65 24 7.365; 943 30.01 24 4.91;
    944 0 27 4.91; 945 0 27 1.08; 946 0 27 -5.935; 947 4.62 27 4.91;
    948 4.62 27 -5.935; 949 4.62 27 -9.735; 950 4.62 27 9.82; 951 11.74 27 4.91;
    952 11.74 27 -5.935; 953 11.74 27 -9.735; 954 11.74 27 9.82; 955 20.65 27 4.91;
    956 20.65 27 -5.935; 957 20.65 27 -9.735; 958 20.65 27 9.82; 959 27.77 27 4.91;
    960 27.77 27 -5.935; 961 27.77 27 -9.735; 963 32.25 27 4.91;
    964 32.25 27 -5.935; 965 32.25 27 1.08; 966 0 27 -2.4275; 967 32.25 27 -2.4275;
    968 -1.95 27 4.91; 969 -1.95 27 -5.935; 970 34.2 27 4.91; 971 34.2 27 -5.935;
    972 24.92 27 4.91; 973 24.92 27 9.82; 976 4.62 27 1.08; 977 11.74 27 1.08;
    978 20.65 27 1.08; 979 27.77 27 1.08; 980 4.62 27 -2.4275; 981 11.74 27 -2.428;
    982 20.65 27 -2.428; 983 27.77 27 -2.428; 984 2.31 27 -5.935;
    985 11.74 27 -7.835; 986 20.65 27 -7.835; 987 30.01 27 -5.935;
    988 2.31 27 4.91; 989 11.74 27 7.365; 990 20.65 27 7.365; 991 30.01 27 4.91;
    992 0 30 4.91; 993 0 30 1.08; 994 0 30 -5.935; 995 4.62 30 4.91;
    996 4.62 30 -5.935; 997 4.62 30 -9.735; 998 4.62 30 9.82; 999 11.74 30 4.91;
    1000 11.74 30 -5.935; 1001 11.74 30 -9.735; 1002 11.74 30 9.82;
    1003 20.65 30 4.91; 1004 20.65 30 -5.935; 1005 20.65 30 -9.735;
    1006 20.65 30 9.82; 1007 27.77 30 4.91; 1008 27.77 30 -5.935;
    1009 27.77 30 -9.735; 1011 32.25 30 4.91; 1012 32.25 30 -5.935;
    1013 32.25 30 1.08; 1014 0 30 -2.4275; 1015 32.25 30 -2.4275;
    1016 -1.95 30 4.91; 1017 -1.95 30 -5.935; 1018 34.2 30 4.91;
    1019 34.2 30 -5.935; 1020 24.92 30 4.91; 1021 24.92 30 9.82; 1024 4.62 30 1.08;
    1025 11.74 30 1.08; 1026 20.65 30 1.08; 1027 27.77 30 1.08;
    1028 4.62 30 -2.4275; 1029 11.74 30 -2.428; 1030 20.65 30 -2.428;
    1031 27.77 30 -2.428; 1032 2.31 30 -5.935; 1033 11.74 30 -7.835;
    1034 20.65 30 -7.835; 1035 30.01 30 -5.935; 1036 2.31 30 4.91;
    1037 11.74 30 7.365; 1038 20.65 30 7.365; 1039 30.01 30 4.91; 1040 0 33 4.91;
    1041 0 33 1.08; 1042 0 33 -5.935; 1043 4.62 33 4.91; 1044 4.62 33 -5.935;
    1045 4.62 33 -9.735; 1046 4.62 33 9.82; 1047 11.74 33 4.91;
    1048 11.74 33 -5.935; 1049 11.74 33 -9.735; 1050 11.74 33 9.82;
    1051 20.65 33 4.91; 1052 20.65 33 -5.935; 1053 20.65 33 -9.735;
    1054 20.65 33 9.82; 1055 27.77 33 4.91; 1056 27.77 33 -5.935;
    1057 27.77 33 -9.735; 1059 32.25 33 4.91; 1060 32.25 33 -5.935;
    1061 32.25 33 1.08; 1062 0 33 -2.4275; 1063 32.25 33 -2.4275;
    1064 24.92 33 4.91; 1065 24.92 33 9.82; 1068 4.62 33 1.08; 1069 11.74 33 1.08;
    1070 20.65 33 1.08; 1071 27.77 33 1.08; 1072 4.62 33 -2.4275;
    1073 11.74 33 -2.428; 1074 20.65 33 -2.428; 1075 27.77 33 -2.428;
    1076 2.31 33 -5.935; 1077 11.74 33 -7.835; 1078 20.65 33 -7.835;
    1079 30.01 33 -5.935; 1080 2.31 33 4.91; 1081 11.74 33 7.365;
    1082 20.65 33 7.365; 1083 30.01 33 4.91; 1084 0 36 4.91; 1085 0 36 1.08;
    1086 0 36 -5.935; 1087 4.62 36 4.91; 1088 4.62 36 -5.935; 1089 4.62 36 -9.735;
    1090 4.62 36 9.82; 1091 11.74 36 4.91; 1092 11.74 36 -5.935;
    1093 11.74 36 -9.735; 1094 11.74 36 9.82; 1095 20.65 36 4.91;
    1096 20.65 36 -5.935; 1097 20.65 36 -9.735; 1098 20.65 36 9.82;
    1099 27.77 36 4.91; 1100 27.77 36 -5.935; 1101 27.77 36 -9.735;
    1103 32.25 36 4.91; 1104 32.25 36 -5.935; 1105 32.25 36 1.08;
    1106 0 36 -2.4275; 1107 32.25 36 -2.4275; 1108 24.92 36 4.91;
    1109 24.92 36 9.82; 1112 4.62 36 1.08; 1113 11.74 36 1.08; 1114 20.65 36 1.08;
    1115 27.77 36 1.08; 1116 4.62 36 -2.4275; 1117 11.74 36 -2.428;
    1118 20.65 36 -2.428; 1119 27.77 36 -2.428; 1120 2.31 36 -5.935;
    1121 11.74 36 -7.835; 1122 20.65 36 -7.835; 1123 30.01 36 -5.935;
    1124 2.31 36 4.91; 1125 11.74 36 7.365; 1126 20.65 36 7.365;
    1127 30.01 36 4.91; 1128 0 39 4.91; 1129 0 39 1.08; 1130 0 39 -5.935;
    1131 4.62 39 4.91; 1132 4.62 39 -5.935; 1133 4.62 39 -9.735; 1134 4.62 39 9.82;
    1135 11.74 39 4.91; 1136 11.74 39 -5.935; 1137 11.74 39 -9.735;
    1138 11.74 39 9.82; 1139 20.65 39 4.91; 1140 20.65 39 -5.935;
    1141 20.65 39 -9.735; 1142 20.65 39 9.82; 1143 27.77 39 4.91;
    1144 27.77 39 -5.935; 1145 27.77 39 -9.735; 1147 32.25 39 4.91;
    1148 32.25 39 -5.935; 1149 32.25 39 1.08; 1150 0 39 -2.4275;
    1151 32.25 39 -2.4275; 1152 24.92 39 4.91; 1153 24.92 39 9.82;
    1156 4.62 39 1.08; 1157 11.74 39 1.08; 1158 20.65 39 1.08; 1159 27.77 39 1.08;
    1160 4.62 39 -2.4275; 1161 11.74 39 -2.428; 1162 20.65 39 -2.428;
    1163 27.77 39 -2.428; 1164 2.31 39 -5.935; 1165 11.74 39 -7.835;
    1166 20.65 39 -7.835; 1167 30.01 39 -5.935; 1168 2.31 39 4.91;
    1169 11.74 39 7.365; 1170 20.65 39 7.365; 1171 30.01 39 4.91; 1172 0 42 4.91;
    1173 0 42 1.08; 1174 0 42 -5.935; 1175 4.62 42 4.91; 1176 4.62 42 -5.935;
    1177 4.62 42 -9.735; 1178 4.62 42 9.82; 1179 11.74 42 4.91;
    1180 11.74 42 -5.935; 1181 11.74 42 -9.735; 1182 11.74 42 9.82;
    1183 20.65 42 4.91; 1184 20.65 42 -5.935; 1185 20.65 42 -9.735;
    1186 20.65 42 9.82; 1187 27.77 42 4.91; 1188 27.77 42 -5.935;
    1189 27.77 42 -9.735; 1191 32.25 42 4.91; 1192 32.25 42 -5.935;
    1193 32.25 42 1.08; 1194 0 42 -2.4275; 1195 32.25 42 -2.4275;
    1196 24.92 42 4.91; 1197 24.92 42 9.82; 1200 4.62 42 1.08; 1201 11.74 42 1.08;
    1202 20.65 42 1.08; 1203 27.77 42 1.08; 1204 4.62 42 -2.4275;
    1205 11.74 42 -2.428; 1206 20.65 42 -2.428; 1207 27.77 42 -2.428;
    1208 2.31 42 -5.935; 1209 11.74 42 -7.835; 1210 20.65 42 -7.835;
    1211 30.01 42 -5.935; 1212 2.31 42 4.91; 1213 11.74 42 7.365;
    1214 20.65 42 7.365; 1215 30.01 42 4.91; 1216 0 45 4.91; 1217 0 45 1.08;
    1218 0 45 -5.935; 1219 4.62 45 4.91; 1220 4.62 45 -5.935; 1221 4.62 45 -9.735;
    1222 4.62 45 9.82; 1223 11.74 45 4.91; 1224 11.74 45 -5.935;
    1225 11.74 45 -9.735; 1226 11.74 45 9.82; 1227 20.65 45 4.91;
    1228 20.65 45 -5.935; 1229 20.65 45 -9.735; 1230 20.65 45 9.82;
    1231 27.77 45 4.91; 1232 27.77 45 -5.935; 1233 27.77 45 -9.735;
    1235 32.25 45 4.91; 1236 32.25 45 -5.935; 1237 32.25 45 1.08;
    1238 0 45 -2.4275; 1239 32.25 45 -2.4275; 1240 24.92 45 4.91;
    1241 24.92 45 9.82; 1244 4.62 45 1.08; 1245 11.74 45 1.08; 1246 20.65 45 1.08;
    1247 27.77 45 1.08; 1248 4.62 45 -2.4275; 1249 11.74 45 -2.428;
    1250 20.65 45 -2.428; 1251 27.77 45 -2.428; 1252 2.31 45 -5.935;
    1253 11.74 45 -7.835; 1254 20.65 45 -7.835; 1255 30.01 45 -5.935;
    1256 2.31 45 4.91; 1257 11.74 45 7.365; 1258 20.65 45 7.365;
    1259 30.01 45 4.91; 1260 0 48 4.91; 1261 0 48 1.08; 1262 0 48 -5.935;
    1263 4.62 48 4.91; 1264 4.62 48 -5.935; 1265 4.62 48 -9.735; 1266 4.62 48 9.82;
    1267 11.74 48 4.91; 1268 11.74 48 -5.935; 1269 11.74 48 -9.735;
    1270 11.74 48 9.82; 1271 20.65 48 4.91; 1272 20.65 48 -5.935;
    1273 20.65 48 -9.735; 1274 20.65 48 9.82; 1275 27.77 48 4.91;
    1276 27.77 48 -5.935; 1277 27.77 48 -9.735; 1279 32.25 48 4.91;
    1280 32.25 48 -5.935; 1281 32.25 48 1.08; 1282 0 48 -2.4275;
    1283 32.25 48 -2.4275; 1284 24.92 48 4.91; 1285 24.92 48 9.82;
    1288 4.62 48 1.08; 1289 11.74 48 1.08; 1290 20.65 48 1.08; 1291 27.77 48 1.08;
    1292 4.62 48 -2.4275; 1293 11.74 48 -2.428; 1294 20.65 48 -2.428;
    1295 27.77 48 -2.428; 1296 2.31 48 -5.935; 1297 11.74 48 -7.835;
    1298 20.65 48 -7.835; 1299 30.01 48 -5.935; 1300 2.31 48 4.91;
    1301 11.74 48 7.365; 1302 20.65 48 7.365; 1303 30.01 48 4.91; 1304 0 51 4.91;
    1305 0 51 1.08; 1306 0 51 -5.935; 1307 4.62 51 4.91; 1308 4.62 51 -5.935;
    1309 4.62 51 -9.735; 1310 4.62 51 9.82; 1311 11.74 51 4.91;
    1312 11.74 51 -5.935; 1313 11.74 51 -9.735; 1314 11.74 51 9.82;
    1315 20.65 51 4.91; 1316 20.65 51 -5.935; 1317 20.65 51 -9.735;
    1318 20.65 51 9.82; 1319 27.77 51 4.91; 1320 27.77 51 -5.935;
    1321 27.77 51 -9.735; 1323 32.25 51 4.91; 1324 32.25 51 -5.935;
    1325 32.25 51 1.08; 1326 0 51 -2.4275; 1327 32.25 51 -2.4275;
    1328 24.92 51 4.91; 1329 24.92 51 9.82; 1332 4.62 51 1.08; 1333 11.74 51 1.08;
    1334 20.65 51 1.08; 1335 27.77 51 1.08; 1336 4.62 51 -2.4275;
    1337 11.74 51 -2.428; 1338 20.65 51 -2.428; 1339 27.77 51 -2.428;
    1340 2.31 51 -5.935; 1341 11.74 51 -7.835; 1342 20.65 51 -7.835;
    1343 30.01 51 -5.935; 1344 2.31 51 4.91; 1345 11.74 51 7.365;
    1346 20.65 51 7.365; 1347 30.01 51 4.91; 1348 0 54 4.91; 1349 0 54 1.08;
    1350 0 54 -5.935; 1351 4.62 54 4.91; 1352 4.62 54 -5.935; 1353 4.62 54 -9.735;
    1354 4.62 54 9.82; 1355 11.74 54 4.91; 1356 11.74 54 -5.935;
    1357 11.74 54 -9.735; 1358 11.74 54 9.82; 1359 20.65 54 4.91;
    1360 20.65 54 -5.935; 1361 20.65 54 -9.735; 1362 20.65 54 9.82;
    1363 27.77 54 4.91; 1364 27.77 54 -5.935; 1365 27.77 54 -9.735;
    1367 32.25 54 4.91; 1368 32.25 54 -5.935; 1369 32.25 54 1.08;
    1370 0 54 -2.4275; 1371 32.25 54 -2.4275; 1372 24.92 54 4.91;
    1373 24.92 54 9.82; 1376 4.62 54 1.08; 1377 11.74 54 1.08; 1378 20.65 54 1.08;
    1379 27.77 54 1.08; 1380 4.62 54 -2.4275; 1381 11.74 54 -2.428;
    1382 20.65 54 -2.428; 1383 27.77 54 -2.428; 1384 2.31 54 -5.935;
    1385 11.74 54 -7.835; 1386 20.65 54 -7.835; 1387 30.01 54 -5.935;
    1388 2.31 54 4.91; 1389 11.74 54 7.365; 1390 20.65 54 7.365;
    1391 30.01 54 4.91; 1392 0 57 4.91; 1393 0 57 1.08; 1394 0 57 -5.935;
    1395 4.62 57 4.91; 1396 4.62 57 -5.935; 1397 4.62 57 -9.735; 1398 4.62 57 9.82;
    1399 11.74 57 4.91; 1400 11.74 57 -5.935; 1401 11.74 57 -9.735;
    1402 11.74 57 9.82; 1403 20.65 57 4.91; 1404 20.65 57 -5.935;
    1405 20.65 57 -9.735; 1406 20.65 57 9.82; 1407 27.77 57 4.91;
    1408 27.77 57 -5.935; 1409 27.77 57 -9.735; 1411 32.25 57 4.91;
    1412 32.25 57 -5.935; 1413 32.25 57 1.08; 1414 0 57 -2.4275;
    1415 32.25 57 -2.4275; 1416 24.92 57 4.91; 1417 24.92 57 9.82;
    1420 4.62 57 1.08; 1421 11.74 57 1.08; 1422 20.65 57 1.08; 1423 27.77 57 1.08;
    1424 4.62 57 -2.4275; 1425 11.74 57 -2.428; 1426 20.65 57 -2.428;
    1427 27.77 57 -2.428; 1428 2.31 57 -5.935; 1429 11.74 57 -7.835;
    1430 20.65 57 -7.835; 1431 30.01 57 -5.935; 1432 2.31 57 4.91;
    1433 11.74 57 7.365; 1434 20.65 57 7.365; 1435 30.01 57 4.91; 1436 0 60 4.91;
    1437 0 60 1.08; 1438 0 60 -5.935; 1439 4.62 60 4.91; 1440 4.62 60 -5.935;
    1441 4.62 60 -9.735; 1442 4.62 60 9.82; 1443 11.74 60 4.91;
    1444 11.74 60 -5.935; 1445 11.74 60 -9.735; 1446 11.74 60 9.82;
    1447 20.65 60 4.91; 1448 20.65 60 -5.935; 1449 20.65 60 -9.735;
    1450 20.65 60 9.82; 1451 27.77 60 4.91; 1452 27.77 60 -5.935;
    1453 27.77 60 -9.735; 1455 32.25 60 4.91; 1456 32.25 60 -5.935;
    1457 32.25 60 1.08; 1458 0 60 -2.4275; 1459 32.25 60 -2.4275;
    1460 24.92 60 4.91; 1461 24.92 60 9.82; 1464 4.62 60 1.08; 1465 11.74 60 1.08;
    1466 20.65 60 1.08; 1467 27.77 60 1.08; 1468 4.62 60 -2.4275;
    1469 11.74 60 -2.428; 1470 20.65 60 -2.428; 1471 27.77 60 -2.428;
    1472 2.31 60 -5.935; 1473 11.74 60 -7.835; 1474 20.65 60 -7.835;
    1475 30.01 60 -5.935; 1476 2.31 60 4.91; 1477 11.74 60 7.365;
    1478 20.65 60 7.365; 1479 30.01 60 4.91; 1480 0 63 4.91; 1481 0 63 1.08;
    1482 0 63 -5.935; 1483 4.62 63 4.91; 1484 4.62 63 -5.935; 1485 4.62 63 -9.735;
    1486 4.62 63 9.82; 1487 11.74 63 4.91; 1488 11.74 63 -5.935;
    1489 11.74 63 -9.735; 1490 11.74 63 9.82; 1491 20.65 63 4.91;
    1492 20.65 63 -5.935; 1493 20.65 63 -9.735; 1494 20.65 63 9.82;
    1495 27.77 63 4.91; 1496 27.77 63 -5.935; 1497 27.77 63 -9.735;
    1499 32.25 63 4.91; 1500 32.25 63 -5.935; 1501 32.25 63 1.08;
    1502 0 63 -2.4275; 1503 32.25 63 -2.4275; 1504 24.92 63 4.91;
    1505 24.92 63 9.82; 1508 4.62 63 1.08; 1509 11.74 63 1.08; 1510 20.65 63 1.08;
    1511 27.77 63 1.08; 1512 4.62 63 -2.4275; 1513 11.74 63 -2.428;
    1514 20.65 63 -2.428; 1515 27.77 63 -2.428; 1516 2.31 63 -5.935;
    1517 11.74 63 -7.835; 1518 20.65 63 -7.835; 1519 30.01 63 -5.935;
    1520 2.31 63 4.91; 1521 11.74 63 7.365; 1522 20.65 63 7.365;
    1523 30.01 63 4.91; 1524 0 66 4.91; 1525 0 66 1.08; 1526 0 66 -5.935;
    1527 4.62 66 4.91; 1528 4.62 66 -5.935; 1529 4.62 66 -9.735; 1530 4.62 66 9.82;
    1531 11.74 66 4.91; 1532 11.74 66 -5.935; 1533 11.74 66 -9.735;
    1534 11.74 66 9.82; 1535 20.65 66 4.91; 1536 20.65 66 -5.935;
    1537 20.65 66 -9.735; 1538 20.65 66 9.82; 1539 27.77 66 4.91;
    1540 27.77 66 -5.935; 1541 27.77 66 -9.735; 1543 32.25 66 4.91;
    1544 32.25 66 -5.935; 1545 32.25 66 1.08; 1546 0 66 -2.4275;
    1547 32.25 66 -2.4275; 1548 24.92 66 4.91; 1549 24.92 66 9.82;
    1552 4.62 66 1.08; 1553 11.74 66 1.08; 1554 20.65 66 1.08; 1555 27.77 66 1.08;
    1556 4.62 66 -2.4275; 1557 11.74 66 -2.428; 1558 20.65 66 -2.428;
    1559 27.77 66 -2.428; 1560 2.31 66 -5.935; 1561 11.74 66 -7.835;
    1562 20.65 66 -7.835; 1563 30.01 66 -5.935; 1564 2.31 66 4.91;
    1565 11.74 66 7.365; 1566 20.65 66 7.365; 1567 30.01 66 4.91; 1568 0 69 4.91;
    1569 0 69 1.08; 1570 0 69 -5.935; 1571 4.62 69 4.91; 1572 4.62 69 -5.935;
    1573 4.62 69 -9.735; 1574 4.62 69 9.82; 1575 11.74 69 4.91;
    1576 11.74 69 -5.935; 1577 11.74 69 -9.735; 1578 11.74 69 9.82;
    1579 20.65 69 4.91; 1580 20.65 69 -5.935; 1581 20.65 69 -9.735;
    1582 20.65 69 9.82; 1583 27.77 69 4.91; 1584 27.77 69 -5.935;
    1585 27.77 69 -9.735; 1587 32.25 69 4.91; 1588 32.25 69 -5.935;
    1589 32.25 69 1.08; 1590 0 69 -2.4275; 1591 32.25 69 -2.4275;
    1592 24.92 69 4.91; 1593 24.92 69 9.82; 1596 4.62 69 1.08; 1597 11.74 69 1.08;
    1598 20.65 69 1.08; 1599 27.77 69 1.08; 1600 4.62 69 -2.4275;
    1601 11.74 69 -2.428; 1602 20.65 69 -2.428; 1603 27.77 69 -2.428;
    1604 2.31 69 -5.935; 1605 11.74 69 -7.835; 1606 20.65 69 -7.835;
    1607 30.01 69 -5.935; 1608 2.31 69 4.91; 1609 11.74 69 7.365;
    1610 20.65 69 7.365; 1611 30.01 69 4.91; 1612 0 72 4.91; 1613 0 72 1.08;
    1614 0 72 -5.935; 1615 4.62 72 4.91; 1616 4.62 72 -5.935; 1617 4.62 72 -9.735;
    1618 4.62 72 9.82; 1619 11.74 72 4.91; 1620 11.74 72 -5.935;
    1621 11.74 72 -9.735; 1622 11.74 72 9.82; 1623 20.65 72 4.91;
    1624 20.65 72 -5.935; 1625 20.65 72 -9.735; 1626 20.65 72 9.82;
    1627 27.77 72 4.91; 1628 27.77 72 -5.935; 1629 27.77 72 -9.735;
    1631 32.25 72 4.91; 1632 32.25 72 -5.935; 1633 32.25 72 1.08;
    1634 0 72 -2.4275; 1635 32.25 72 -2.4275; 1636 24.92 72 4.91;
    1637 24.92 72 9.82; 1640 4.62 72 1.08; 1641 11.74 72 1.08; 1642 20.65 72 1.08;
    1643 27.77 72 1.08; 1644 4.62 72 -2.4275; 1645 11.74 72 -2.428;
    1646 20.65 72 -2.428; 1647 27.77 72 -2.428; 1648 2.31 72 -5.935;
    1649 11.74 72 -7.835; 1650 20.65 72 -7.835; 1651 30.01 72 -5.935;
    1652 2.31 72 4.91; 1653 11.74 72 7.365; 1654 20.65 72 7.365;
    1655 30.01 72 4.91; 1656 0 75 4.91; 1657 0 75 1.08; 1658 0 75 -5.935;
    1659 4.62 75 4.91; 1660 4.62 75 -5.935; 1661 4.62 75 -9.735; 1662 4.62 75 9.82;
    1663 11.74 75 4.91; 1664 11.74 75 -5.935; 1665 11.74 75 -9.735;
    1666 11.74 75 9.82; 1667 20.65 75 4.91; 1668 20.65 75 -5.935;
    1669 20.65 75 -9.735; 1670 20.65 75 9.82; 1671 27.77 75 4.91;
    1672 27.77 75 -5.935; 1673 27.77 75 -9.735; 1675 32.25 75 4.91;
    1676 32.25 75 -5.935; 1677 32.25 75 1.08; 1678 0 75 -2.4275;
    1679 32.25 75 -2.4275; 1680 24.92 75 4.91; 1681 24.92 75 9.82;
    1684 4.62 75 1.08; 1685 11.74 75 1.08; 1686 20.65 75 1.08; 1687 27.77 75 1.08;
    1688 4.62 75 -2.4275; 1689 11.74 75 -2.428; 1690 20.65 75 -2.428;
    1691 27.77 75 -2.428; 1692 2.31 75 -5.935; 1693 11.74 75 -7.835;
    1694 20.65 75 -7.835; 1695 30.01 75 -5.935; 1696 2.31 75 4.91;
    1697 11.74 75 7.365; 1698 20.65 75 7.365; 1699 30.01 75 4.91; 1700 0 78 4.91;
    1701 0 78 1.08; 1702 0 78 -5.935; 1703 4.62 78 4.91; 1704 4.62 78 -5.935;
    1705 4.62 78 -9.735; 1706 4.62 78 9.82; 1707 11.74 78 4.91;
    1708 11.74 78 -5.935; 1709 11.74 78 -9.735; 1710 11.74 78 9.82;
    1711 20.65 78 4.91; 1712 20.65 78 -5.935; 1713 20.65 78 -9.735;
    1714 20.65 78 9.82; 1715 27.77 78 4.91; 1716 27.77 78 -5.935;
    1717 27.77 78 -9.735; 1719 32.25 78 4.91; 1720 32.25 78 -5.935;
    1721 32.25 78 1.08; 1722 0 78 -2.4275; 1723 32.25 78 -2.4275;
    1724 24.92 78 4.91; 1725 24.92 78 9.82; 1728 4.62 78 1.08; 1729 11.74 78 1.08;
    1730 20.65 78 1.08; 1731 27.77 78 1.08; 1732 4.62 78 -2.4275;
    1733 11.74 78 -2.428; 1734 20.65 78 -2.428; 1735 27.77 78 -2.428;
    1736 2.31 78 -5.935; 1737 11.74 78 -7.835; 1738 20.65 78 -7.835;
    1739 30.01 78 -5.935; 1740 2.31 78 4.91; 1741 11.74 78 7.365;
    1742 20.65 78 7.365; 1743 30.01 78 4.91; 1744 0 81 4.91; 1745 0 81 1.08;
    1746 0 81 -5.935; 1747 4.62 81 4.91; 1748 4.62 81 -5.935; 1749 4.62 81 -9.735;
    1750 4.62 81 9.82; 1751 11.74 81 4.91; 1752 11.74 81 -5.935;
    1753 11.74 81 -9.735; 1754 11.74 81 9.82; 1755 20.65 81 4.91;
    1756 20.65 81 -5.935; 1757 20.65 81 -9.735; 1758 20.65 81 9.82;
    1759 27.77 81 4.91; 1760 27.77 81 -5.935; 1761 27.77 81 -9.735;
    1763 32.25 81 4.91; 1764 32.25 81 -5.935; 1765 32.25 81 1.08;
    1766 0 81 -2.4275; 1767 32.25 81 -2.4275; 1768 24.92 81 4.91;
    1769 24.92 81 9.82; 1772 4.62 81 1.08; 1773 11.74 81 1.08; 1774 20.65 81 1.08;
    1775 27.77 81 1.08; 1776 4.62 81 -2.4275; 1777 11.74 81 -2.428;
    1778 20.65 81 -2.428; 1779 27.77 81 -2.428; 1780 2.31 81 -5.935;
    1781 11.74 81 -7.835; 1782 20.65 81 -7.835; 1783 30.01 81 -5.935;
    1784 2.31 81 4.91; 1785 11.74 81 7.365; 1786 20.65 81 7.365;
    1787 30.01 81 4.91; 1788 0 84 4.91; 1789 0 84 1.08; 1790 0 84 -5.935;
    1791 4.62 84 4.91; 1792 4.62 84 -5.935; 1793 4.62 84 -9.735; 1794 4.62 84 9.82;
    1795 11.74 84 4.91; 1796 11.74 84 -5.935; 1797 11.74 84 -9.735;
    1798 11.74 84 9.82; 1799 20.65 84 4.91; 1800 20.65 84 -5.935;
    1801 20.65 84 -9.735; 1802 20.65 84 9.82; 1803 27.77 84 4.91;
    1804 27.77 84 -5.935; 1805 27.77 84 -9.735; 1807 32.25 84 4.91;
    1808 32.25 84 -5.935; 1809 32.25 84 1.08; 1810 0 84 -2.4275;
    1811 32.25 84 -2.4275; 1812 24.92 84 4.91; 1813 24.92 84 9.82;
    1816 4.62 84 1.08; 1817 11.74 84 1.08; 1818 20.65 84 1.08; 1819 27.77 84 1.08;
    1820 4.62 84 -2.4275; 1821 11.74 84 -2.428; 1822 20.65 84 -2.428;
    1823 27.77 84 -2.428; 1824 2.31 84 -5.935; 1825 11.74 84 -7.835;
    1826 20.65 84 -7.835; 1827 30.01 84 -5.935; 1828 2.31 84 4.91;
    1829 11.74 84 7.365; 1830 20.65 84 7.365; 1831 30.01 84 4.91; 1832 0 87 4.91;
    1833 0 87 1.08; 1834 0 87 -5.935; 1835 4.62 87 4.91; 1836 4.62 87 -5.935;
    1837 4.62 87 -9.735; 1838 4.62 87 9.82; 1839 11.74 87 4.91;
    1840 11.74 87 -5.935; 1841 11.74 87 -9.735; 1842 11.74 87 9.82;
    1843 20.65 87 4.91; 1844 20.65 87 -5.935; 1845 20.65 87 -9.735;
    1846 20.65 87 9.82; 1847 27.77 87 4.91; 1848 27.77 87 -5.935;
    1849 27.77 87 -9.735; 1851 32.25 87 4.91; 1852 32.25 87 -5.935;
    1853 32.25 87 1.08; 1854 0 87 -2.4275; 1855 32.25 87 -2.4275;
    1856 24.92 87 4.91; 1857 24.92 87 9.82; 1860 4.62 87 1.08; 1861 11.74 87 1.08;
    1862 20.65 87 1.08; 1863 27.77 87 1.08; 1864 4.62 87 -2.4275;
    1865 11.74 87 -2.428; 1866 20.65 87 -2.428; 1867 27.77 87 -2.428;
    1868 2.31 87 -5.935; 1869 11.74 87 -7.835; 1870 20.65 87 -7.835;
    1871 30.01 87 -5.935; 1872 2.31 87 4.91; 1873 11.74 87 7.365;
    1874 20.65 87 7.365; 1875 30.01 87 4.91; 1876 0 90 4.91; 1877 0 90 1.08;
    1878 0 90 -5.935; 1879 4.62 90 4.91; 1880 4.62 90 -5.935; 1881 4.62 90 -9.735;
    1882 4.62 90 9.82; 1883 11.74 90 4.91; 1884 11.74 90 -5.935;
    1885 11.74 90 -9.735; 1886 11.74 90 9.82; 1887 20.65 90 4.91;
    1888 20.65 90 -5.935; 1889 20.65 90 -9.735; 1890 20.65 90 9.82;
    1891 27.77 90 4.91; 1892 27.77 90 -5.935; 1893 27.77 90 -9.735;
    1895 32.25 90 4.91; 1896 32.25 90 -5.935; 1897 32.25 90 1.08;
    1898 0 90 -2.4275; 1899 32.25 90 -2.4275; 1900 24.92 90 4.91;
    1901 24.92 90 9.82; 1904 4.62 90 1.08; 1905 11.74 90 1.08; 1906 20.65 90 1.08;
    1907 27.77 90 1.08; 1908 4.62 90 -2.4275; 1909 11.74 90 -2.428;
    1910 20.65 90 -2.428; 1911 27.77 90 -2.428; 1912 2.31 90 -5.935;
    1913 11.74 90 -7.835; 1914 20.65 90 -7.835; 1915 30.01 90 -5.935;
    1916 2.31 90 4.91; 1917 11.74 90 7.365; 1918 20.65 90 7.365;
    1919 30.01 90 4.91; 1920 4.62 -3 1.08; 1921 11.74 -3 1.08; 1922 20.65 -3 1.08;
    1923 27.77 -3 1.08; 1924 4.62 -3 -2.4275; 1925 11.74 -3 -2.428;
    1926 20.65 -3 -2.428; 1927 27.77 -3 -2.428; 1928 26.345 0 4.91;
    1929 26.345 0 9.82; 1930 26.345 0 7.365; 2021 26.345 -3 7.365;
    2022 26.345 -3 4.91; 2023 26.345 -3 9.82; 2024 27.77 -3 7.365;
    2025 27.77 0 9.82; 2026 24.92 0 7.365; 2027 27.77 3 7.365; 2028 26.345 3 4.91;
    2029 26.345 3 9.82; 2030 26.345 3 7.365; 2031 27.77 3 9.82; 2032 24.92 3 7.365;
    2033 27.77 6 7.365; 2034 26.345 6 4.91; 2035 26.345 6 9.82;
    2036 26.345 6 7.365; 2037 27.77 6 9.82; 2038 24.92 6 7.365; 2039 27.77 9 7.365;
    2040 26.345 9 4.91; 2041 26.345 9 9.82; 2042 26.345 9 7.365; 2043 27.77 9 9.82;
    2044 24.92 9 7.365; 2045 27.77 12 7.365; 2046 26.345 12 4.91;
    2047 26.345 12 9.82; 2048 26.345 12 7.365; 2049 27.77 12 9.82;
    2050 24.92 12 7.365; 2051 27.77 15 7.365; 2052 26.345 15 4.91;
    2053 26.345 15 9.82; 2054 26.345 15 7.365; 2055 27.77 15 9.82;
    2056 24.92 15 7.365; 2057 27.77 18 7.365; 2058 26.345 18 4.91;
    2059 26.345 18 9.82; 2060 26.345 18 7.365; 2061 27.77 18 9.82;
    2062 24.92 18 7.365; 2063 27.77 21 7.365; 2064 26.345 21 4.91;
    2065 26.345 21 9.82; 2066 26.345 21 7.365; 2067 27.77 21 9.82;
    2068 24.92 21 7.365; 2069 27.77 24 7.365; 2070 26.345 24 4.91;
    2071 26.345 24 9.82; 2072 26.345 24 7.365; 2073 27.77 24 9.82;
    2074 24.92 24 7.365; 2075 27.77 27 7.365; 2076 26.345 27 4.91;
    2077 26.345 27 9.82; 2078 26.345 27 7.365; 2079 27.77 27 9.82;
    2080 24.92 27 7.365; 2081 27.77 30 7.365; 2082 26.345 30 4.91;
    2083 26.345 30 9.82; 2084 26.345 30 7.365; 2085 27.77 30 9.82;
    2086 24.92 30 7.365; 2087 27.77 33 7.365; 2088 26.345 33 4.91;
    2089 26.345 33 9.82; 2090 26.345 33 7.365; 2091 27.77 33 9.82;
    2092 24.92 33 7.365; 2093 27.77 36 7.365; 2094 26.345 36 4.91;
    2095 26.345 36 9.82; 2096 26.345 36 7.365; 2097 27.77 36 9.82;
    2098 24.92 36 7.365; 2099 27.77 39 7.365; 2100 26.345 39 4.91;
    2101 26.345 39 9.82; 2102 26.345 39 7.365; 2103 27.77 39 9.82;
    2104 24.92 39 7.365; 2105 27.77 42 7.365; 2106 26.345 42 4.91;
    2107 26.345 42 9.82; 2108 26.345 42 7.365; 2109 27.77 42 9.82;
    2110 24.92 42 7.365; 2111 27.77 45 7.365; 2112 26.345 45 4.91;
    2113 26.345 45 9.82; 2114 26.345 45 7.365; 2115 27.77 45 9.82;
    2116 24.92 45 7.365; 2117 27.77 48 7.365; 2118 26.345 48 4.91;
    2119 26.345 48 9.82; 2120 26.345 48 7.365; 2121 27.77 48 9.82;
    2122 24.92 48 7.365; 2123 27.77 51 7.365; 2124 26.345 51 4.91;
    2125 26.345 51 9.82; 2126 26.345 51 7.365; 2127 27.77 51 9.82;
    2128 24.92 51 7.365; 2129 27.77 54 7.365; 2130 26.345 54 4.91;
    2131 26.345 54 9.82; 2132 26.345 54 7.365; 2133 27.77 54 9.82;
    2134 24.92 54 7.365; 2135 27.77 57 7.365; 2136 26.345 57 4.91;
    2137 26.345 57 9.82; 2138 26.345 57 7.365; 2139 27.77 57 9.82;
    2140 24.92 57 7.365; 2141 27.77 60 7.365; 2142 26.345 60 4.91;
    2143 26.345 60 9.82; 2144 26.345 60 7.365; 2145 27.77 60 9.82;
    2146 24.92 60 7.365; 2147 27.77 63 7.365; 2148 26.345 63 4.91;
    2149 26.345 63 9.82; 2150 26.345 63 7.365; 2151 27.77 63 9.82;
    2152 24.92 63 7.365; 2153 27.77 66 7.365; 2154 26.345 66 4.91;
    2155 26.345 66 9.82; 2156 26.345 66 7.365; 2157 27.77 66 9.82;
    2158 24.92 66 7.365; 2159 27.77 69 7.365; 2160 26.345 69 4.91;
    2161 26.345 69 9.82; 2162 26.345 69 7.365; 2163 27.77 69 9.82;
    2164 24.92 69 7.365; 2165 27.77 72 7.365; 2166 26.345 72 4.91;
    2167 26.345 72 9.82; 2168 26.345 72 7.365; 2169 27.77 72 9.82;
    2170 24.92 72 7.365; 2171 27.77 75 7.365; 2172 26.345 75 4.91;
    2173 26.345 75 9.82; 2174 26.345 75 7.365; 2175 27.77 75 9.82;
    2176 24.92 75 7.365; 2177 27.77 78 7.365; 2178 26.345 78 4.91;
    2179 26.345 78 9.82; 2180 26.345 78 7.365; 2181 27.77 78 9.82;
    2182 24.92 78 7.365; 2183 27.77 81 7.365; 2184 26.345 81 4.91;
    2185 26.345 81 9.82; 2186 26.345 81 7.365; 2187 27.77 81 9.82;
    2188 24.92 81 7.365; 2189 27.77 84 7.365; 2190 26.345 84 4.91;
    2191 26.345 84 9.82; 2192 26.345 84 7.365; 2193 27.77 84 9.82;
    2194 24.92 84 7.365; 2195 27.77 87 7.365; 2196 26.345 87 4.91;
    2197 26.345 87 9.82; 2198 26.345 87 7.365; 2199 27.77 87 9.82;
    2200 24.92 87 7.365; 2201 27.77 90 7.365; 2202 26.345 90 4.91;
    2203 26.345 90 9.82; 2204 26.345 90 7.365; 2205 27.77 90 9.82;
    2206 24.92 90 7.365;
    MEMBER INCIDENCES
    6 8 30; 7 9 31; 18 20 42; 23 7 8; 24 8 12; 26 11 15; 28 16 20; 29 20 19;
    31 23 47; 34 6 9; 35 9 13; 37 10 14; 39 17 53; 42 2 56; 43 3 46; 44 46 1;
    45 47 22; 46 46 60; 47 7 60; 48 11 61; 49 15 62; 50 19 63; 51 7 11; 52 15 19;
    53 6 10; 54 14 52; 55 3 49; 56 1 48; 57 22 50; 58 23 51; 59 49 48; 60 51 50;
    65 52 2026; 66 56 57; 67 56 6; 68 57 10; 69 57 58; 70 58 14; 71 58 59;
    72 59 18; 73 59 24; 74 60 61; 75 60 56; 76 61 57; 77 61 62; 78 62 58; 79 62 63;
    80 63 59; 81 63 47; 872 464 552; 873 465 553; 874 466 554; 875 467 555;
    876 468 556; 877 469 557; 878 470 558; 879 471 559; 880 565 8; 881 566 9;
    882 577 20; 884 564 565; 885 565 569; 886 568 572; 887 573 577; 888 577 576;
    889 580 583; 890 563 566; 891 566 570; 892 567 571; 893 574 589; 895 561 592;
    896 562 582; 897 582 560; 898 583 579; 899 582 596; 900 564 596; 901 568 597;
    902 572 598; 903 576 599; 904 564 568; 905 572 576; 906 563 567; 907 571 588;
    908 562 585; 909 560 584; 910 579 586; 911 580 587; 912 585 584; 913 587 586;
    918 588 2032; 919 592 593; 920 592 563; 921 593 567; 922 593 594; 923 594 571;
    924 594 595; 925 595 575; 926 595 581; 927 596 597; 928 596 592; 929 597 593;
    930 597 598; 931 598 594; 932 598 599; 933 599 595; 934 599 583; 935 600 464;
    936 601 465; 937 602 466; 938 603 467; 939 604 468; 940 605 469; 941 606 470;
    942 607 471; 943 613 565; 944 614 566; 945 625 577; 947 612 613; 948 613 617;
    949 616 620; 950 621 625; 951 625 624; 952 628 631; 953 611 614; 954 614 618;
    955 615 619; 956 622 637; 958 609 640; 959 610 630; 960 630 608; 961 631 627;
    962 630 644; 963 612 644; 964 616 645; 965 620 646; 966 624 647; 967 612 616;
    968 620 624; 969 611 615; 970 619 636; 971 610 633; 972 608 632; 973 627 634;
    974 628 635; 975 633 632; 976 635 634; 981 636 2038; 982 640 641; 983 640 611;
    984 641 615; 985 641 642; 986 642 619; 987 642 643; 988 643 623; 989 643 629;
    990 644 645; 991 644 640; 992 645 641; 993 645 646; 994 646 642; 995 646 647;
    996 647 643; 997 647 631; 998 648 600; 999 649 601; 1000 650 602; 1001 651 603;
    1002 652 604; 1003 653 605; 1004 654 606; 1005 655 607; 1006 661 613;
    1007 662 614; 1008 673 625; 1010 660 661; 1011 661 665; 1012 664 668;
    1013 669 673; 1014 673 672; 1015 676 679; 1016 659 662; 1017 662 666;
    1018 663 667; 1019 670 685; 1021 657 688; 1022 658 678; 1023 678 656;
    1024 679 675; 1025 678 692; 1026 660 692; 1027 664 693; 1028 668 694;
    1029 672 695; 1030 660 664; 1031 668 672; 1032 659 663; 1033 667 684;
    1034 658 681; 1035 656 680; 1036 675 682; 1037 676 683; 1038 681 680;
    1039 683 682; 1044 684 2044; 1045 688 689; 1046 688 659; 1047 689 663;
    1048 689 690; 1049 690 667; 1050 690 691; 1051 691 671; 1052 691 677;
    1053 692 693; 1054 692 688; 1055 693 689; 1056 693 694; 1057 694 690;
    1058 694 695; 1059 695 691; 1060 695 679; 1061 696 648; 1062 697 649;
    1063 698 650; 1064 699 651; 1065 700 652; 1066 701 653; 1067 702 654;
    1068 703 655; 1069 709 661; 1070 710 662; 1071 721 673; 1073 708 709;
    1074 709 713; 1075 712 716; 1076 717 721; 1077 721 720; 1078 724 727;
    1079 707 710; 1080 710 714; 1081 711 715; 1082 718 733; 1084 705 736;
    1085 706 726; 1086 726 704; 1087 727 723; 1088 726 740; 1089 708 740;
    1090 712 741; 1091 716 742; 1092 720 743; 1093 708 712; 1094 716 720;
    1095 707 711; 1096 715 732; 1097 706 729; 1098 704 728; 1099 723 730;
    1100 724 731; 1101 729 728; 1102 731 730; 1107 732 2050; 1108 736 737;
    1109 736 707; 1110 737 711; 1111 737 738; 1112 738 715; 1113 738 739;
    1114 739 719; 1115 739 725; 1116 740 741; 1117 740 736; 1118 741 737;
    1119 741 742; 1120 742 738; 1121 742 743; 1122 743 739; 1123 743 727;
    1124 744 696; 1125 745 697; 1126 746 698; 1127 747 699; 1128 748 700;
    1129 749 701; 1130 750 702; 1131 751 703; 1132 757 709; 1133 758 710;
    1134 769 721; 1136 756 757; 1137 757 761; 1138 760 764; 1139 765 769;
    1140 769 768; 1141 772 775; 1142 755 758; 1143 758 762; 1144 759 763;
    1145 766 781; 1147 753 784; 1148 754 774; 1149 774 752; 1150 775 771;
    1151 774 788; 1152 756 788; 1153 760 789; 1154 764 790; 1155 768 791;
    1156 756 760; 1157 764 768; 1158 755 759; 1159 763 780; 1160 754 777;
    1161 752 776; 1162 771 778; 1163 772 779; 1164 777 776; 1165 779 778;
    1170 780 2056; 1171 784 785; 1172 784 755; 1173 785 759; 1174 785 786;
    1175 786 763; 1176 786 787; 1177 787 767; 1178 787 773; 1179 788 789;
    1180 788 784; 1181 789 785; 1182 789 790; 1183 790 786; 1184 790 791;
    1185 791 787; 1186 791 775; 1187 792 744; 1188 793 745; 1189 794 746;
    1190 795 747; 1191 796 748; 1192 797 749; 1193 798 750; 1194 799 751;
    1195 805 757; 1196 806 758; 1197 817 769; 1199 804 805; 1200 805 809;
    1201 808 812; 1202 813 817; 1203 817 816; 1204 820 823; 1205 803 806;
    1206 806 810; 1207 807 811; 1208 814 829; 1210 801 832; 1211 802 822;
    1212 822 800; 1213 823 819; 1214 822 836; 1215 804 836; 1216 808 837;
    1217 812 838; 1218 816 839; 1219 804 808; 1220 812 816; 1221 803 807;
    1222 811 828; 1223 802 825; 1224 800 824; 1225 819 826; 1226 820 827;
    1227 825 824; 1228 827 826; 1233 828 2062; 1234 832 833; 1235 832 803;
    1236 833 807; 1237 833 834; 1238 834 811; 1239 834 835; 1240 835 815;
    1241 835 821; 1242 836 837; 1243 836 832; 1244 837 833; 1245 837 838;
    1246 838 834; 1247 838 839; 1248 839 835; 1249 839 823; 1250 840 792;
    1251 841 793; 1252 842 794; 1253 843 795; 1254 844 796; 1255 845 797;
    1256 846 798; 1257 847 799; 1258 853 805; 1259 854 806; 1260 865 817;
    1262 852 853; 1263 853 857; 1264 856 860; 1265 861 865; 1266 865 864;
    1267 868 871; 1268 851 854; 1269 854 858; 1270 855 859; 1271 862 877;
    1273 849 880; 1274 850 870; 1275 870 848; 1276 871 867; 1277 870 884;
    1278 852 884; 1279 856 885; 1280 860 886; 1281 864 887; 1282 852 856;
    1283 860 864; 1284 851 855; 1285 859 876; 1286 850 873; 1287 848 872;
    1288 867 874; 1289 868 875; 1290 873 872; 1291 875 874; 1296 876 2068;
    1297 880 881; 1298 880 851; 1299 881 855; 1300 881 882; 1301 882 859;
    1302 882 883; 1303 883 863; 1304 883 869; 1305 884 885; 1306 884 880;
    1307 885 881; 1308 885 886; 1309 886 882; 1310 886 887; 1311 887 883;
    1312 887 871; 1313 888 840; 1314 889 841; 1315 890 842; 1316 891 843;
    1317 892 844; 1318 893 845; 1319 894 846; 1320 895 847; 1321 901 853;
    1322 902 854; 1323 913 865; 1325 900 901; 1326 901 905; 1327 904 908;
    1328 909 913; 1329 913 912; 1330 916 919; 1331 899 902; 1332 902 906;
    1333 903 907; 1334 910 925; 1336 897 928; 1337 898 918; 1338 918 896;
    1339 919 915; 1340 918 932; 1341 900 932; 1342 904 933; 1343 908 934;
    1344 912 935; 1345 900 904; 1346 908 912; 1347 899 903; 1348 907 924;
    1349 898 921; 1350 896 920; 1351 915 922; 1352 916 923; 1353 921 920;
    1354 923 922; 1359 924 2074; 1360 928 929; 1361 928 899; 1362 929 903;
    1363 929 930; 1364 930 907; 1365 930 931; 1366 931 911; 1367 931 917;
    1368 932 933; 1369 932 928; 1370 933 929; 1371 933 934; 1372 934 930;
    1373 934 935; 1374 935 931; 1375 935 919; 1376 936 888; 1377 937 889;
    1378 938 890; 1379 939 891; 1380 940 892; 1381 941 893; 1382 942 894;
    1383 943 895; 1384 949 901; 1385 950 902; 1386 961 913; 1388 948 949;
    1389 949 953; 1390 952 956; 1391 957 961; 1392 961 960; 1393 964 967;
    1394 947 950; 1395 950 954; 1396 951 955; 1397 958 973; 1399 945 976;
    1400 946 966; 1401 966 944; 1402 967 963; 1403 966 980; 1404 948 980;
    1405 952 981; 1406 956 982; 1407 960 983; 1408 948 952; 1409 956 960;
    1410 947 951; 1411 955 972; 1412 946 969; 1413 944 968; 1414 963 970;
    1415 964 971; 1416 969 968; 1417 971 970; 1422 972 2080; 1423 976 977;
    1424 976 947; 1425 977 951; 1426 977 978; 1427 978 955; 1428 978 979;
    1429 979 959; 1430 979 965; 1431 980 981; 1432 980 976; 1433 981 977;
    1434 981 982; 1435 982 978; 1436 982 983; 1437 983 979; 1438 983 967;
    1439 984 936; 1440 985 937; 1441 986 938; 1442 987 939; 1443 988 940;
    1444 989 941; 1445 990 942; 1446 991 943; 1447 997 949; 1448 998 950;
    1449 1009 961; 1451 996 997; 1452 997 1001; 1453 1000 1004; 1454 1005 1009;
    1455 1009 1008; 1456 1012 1015; 1457 995 998; 1458 998 1002; 1459 999 1003;
    1460 1006 1021; 1462 993 1024; 1463 994 1014; 1464 1014 992; 1465 1015 1011;
    1466 1014 1028; 1467 996 1028; 1468 1000 1029; 1469 1004 1030; 1470 1008 1031;
    1471 996 1000; 1472 1004 1008; 1473 995 999; 1474 1003 1020; 1475 994 1017;
    1476 992 1016; 1477 1011 1018; 1478 1012 1019; 1479 1017 1016; 1480 1019 1018;
    1485 1020 2086; 1486 1024 1025; 1487 1024 995; 1488 1025 999; 1489 1025 1026;
    1490 1026 1003; 1491 1026 1027; 1492 1027 1007; 1493 1027 1013; 1494 1028 1029;
    1495 1028 1024; 1496 1029 1025; 1497 1029 1030; 1498 1030 1026; 1499 1030 1031;
    1500 1031 1027; 1501 1031 1015; 1502 1032 984; 1503 1033 985; 1504 1034 986;
    1505 1035 987; 1506 1036 988; 1507 1037 989; 1508 1038 990; 1509 1039 991;
    1510 3 7; 1511 1 6; 1512 12 11; 1513 16 15; 1514 14 17; 1515 10 13; 1516 19 23;
    1517 18 22; 1518 562 564; 1519 560 563; 1520 569 568; 1521 573 572;
    1522 571 574; 1523 567 570; 1524 576 580; 1525 575 579; 1526 610 612;
    1527 608 611; 1528 617 616; 1529 621 620; 1530 619 622; 1531 615 618;
    1532 624 628; 1533 623 627; 1534 658 660; 1535 656 659; 1536 665 664;
    1537 669 668; 1538 667 670; 1539 663 666; 1540 672 676; 1541 671 675;
    1542 706 708; 1543 704 707; 1544 713 712; 1545 717 716; 1546 715 718;
    1547 711 714; 1548 720 724; 1549 719 723; 1550 754 756; 1551 752 755;
    1552 761 760; 1553 765 764; 1554 763 766; 1555 759 762; 1556 768 772;
    1557 767 771; 1558 802 804; 1559 800 803; 1560 809 808; 1561 813 812;
    1562 811 814; 1563 807 810; 1564 816 820; 1565 815 819; 1566 850 852;
    1567 848 851; 1568 857 856; 1569 861 860; 1570 859 862; 1571 855 858;
    1572 864 868; 1573 863 867; 1574 898 900; 1575 896 899; 1576 905 904;
    1577 909 908; 1578 907 910; 1579 903 906; 1580 912 916; 1581 911 915;
    1582 946 948; 1583 944 947; 1584 953 952; 1585 957 956; 1586 955 958;
    1587 951 954; 1588 960 964; 1589 959 963; 1590 994 996; 1591 992 995;
    1592 1001 1000; 1593 1005 1004; 1594 1003 1006; 1595 999 1002; 1596 1008 1012;
    1597 1007 1011; 1598 1045 997; 1599 1046 998; 1600 1057 1009; 1602 1044 1045;
    1603 1045 1049; 1604 1048 1052; 1605 1053 1057; 1606 1057 1056; 1607 1060 1063;
    1608 1043 1046; 1609 1046 1050; 1610 1047 1051; 1611 1054 1065; 1613 1041 1068;
    1614 1042 1062; 1615 1062 1040; 1616 1063 1059; 1617 1062 1072; 1618 1044 1072;
    1619 1048 1073; 1620 1052 1074; 1621 1056 1075; 1622 1044 1048; 1623 1052 1056;
    1624 1043 1047; 1625 1051 1064; 1630 1064 2092; 1631 1068 1069; 1632 1068 1043;
    1633 1069 1047; 1634 1069 1070; 1635 1070 1051; 1636 1070 1071; 1637 1071 1055;
    1638 1071 1061; 1639 1072 1073; 1640 1072 1068; 1641 1073 1069; 1642 1073 1074;
    1643 1074 1070; 1644 1074 1075; 1645 1075 1071; 1646 1075 1063; 1647 1076 1032;
    1648 1077 1033; 1649 1078 1034; 1650 1079 1035; 1651 1080 1036; 1652 1081 1037;
    1653 1082 1038; 1654 1083 1039; 1655 1042 1044; 1656 1040 1043; 1657 1049 1048;
    1658 1053 1052; 1659 1051 1054; 1660 1047 1050; 1661 1056 1060; 1662 1055 1059;
    1663 1089 1045; 1664 1090 1046; 1665 1101 1057; 1667 1088 1089; 1668 1089 1093;
    1669 1092 1096; 1670 1097 1101; 1671 1101 1100; 1672 1104 1107; 1673 1087 1090;
    1674 1090 1094; 1675 1091 1095; 1676 1098 1109; 1678 1085 1112; 1679 1086 1106;
    1680 1106 1084; 1681 1107 1103; 1682 1106 1116; 1683 1088 1116; 1684 1092 1117;
    1685 1096 1118; 1686 1100 1119; 1687 1088 1092; 1688 1096 1100; 1689 1087 1091;
    1690 1095 1108; 1695 1108 2098; 1696 1112 1113; 1697 1112 1087; 1698 1113 1091;
    1699 1113 1114; 1700 1114 1095; 1701 1114 1115; 1702 1115 1099; 1703 1115 1105;
    1704 1116 1117; 1705 1116 1112; 1706 1117 1113; 1707 1117 1118; 1708 1118 1114;
    1709 1118 1119; 1710 1119 1115; 1711 1119 1107; 1712 1120 1076; 1713 1121 1077;
    1714 1122 1078; 1715 1123 1079; 1716 1124 1080; 1717 1125 1081; 1718 1126 1082;
    1719 1127 1083; 1720 1086 1088; 1721 1084 1087; 1722 1093 1092; 1723 1097 1096;
    1724 1095 1098; 1725 1091 1094; 1726 1100 1104; 1727 1099 1103; 1728 1133 1089;
    1729 1134 1090; 1730 1145 1101; 1732 1132 1133; 1733 1133 1137; 1734 1136 1140;
    1735 1141 1145; 1736 1145 1144; 1737 1148 1151; 1738 1131 1134; 1739 1134 1138;
    1740 1135 1139; 1741 1142 1153; 1743 1129 1156; 1744 1130 1150; 1745 1150 1128;
    1746 1151 1147; 1747 1150 1160; 1748 1132 1160; 1749 1136 1161; 1750 1140 1162;
    1751 1144 1163; 1752 1132 1136; 1753 1140 1144; 1754 1131 1135; 1755 1139 1152;
    1760 1152 2104; 1761 1156 1157; 1762 1156 1131; 1763 1157 1135; 1764 1157 1158;
    1765 1158 1139; 1766 1158 1159; 1767 1159 1143; 1768 1159 1149; 1769 1160 1161;
    1770 1160 1156; 1771 1161 1157; 1772 1161 1162; 1773 1162 1158; 1774 1162 1163;
    1775 1163 1159; 1776 1163 1151; 1777 1164 1120; 1778 1165 1121; 1779 1166 1122;
    1780 1167 1123; 1781 1168 1124; 1782 1169 1125; 1783 1170 1126; 1784 1171 1127;
    1785 1130 1132; 1786 1128 1131; 1787 1137 1136; 1788 1141 1140; 1789 1139 1142;
    1790 1135 1138; 1791 1144 1148; 1792 1143 1147; 1793 1177 1133; 1794 1178 1134;
    1795 1189 1145; 1797 1176 1177; 1798 1177 1181; 1799 1180 1184; 1800 1185 1189;
    1801 1189 1188; 1802 1192 1195; 1803 1175 1178; 1804 1178 1182; 1805 1179 1183;
    1806 1186 1197; 1808 1173 1200; 1809 1174 1194; 1810 1194 1172; 1811 1195 1191;
    1812 1194 1204; 1813 1176 1204; 1814 1180 1205; 1815 1184 1206; 1816 1188 1207;
    1817 1176 1180; 1818 1184 1188; 1819 1175 1179; 1820 1183 1196; 1825 1196 2110;
    1826 1200 1201; 1827 1200 1175; 1828 1201 1179; 1829 1201 1202; 1830 1202 1183;
    1831 1202 1203; 1832 1203 1187; 1833 1203 1193; 1834 1204 1205; 1835 1204 1200;
    1836 1205 1201; 1837 1205 1206; 1838 1206 1202; 1839 1206 1207; 1840 1207 1203;
    1841 1207 1195; 1842 1208 1164; 1843 1209 1165; 1844 1210 1166; 1845 1211 1167;
    1846 1212 1168; 1847 1213 1169; 1848 1214 1170; 1849 1215 1171; 1850 1174 1176;
    1851 1172 1175; 1852 1181 1180; 1853 1185 1184; 1854 1183 1186; 1855 1179 1182;
    1856 1188 1192; 1857 1187 1191; 1858 1221 1177; 1859 1222 1178; 1860 1233 1189;
    1862 1220 1221; 1863 1221 1225; 1864 1224 1228; 1865 1229 1233; 1866 1233 1232;
    1867 1236 1239; 1868 1219 1222; 1869 1222 1226; 1870 1223 1227; 1871 1230 1241;
    1873 1217 1244; 1874 1218 1238; 1875 1238 1216; 1876 1239 1235; 1877 1238 1248;
    1878 1220 1248; 1879 1224 1249; 1880 1228 1250; 1881 1232 1251; 1882 1220 1224;
    1883 1228 1232; 1884 1219 1223; 1885 1227 1240; 1890 1240 2116; 1891 1244 1245;
    1892 1244 1219; 1893 1245 1223; 1894 1245 1246; 1895 1246 1227; 1896 1246 1247;
    1897 1247 1231; 1898 1247 1237; 1899 1248 1249; 1900 1248 1244; 1901 1249 1245;
    1902 1249 1250; 1903 1250 1246; 1904 1250 1251; 1905 1251 1247; 1906 1251 1239;
    1907 1252 1208; 1908 1253 1209; 1909 1254 1210; 1910 1255 1211; 1911 1256 1212;
    1912 1257 1213; 1913 1258 1214; 1914 1259 1215; 1915 1218 1220; 1916 1216 1219;
    1917 1225 1224; 1918 1229 1228; 1919 1227 1230; 1920 1223 1226; 1921 1232 1236;
    1922 1231 1235; 1923 1265 1221; 1924 1266 1222; 1925 1277 1233; 1927 1264 1265;
    1928 1265 1269; 1929 1268 1272; 1930 1273 1277; 1931 1277 1276; 1932 1280 1283;
    1933 1263 1266; 1934 1266 1270; 1935 1267 1271; 1936 1274 1285; 1938 1261 1288;
    1939 1262 1282; 1940 1282 1260; 1941 1283 1279; 1942 1282 1292; 1943 1264 1292;
    1944 1268 1293; 1945 1272 1294; 1946 1276 1295; 1947 1264 1268; 1948 1272 1276;
    1949 1263 1267; 1950 1271 1284; 1955 1284 2122; 1956 1288 1289; 1957 1288 1263;
    1958 1289 1267; 1959 1289 1290; 1960 1290 1271; 1961 1290 1291; 1962 1291 1275;
    1963 1291 1281; 1964 1292 1293; 1965 1292 1288; 1966 1293 1289; 1967 1293 1294;
    1968 1294 1290; 1969 1294 1295; 1970 1295 1291; 1971 1295 1283; 1972 1296 1252;
    1973 1297 1253; 1974 1298 1254; 1975 1299 1255; 1976 1300 1256; 1977 1301 1257;
    1978 1302 1258; 1979 1303 1259; 1980 1262 1264; 1981 1260 1263; 1982 1269 1268;
    1983 1273 1272; 1984 1271 1274; 1985 1267 1270; 1986 1276 1280; 1987 1275 1279;
    1988 1309 1265; 1989 1310 1266; 1990 1321 1277; 1992 1308 1309; 1993 1309 1313;
    1994 1312 1316; 1995 1317 1321; 1996 1321 1320; 1997 1324 1327; 1998 1307 1310;
    1999 1310 1314; 2000 1311 1315; 2001 1318 1329; 2003 1305 1332; 2004 1306 1326;
    2005 1326 1304; 2006 1327 1323; 2007 1326 1336; 2008 1308 1336; 2009 1312 1337;
    2010 1316 1338; 2011 1320 1339; 2012 1308 1312; 2013 1316 1320; 2014 1307 1311;
    2015 1315 1328; 2020 1328 2128; 2021 1332 1333; 2022 1332 1307; 2023 1333 1311;
    2024 1333 1334; 2025 1334 1315; 2026 1334 1335; 2027 1335 1319; 2028 1335 1325;
    2029 1336 1337; 2030 1336 1332; 2031 1337 1333; 2032 1337 1338; 2033 1338 1334;
    2034 1338 1339; 2035 1339 1335; 2036 1339 1327; 2037 1340 1296; 2038 1341 1297;
    2039 1342 1298; 2040 1343 1299; 2041 1344 1300; 2042 1345 1301; 2043 1346 1302;
    2044 1347 1303; 2045 1306 1308; 2046 1304 1307; 2047 1313 1312; 2048 1317 1316;
    2049 1315 1318; 2050 1311 1314; 2051 1320 1324; 2052 1319 1323; 2053 1353 1309;
    2054 1354 1310; 2055 1365 1321; 2057 1352 1353; 2058 1353 1357; 2059 1356 1360;
    2060 1361 1365; 2061 1365 1364; 2062 1368 1371; 2063 1351 1354; 2064 1354 1358;
    2065 1355 1359; 2066 1362 1373; 2068 1349 1376; 2069 1350 1370; 2070 1370 1348;
    2071 1371 1367; 2072 1370 1380; 2073 1352 1380; 2074 1356 1381; 2075 1360 1382;
    2076 1364 1383; 2077 1352 1356; 2078 1360 1364; 2079 1351 1355; 2080 1359 1372;
    2085 1372 2134; 2086 1376 1377; 2087 1376 1351; 2088 1377 1355; 2089 1377 1378;
    2090 1378 1359; 2091 1378 1379; 2092 1379 1363; 2093 1379 1369; 2094 1380 1381;
    2095 1380 1376; 2096 1381 1377; 2097 1381 1382; 2098 1382 1378; 2099 1382 1383;
    2100 1383 1379; 2101 1383 1371; 2102 1384 1340; 2103 1385 1341; 2104 1386 1342;
    2105 1387 1343; 2106 1388 1344; 2107 1389 1345; 2108 1390 1346; 2109 1391 1347;
    2110 1350 1352; 2111 1348 1351; 2112 1357 1356; 2113 1361 1360; 2114 1359 1362;
    2115 1355 1358; 2116 1364 1368; 2117 1363 1367; 2118 1397 1353; 2119 1398 1354;
    2120 1409 1365; 2122 1396 1397; 2123 1397 1401; 2124 1400 1404; 2125 1405 1409;
    2126 1409 1408; 2127 1412 1415; 2128 1395 1398; 2129 1398 1402; 2130 1399 1403;
    2131 1406 1417; 2133 1393 1420; 2134 1394 1414; 2135 1414 1392; 2136 1415 1411;
    2137 1414 1424; 2138 1396 1424; 2139 1400 1425; 2140 1404 1426; 2141 1408 1427;
    2142 1396 1400; 2143 1404 1408; 2144 1395 1399; 2145 1403 1416; 2150 1416 2140;
    2151 1420 1421; 2152 1420 1395; 2153 1421 1399; 2154 1421 1422; 2155 1422 1403;
    2156 1422 1423; 2157 1423 1407; 2158 1423 1413; 2159 1424 1425; 2160 1424 1420;
    2161 1425 1421; 2162 1425 1426; 2163 1426 1422; 2164 1426 1427; 2165 1427 1423;
    2166 1427 1415; 2167 1428 1384; 2168 1429 1385; 2169 1430 1386; 2170 1431 1387;
    2171 1432 1388; 2172 1433 1389; 2173 1434 1390; 2174 1435 1391; 2175 1394 1396;
    2176 1392 1395; 2177 1401 1400; 2178 1405 1404; 2179 1403 1406; 2180 1399 1402;
    2181 1408 1412; 2182 1407 1411; 2183 1441 1397; 2184 1442 1398; 2185 1453 1409;
    2187 1440 1441; 2188 1441 1445; 2189 1444 1448; 2190 1449 1453; 2191 1453 1452;
    2192 1456 1459; 2193 1439 1442; 2194 1442 1446; 2195 1443 1447; 2196 1450 1461;
    2198 1437 1464; 2199 1438 1458; 2200 1458 1436; 2201 1459 1455; 2202 1458 1468;
    2203 1440 1468; 2204 1444 1469; 2205 1448 1470; 2206 1452 1471; 2207 1440 1444;
    2208 1448 1452; 2209 1439 1443; 2210 1447 1460; 2215 1460 2146; 2216 1464 1465;
    2217 1464 1439; 2218 1465 1443; 2219 1465 1466; 2220 1466 1447; 2221 1466 1467;
    2222 1467 1451; 2223 1467 1457; 2224 1468 1469; 2225 1468 1464; 2226 1469 1465;
    2227 1469 1470; 2228 1470 1466; 2229 1470 1471; 2230 1471 1467; 2231 1471 1459;
    2232 1472 1428; 2233 1473 1429; 2234 1474 1430; 2235 1475 1431; 2236 1476 1432;
    2237 1477 1433; 2238 1478 1434; 2239 1479 1435; 2240 1438 1440; 2241 1436 1439;
    2242 1445 1444; 2243 1449 1448; 2244 1447 1450; 2245 1443 1446; 2246 1452 1456;
    2247 1451 1455; 2248 1485 1441; 2249 1486 1442; 2250 1497 1453; 2252 1484 1485;
    2253 1485 1489; 2254 1488 1492; 2255 1493 1497; 2256 1497 1496; 2257 1500 1503;
    2258 1483 1486; 2259 1486 1490; 2260 1487 1491; 2261 1494 1505; 2263 1481 1508;
    2264 1482 1502; 2265 1502 1480; 2266 1503 1499; 2267 1502 1512; 2268 1484 1512;
    2269 1488 1513; 2270 1492 1514; 2271 1496 1515; 2272 1484 1488; 2273 1492 1496;
    2274 1483 1487; 2275 1491 1504; 2280 1504 2152; 2281 1508 1509; 2282 1508 1483;
    2283 1509 1487; 2284 1509 1510; 2285 1510 1491; 2286 1510 1511; 2287 1511 1495;
    2288 1511 1501; 2289 1512 1513; 2290 1512 1508; 2291 1513 1509; 2292 1513 1514;
    2293 1514 1510; 2294 1514 1515; 2295 1515 1511; 2296 1515 1503; 2297 1516 1472;
    2298 1517 1473; 2299 1518 1474; 2300 1519 1475; 2301 1520 1476; 2302 1521 1477;
    2303 1522 1478; 2304 1523 1479; 2305 1482 1484; 2306 1480 1483; 2307 1489 1488;
    2308 1493 1492; 2309 1491 1494; 2310 1487 1490; 2311 1496 1500; 2312 1495 1499;
    2313 1529 1485; 2314 1530 1486; 2315 1541 1497; 2317 1528 1529; 2318 1529 1533;
    2319 1532 1536; 2320 1537 1541; 2321 1541 1540; 2322 1544 1547; 2323 1527 1530;
    2324 1530 1534; 2325 1531 1535; 2326 1538 1549; 2328 1525 1552; 2329 1526 1546;
    2330 1546 1524; 2331 1547 1543; 2332 1546 1556; 2333 1528 1556; 2334 1532 1557;
    2335 1536 1558; 2336 1540 1559; 2337 1528 1532; 2338 1536 1540; 2339 1527 1531;
    2340 1535 1548; 2345 1548 2158; 2346 1552 1553; 2347 1552 1527; 2348 1553 1531;
    2349 1553 1554; 2350 1554 1535; 2351 1554 1555; 2352 1555 1539; 2353 1555 1545;
    2354 1556 1557; 2355 1556 1552; 2356 1557 1553; 2357 1557 1558; 2358 1558 1554;
    2359 1558 1559; 2360 1559 1555; 2361 1559 1547; 2362 1560 1516; 2363 1561 1517;
    2364 1562 1518; 2365 1563 1519; 2366 1564 1520; 2367 1565 1521; 2368 1566 1522;
    2369 1567 1523; 2370 1526 1528; 2371 1524 1527; 2372 1533 1532; 2373 1537 1536;
    2374 1535 1538; 2375 1531 1534; 2376 1540 1544; 2377 1539 1543; 2378 1573 1529;
    2379 1574 1530; 2380 1585 1541; 2382 1572 1573; 2383 1573 1577; 2384 1576 1580;
    2385 1581 1585; 2386 1585 1584; 2387 1588 1591; 2388 1571 1574; 2389 1574 1578;
    2390 1575 1579; 2391 1582 1593; 2393 1569 1596; 2394 1570 1590; 2395 1590 1568;
    2396 1591 1587; 2397 1590 1600; 2398 1572 1600; 2399 1576 1601; 2400 1580 1602;
    2401 1584 1603; 2402 1572 1576; 2403 1580 1584; 2404 1571 1575; 2405 1579 1592;
    2410 1592 2164; 2411 1596 1597; 2412 1596 1571; 2413 1597 1575; 2414 1597 1598;
    2415 1598 1579; 2416 1598 1599; 2417 1599 1583; 2418 1599 1589; 2419 1600 1601;
    2420 1600 1596; 2421 1601 1597; 2422 1601 1602; 2423 1602 1598; 2424 1602 1603;
    2425 1603 1599; 2426 1603 1591; 2427 1604 1560; 2428 1605 1561; 2429 1606 1562;
    2430 1607 1563; 2431 1608 1564; 2432 1609 1565; 2433 1610 1566; 2434 1611 1567;
    2435 1570 1572; 2436 1568 1571; 2437 1577 1576; 2438 1581 1580; 2439 1579 1582;
    2440 1575 1578; 2441 1584 1588; 2442 1583 1587; 2443 1617 1573; 2444 1618 1574;
    2445 1629 1585; 2447 1616 1617; 2448 1617 1621; 2449 1620 1624; 2450 1625 1629;
    2451 1629 1628; 2452 1632 1635; 2453 1615 1618; 2454 1618 1622; 2455 1619 1623;
    2456 1626 1637; 2458 1613 1640; 2459 1614 1634; 2460 1634 1612; 2461 1635 1631;
    2462 1634 1644; 2463 1616 1644; 2464 1620 1645; 2465 1624 1646; 2466 1628 1647;
    2467 1616 1620; 2468 1624 1628; 2469 1615 1619; 2470 1623 1636; 2475 1636 2170;
    2476 1640 1641; 2477 1640 1615; 2478 1641 1619; 2479 1641 1642; 2480 1642 1623;
    2481 1642 1643; 2482 1643 1627; 2483 1643 1633; 2484 1644 1645; 2485 1644 1640;
    2486 1645 1641; 2487 1645 1646; 2488 1646 1642; 2489 1646 1647; 2490 1647 1643;
    2491 1647 1635; 2492 1648 1604; 2493 1649 1605; 2494 1650 1606; 2495 1651 1607;
    2496 1652 1608; 2497 1653 1609; 2498 1654 1610; 2499 1655 1611; 2500 1614 1616;
    2501 1612 1615; 2502 1621 1620; 2503 1625 1624; 2504 1623 1626; 2505 1619 1622;
    2506 1628 1632; 2507 1627 1631; 2508 1661 1617; 2509 1662 1618; 2510 1673 1629;
    2512 1660 1661; 2513 1661 1665; 2514 1664 1668; 2515 1669 1673; 2516 1673 1672;
    2517 1676 1679; 2518 1659 1662; 2519 1662 1666; 2520 1663 1667; 2521 1670 1681;
    2523 1657 1684; 2524 1658 1678; 2525 1678 1656; 2526 1679 1675; 2527 1678 1688;
    2528 1660 1688; 2529 1664 1689; 2530 1668 1690; 2531 1672 1691; 2532 1660 1664;
    2533 1668 1672; 2534 1659 1663; 2535 1667 1680; 2540 1680 2176; 2541 1684 1685;
    2542 1684 1659; 2543 1685 1663; 2544 1685 1686; 2545 1686 1667; 2546 1686 1687;
    2547 1687 1671; 2548 1687 1677; 2549 1688 1689; 2550 1688 1684; 2551 1689 1685;
    2552 1689 1690; 2553 1690 1686; 2554 1690 1691; 2555 1691 1687; 2556 1691 1679;
    2557 1692 1648; 2558 1693 1649; 2559 1694 1650; 2560 1695 1651; 2561 1696 1652;
    2562 1697 1653; 2563 1698 1654; 2564 1699 1655; 2565 1658 1660; 2566 1656 1659;
    2567 1665 1664; 2568 1669 1668; 2569 1667 1670; 2570 1663 1666; 2571 1672 1676;
    2572 1671 1675; 2573 1705 1661; 2574 1706 1662; 2575 1717 1673; 2577 1704 1705;
    2578 1705 1709; 2579 1708 1712; 2580 1713 1717; 2581 1717 1716; 2582 1720 1723;
    2583 1703 1706; 2584 1706 1710; 2585 1707 1711; 2586 1714 1725; 2588 1701 1728;
    2589 1702 1722; 2590 1722 1700; 2591 1723 1719; 2592 1722 1732; 2593 1704 1732;
    2594 1708 1733; 2595 1712 1734; 2596 1716 1735; 2597 1704 1708; 2598 1712 1716;
    2599 1703 1707; 2600 1711 1724; 2605 1724 2182; 2606 1728 1729; 2607 1728 1703;
    2608 1729 1707; 2609 1729 1730; 2610 1730 1711; 2611 1730 1731; 2612 1731 1715;
    2613 1731 1721; 2614 1732 1733; 2615 1732 1728; 2616 1733 1729; 2617 1733 1734;
    2618 1734 1730; 2619 1734 1735; 2620 1735 1731; 2621 1735 1723; 2622 1736 1692;
    2623 1737 1693; 2624 1738 1694; 2625 1739 1695; 2626 1740 1696; 2627 1741 1697;
    2628 1742 1698; 2629 1743 1699; 2630 1702 1704; 2631 1700 1703; 2632 1709 1708;
    2633 1713 1712; 2634 1711 1714; 2635 1707 1710; 2636 1716 1720; 2637 1715 1719;
    2638 1749 1705; 2639 1750 1706; 2640 1761 1717; 2642 1748 1749; 2643 1749 1753;
    2644 1752 1756; 2645 1757 1761; 2646 1761 1760; 2647 1764 1767; 2648 1747 1750;
    2649 1750 1754; 2650 1751 1755; 2651 1758 1769; 2653 1745 1772; 2654 1746 1766;
    2655 1766 1744; 2656 1767 1763; 2657 1766 1776; 2658 1748 1776; 2659 1752 1777;
    2660 1756 1778; 2661 1760 1779; 2662 1748 1752; 2663 1756 1760; 2664 1747 1751;
    2665 1755 1768; 2670 1768 2188; 2671 1772 1773; 2672 1772 1747; 2673 1773 1751;
    2674 1773 1774; 2675 1774 1755; 2676 1774 1775; 2677 1775 1759; 2678 1775 1765;
    2679 1776 1777; 2680 1776 1772; 2681 1777 1773; 2682 1777 1778; 2683 1778 1774;
    2684 1778 1779; 2685 1779 1775; 2686 1779 1767; 2687 1780 1736; 2688 1781 1737;
    2689 1782 1738; 2690 1783 1739; 2691 1784 1740; 2692 1785 1741; 2693 1786 1742;
    2694 1787 1743; 2695 1746 1748; 2696 1744 1747; 2697 1753 1752; 2698 1757 1756;
    2699 1755 1758; 2700 1751 1754; 2701 1760 1764; 2702 1759 1763; 2703 1793 1749;
    2704 1794 1750; 2705 1805 1761; 2707 1792 1793; 2708 1793 1797; 2709 1796 1800;
    2710 1801 1805; 2711 1805 1804; 2712 1808 1811; 2713 1791 1794; 2714 1794 1798;
    2715 1795 1799; 2716 1802 1813; 2718 1789 1816; 2719 1790 1810; 2720 1810 1788;
    2721 1811 1807; 2722 1810 1820; 2723 1792 1820; 2724 1796 1821; 2725 1800 1822;
    2726 1804 1823; 2727 1792 1796; 2728 1800 1804; 2729 1791 1795; 2730 1799 1812;
    2735 1812 2194; 2736 1816 1817; 2737 1816 1791; 2738 1817 1795; 2739 1817 1818;
    2740 1818 1799; 2741 1818 1819; 2742 1819 1803; 2743 1819 1809; 2744 1820 1821;
    2745 1820 1816; 2746 1821 1817; 2747 1821 1822; 2748 1822 1818; 2749 1822 1823;
    2750 1823 1819; 2751 1823 1811; 2752 1824 1780; 2753 1825 1781; 2754 1826 1782;
    2755 1827 1783; 2756 1828 1784; 2757 1829 1785; 2758 1830 1786; 2759 1831 1787;
    2760 1790 1792; 2761 1788 1791; 2762 1797 1796; 2763 1801 1800; 2764 1799 1802;
    2765 1795 1798; 2766 1804 1808; 2767 1803 1807; 2768 1837 1793; 2769 1838 1794;
    2770 1849 1805; 2772 1836 1837; 2773 1837 1841; 2774 1840 1844; 2775 1845 1849;
    2776 1849 1848; 2777 1852 1855; 2778 1835 1838; 2779 1838 1842; 2780 1839 1843;
    2781 1846 1857; 2783 1833 1860; 2784 1834 1854; 2785 1854 1832; 2786 1855 1851;
    2787 1854 1864; 2788 1836 1864; 2789 1840 1865; 2790 1844 1866; 2791 1848 1867;
    2792 1836 1840; 2793 1844 1848; 2794 1835 1839; 2795 1843 1856; 2800 1856 2200;
    2801 1860 1861; 2802 1860 1835; 2803 1861 1839; 2804 1861 1862; 2805 1862 1843;
    2806 1862 1863; 2807 1863 1847; 2808 1863 1853; 2809 1864 1865; 2810 1864 1860;
    2811 1865 1861; 2812 1865 1866; 2813 1866 1862; 2814 1866 1867; 2815 1867 1863;
    2816 1867 1855; 2817 1868 1824; 2818 1869 1825; 2819 1870 1826; 2820 1871 1827;
    2821 1872 1828; 2822 1873 1829; 2823 1874 1830; 2824 1875 1831; 2825 1834 1836;
    2826 1832 1835; 2827 1841 1840; 2828 1845 1844; 2829 1843 1846; 2830 1839 1842;
    2831 1848 1852; 2832 1847 1851; 2833 1881 1837; 2834 1882 1838; 2835 1893 1849;
    2837 1880 1881; 2838 1881 1885; 2839 1884 1888; 2840 1889 1893; 2841 1893 1892;
    2842 1896 1899; 2843 1879 1882; 2844 1882 1886; 2845 1883 1887; 2846 1890 1901;
    2848 1877 1904; 2849 1878 1898; 2850 1898 1876; 2851 1899 1895; 2852 1898 1908;
    2853 1880 1908; 2854 1884 1909; 2855 1888 1910; 2856 1892 1911; 2857 1880 1884;
    2858 1888 1892; 2859 1879 1883; 2860 1887 1900; 2865 1900 2206; 2866 1904 1905;
    2867 1904 1879; 2868 1905 1883; 2869 1905 1906; 2870 1906 1887; 2871 1906 1907;
    2872 1907 1891; 2873 1907 1897; 2874 1908 1909; 2875 1908 1904; 2876 1909 1905;
    2877 1909 1910; 2878 1910 1906; 2879 1910 1911; 2880 1911 1907; 2881 1911 1899;
    2882 1912 1868; 2883 1913 1869; 2884 1914 1870; 2885 1915 1871; 2886 1916 1872;
    2887 1917 1873; 2888 1918 1874; 2889 1919 1875; 2890 1878 1880; 2891 1876 1879;
    2892 1885 1884; 2893 1889 1888; 2894 1887 1890; 2895 1883 1886; 2896 1892 1896;
    2897 1891 1895; 2898 56 1920; 2899 57 1921; 2900 58 1922; 2901 59 1923;
    2902 60 1924; 2903 61 1925; 2904 62 1926; 2905 63 1927; 2906 592 56;
    2907 593 57; 2908 594 58; 2909 595 59; 2910 596 60; 2911 597 61; 2912 598 62;
    2913 599 63; 2914 640 592; 2915 641 593; 2916 642 594; 2917 643 595;
    2918 644 596; 2919 645 597; 2920 646 598; 2921 647 599; 2922 688 640;
    2923 689 641; 2924 690 642; 2925 691 643; 2926 692 644; 2927 693 645;
    2928 694 646; 2929 695 647; 2930 736 688; 2931 737 689; 2932 738 690;
    2933 739 691; 2934 740 692; 2935 741 693; 2936 742 694; 2937 743 695;
    2938 784 736; 2939 785 737; 2940 786 738; 2941 787 739; 2942 788 740;
    2943 789 741; 2944 790 742; 2945 791 743; 2946 832 784; 2947 833 785;
    2948 834 786; 2949 835 787; 2950 836 788; 2951 837 789; 2952 838 790;
    2953 839 791; 2954 880 832; 2955 881 833; 2956 882 834; 2957 883 835;
    2958 884 836; 2959 885 837; 2960 886 838; 2961 887 839; 2962 928 880;
    2963 929 881; 2964 930 882; 2965 931 883; 2966 932 884; 2967 933 885;
    2968 934 886; 2969 935 887; 2970 976 928; 2971 977 929; 2972 978 930;
    2973 979 931; 2974 980 932; 2975 981 933; 2976 982 934; 2977 983 935;
    2978 1024 976; 2979 1025 977; 2980 1026 978; 2981 1027 979; 2982 1028 980;
    2983 1029 981; 2984 1030 982; 2985 1031 983; 2986 1068 1024; 2987 1069 1025;
    2988 1070 1026; 2989 1071 1027; 2990 1072 1028; 2991 1073 1029; 2992 1074 1030;
    2993 1075 1031; 2994 1112 1068; 2995 1113 1069; 2996 1114 1070; 2997 1115 1071;
    2998 1116 1072; 2999 1117 1073; 3000 1118 1074; 3001 1119 1075; 3002 1156 1112;
    3003 1157 1113; 3004 1158 1114; 3005 1159 1115; 3006 1160 1116; 3007 1161 1117;
    3008 1162 1118; 3009 1163 1119; 3010 1200 1156; 3011 1201 1157; 3012 1202 1158;
    3013 1203 1159; 3014 1204 1160; 3015 1205 1161; 3016 1206 1162; 3017 1207 1163;
    3018 1244 1200; 3019 1245 1201; 3020 1246 1202; 3021 1247 1203; 3022 1248 1204;
    3023 1249 1205; 3024 1250 1206; 3025 1251 1207; 3026 1288 1244; 3027 1289 1245;
    3028 1290 1246; 3029 1291 1247; 3030 1292 1248; 3031 1293 1249; 3032 1294 1250;
    3033 1295 1251; 3034 1332 1288; 3035 1333 1289; 3036 1334 1290; 3037 1335 1291;
    3038 1336 1292; 3039 1337 1293; 3040 1338 1294; 3041 1339 1295; 3042 1376 1332;
    3043 1377 1333; 3044 1378 1334; 3045 1379 1335; 3046 1380 1336; 3047 1381 1337;
    3048 1382 1338; 3049 1383 1339; 3050 1420 1376; 3051 1421 1377; 3052 1422 1378;
    3053 1423 1379; 3054 1424 1380; 3055 1425 1381; 3056 1426 1382; 3057 1427 1383;
    3058 1464 1420; 3059 1465 1421; 3060 1466 1422; 3061 1467 1423; 3062 1468 1424;
    3063 1469 1425; 3064 1470 1426; 3065 1471 1427; 3066 1508 1464; 3067 1509 1465;
    3068 1510 1466; 3069 1511 1467; 3070 1512 1468; 3071 1513 1469; 3072 1514 1470;
    3073 1515 1471; 3074 1552 1508; 3075 1553 1509; 3076 1554 1510; 3077 1555 1511;
    3078 1556 1512; 3079 1557 1513; 3080 1558 1514; 3081 1559 1515; 3082 1596 1552;
    3083 1597 1553; 3084 1598 1554; 3085 1599 1555; 3086 1600 1556; 3087 1601 1557;
    3088 1602 1558; 3089 1603 1559; 3090 1640 1596; 3091 1641 1597; 3092 1642 1598;
    3093 1643 1599; 3094 1644 1600; 3095 1645 1601; 3096 1646 1602; 3097 1647 1603;
    3098 1684 1640; 3099 1685 1641; 3100 1686 1642; 3101 1687 1643; 3102 1688 1644;
    3103 1689 1645; 3104 1690 1646; 3105 1691 1647; 3106 1728 1684; 3107 1729 1685;
    3108 1730 1686; 3109 1731 1687; 3110 1732 1688; 3111 1733 1689; 3112 1734 1690;
    3113 1735 1691; 3114 1772 1728; 3115 1773 1729; 3116 1774 1730; 3117 1775 1731;
    3118 1776 1732; 3119 1777 1733; 3120 1778 1734; 3121 1779 1735; 3122 1816 1772;
    3123 1817 1773; 3124 1818 1774; 3125 1819 1775; 3126 1820 1776; 3127 1821 1777;
    3128 1822 1778; 3129 1823 1779; 3130 1860 1816; 3131 1861 1817; 3132 1862 1818;
    3133 1863 1819; 3134 1864 1820; 3135 1865 1821; 3136 1866 1822; 3137 1867 1823;
    3138 1904 1860; 3139 1905 1861; 3140 1906 1862; 3141 1907 1863; 3142 1908 1864;
    3143 1909 1865; 3144 1910 1866; 3145 1911 1867; 3239 1930 2021; 3240 1928 2022;
    3241 1929 2023; 3242 54 2024; 3243 52 18; 3244 2026 53; 3245 2026 54;
    3246 53 2025; 3247 18 2025; 3248 2032 589; 3249 2030 1930; 3250 2028 1928;
    3251 2029 1929; 3252 2027 54; 3253 588 575; 3254 2032 2027; 3255 589 2031;
    3256 575 2031; 3257 2038 637; 3258 2036 2030; 3259 2034 2028; 3260 2035 2029;
    3261 2033 2027; 3262 636 623; 3263 2038 2033; 3264 637 2037; 3265 623 2037;
    3266 2044 685; 3267 2042 2036; 3268 2040 2034; 3269 2041 2035; 3270 2039 2033;
    3271 684 671; 3272 2044 2039; 3273 685 2043; 3274 671 2043; 3275 2050 733;
    3276 2048 2042; 3277 2046 2040; 3278 2047 2041; 3279 2045 2039; 3280 732 719;
    3281 2050 2045; 3282 733 2049; 3283 719 2049; 3284 2056 781; 3285 2054 2048;
    3286 2052 2046; 3287 2053 2047; 3288 2051 2045; 3289 780 767; 3290 2056 2051;
    3291 781 2055; 3292 767 2055; 3293 2062 829; 3294 2060 2054; 3295 2058 2052;
    3296 2059 2053; 3297 2057 2051; 3298 828 815; 3299 2062 2057; 3300 829 2061;
    3301 815 2061; 3302 2068 877; 3303 2066 2060; 3304 2064 2058; 3305 2065 2059;
    3306 2063 2057; 3307 876 863; 3308 2068 2063; 3309 877 2067; 3310 863 2067;
    3311 2074 925; 3312 2072 2066; 3313 2070 2064; 3314 2071 2065; 3315 2069 2063;
    3316 924 911; 3317 2074 2069; 3318 925 2073; 3319 911 2073; 3320 2080 973;
    3321 2078 2072; 3322 2076 2070; 3323 2077 2071; 3324 2075 2069; 3325 972 959;
    3326 2080 2075; 3327 973 2079; 3328 959 2079; 3329 2086 1021; 3330 2084 2078;
    3331 2082 2076; 3332 2083 2077; 3333 2081 2075; 3334 1020 1007; 3335 2086 2081;
    3336 1021 2085; 3337 1007 2085; 3338 2092 1065; 3339 2090 2084; 3340 2088 2082;
    3341 2089 2083; 3342 2087 2081; 3343 1064 1055; 3344 2092 2087; 3345 1065 2091;
    3346 1055 2091; 3347 2098 1109; 3348 2096 2090; 3349 2094 2088; 3350 2095 2089;
    3351 2093 2087; 3352 1108 1099; 3353 2098 2093; 3354 1109 2097; 3355 1099 2097;
    3356 2104 1153; 3357 2102 2096; 3358 2100 2094; 3359 2101 2095; 3360 2099 2093;
    3361 1152 1143; 3362 2104 2099; 3363 1153 2103; 3364 1143 2103; 3365 2110 1197;
    3366 2108 2102; 3367 2106 2100; 3368 2107 2101; 3369 2105 2099; 3370 1196 1187;
    3371 2110 2105; 3372 1197 2109; 3373 1187 2109; 3374 2116 1241; 3375 2114 2108;
    3376 2112 2106; 3377 2113 2107; 3378 2111 2105; 3379 1240 1231; 3380 2116 2111;
    3381 1241 2115; 3382 1231 2115; 3383 2122 1285; 3384 2120 2114; 3385 2118 2112;
    3386 2119 2113; 3387 2117 2111; 3388 1284 1275; 3389 2122 2117; 3390 1285 2121;
    3391 1275 2121; 3392 2128 1329; 3393 2126 2120; 3394 2124 2118; 3395 2125 2119;
    3396 2123 2117; 3397 1328 1319; 3398 2128 2123; 3399 1329 2127; 3400 1319 2127;
    3401 2134 1373; 3402 2132 2126; 3403 2130 2124; 3404 2131 2125; 3405 2129 2123;
    3406 1372 1363; 3407 2134 2129; 3408 1373 2133; 3409 1363 2133; 3410 2140 1417;
    3411 2138 2132; 3412 2136 2130; 3413 2137 2131; 3414 2135 2129; 3415 1416 1407;
    3416 2140 2135; 3417 1417 2139; 3418 1407 2139; 3419 2146 1461; 3420 2144 2138;
    3421 2142 2136; 3422 2143 2137; 3423 2141 2135; 3424 1460 1451; 3425 2146 2141;
    3426 1461 2145; 3427 1451 2145; 3428 2152 1505; 3429 2150 2144; 3430 2148 2142;
    3431 2149 2143; 3432 2147 2141; 3433 1504 1495; 3434 2152 2147; 3435 1505 2151;
    3436 1495 2151; 3437 2158 1549; 3438 2156 2150; 3439 2154 2148; 3440 2155 2149;
    3441 2153 2147; 3442 1548 1539; 3443 2158 2153; 3444 1549 2157; 3445 1539 2157;
    3446 2164 1593; 3447 2162 2156; 3448 2160 2154; 3449 2161 2155; 3450 2159 2153;
    3451 1592 1583; 3452 2164 2159; 3453 1593 2163; 3454 1583 2163; 3455 2170 1637;
    3456 2168 2162; 3457 2166 2160; 3458 2167 2161; 3459 2165 2159; 3460 1636 1627;
    3461 2170 2165; 3462 1637 2169; 3463 1627 2169; 3464 2176 1681; 3465 2174 2168;
    3466 2172 2166; 3467 2173 2167; 3468 2171 2165; 3469 1680 1671; 3470 2176 2171;
    3471 1681 2175; 3472 1671 2175; 3473 2182 1725; 3474 2180 2174; 3475 2178 2172;
    3476 2179 2173; 3477 2177 2171; 3478 1724 1715; 3479 2182 2177; 3480 1725 2181;
    3481 1715 2181; 3482 2188 1769; 3483 2186 2180; 3484 2184 2178; 3485 2185 2179;
    3486 2183 2177; 3487 1768 1759; 3488 2188 2183; 3489 1769 2187; 3490 1759 2187;
    3491 2194 1813; 3492 2192 2186; 3493 2190 2184; 3494 2191 2185; 3495 2189 2183;
    3496 1812 1803; 3497 2194 2189; 3498 1813 2193; 3499 1803 2193; 3500 2200 1857;
    3501 2198 2192; 3502 2196 2190; 3503 2197 2191; 3504 2195 2189; 3505 1856 1847;
    3506 2200 2195; 3507 1857 2199; 3508 1847 2199; 3509 2206 1901; 3510 2204 2198;
    3511 2202 2196; 3512 2203 2197; 3513 2201 2195; 3514 1900 1891; 3515 2206 2201;
    3516 1901 2205; 3517 1891 2205;
    DEFINE MATERIAL START
    ISOTROPIC CONCRETE
    E 2.17185e+07
    POISSON 0.17
    DENSITY 23.5616
    ALPHA 1e-05
    DAMP 0.05
    TYPE CONCRETE
    STRENGTH FCU 27579
    END DEFINE MATERIAL
    MEMBER PROPERTY INDIAN
    24 26 28 35 37 39 42 46 51 TO 54 65 66 69 71 73 74 77 79 81 885 TO 887 891 -
    892 TO 893 895 899 904 TO 907 918 919 922 924 926 927 930 932 934 948 TO 950 -
    954 TO 956 958 962 967 TO 970 981 982 985 987 989 990 993 995 997 -
    1011 TO 1013 1017 TO 1019 1021 1025 1030 TO 1033 1044 1045 1048 1050 1052 -
    1053 1056 1058 1060 1074 TO 1076 1080 TO 1082 1084 1088 1093 TO 1096 1107 -
    1108 1111 1113 1115 1116 1119 1121 1123 1137 TO 1139 1143 TO 1145 1147 1151 -
    1156 TO 1159 1170 1171 1174 1176 1178 1179 1182 1184 1186 1200 TO 1202 1206 -
    1207 TO 1208 1210 1214 1219 TO 1222 1233 1234 1237 1239 1241 1242 1245 1247 -
    1249 1263 TO 1265 1269 TO 1271 1273 1277 1282 TO 1285 1296 1297 1300 1302 -
    1304 1305 1308 1310 1312 1326 TO 1328 1332 TO 1334 1336 1340 1345 TO 1348 -
    1359 1360 1363 1365 1367 1368 1371 1373 1375 1389 TO 1391 1395 TO 1397 1399 -
    1403 1408 TO 1411 1422 1423 1426 1428 1430 1431 1434 1436 1438 1452 TO 1454 -
    1458 TO 1460 1462 1466 1471 TO 1474 1485 1486 1489 1491 1493 1494 1497 1499 -
    1501 1603 TO 1605 1609 TO 1611 1613 1617 1622 TO 1625 1630 1631 1634 1636 -
    1638 1639 1642 1644 1646 1668 TO 1670 1674 TO 1676 1678 3244 3248 3257 3266 -
    3275 3284 3293 3302 3311 3320 3329 3338 PRIS YD 0.75 ZD 0.4
    1682 1687 TO 1690 1695 1696 1699 1701 1703 1704 1707 1709 1711 1733 TO 1735 -
    1739 TO 1741 1743 1747 1752 TO 1755 1760 1761 1764 1766 1768 1769 1772 1774 -
    1776 1798 TO 1800 1804 TO 1806 1808 1812 1817 TO 1820 1825 1826 1829 1831 -
    1833 1834 1837 1839 1841 1863 TO 1865 1869 TO 1871 1873 1877 1882 TO 1885 -
    1890 1891 1894 1896 1898 1899 1902 1904 1906 1928 TO 1930 1934 TO 1936 1938 -
    1942 1947 TO 1950 1955 1956 1959 1961 1963 1964 1967 1969 1971 1993 TO 1995 -
    1999 TO 2001 2003 2007 2012 TO 2015 2020 2021 2024 2026 2028 2029 2032 2034 -
    2036 2058 TO 2060 2064 TO 2066 2068 2072 2077 TO 2080 2085 2086 2089 2091 -
    2093 2094 2097 2099 2101 2123 TO 2125 2129 TO 2131 2133 2137 2142 TO 2145 -
    2150 2151 2154 2156 2158 2159 2162 2164 2166 2188 TO 2190 2194 TO 2196 2198 -
    2202 2207 TO 2210 2215 2216 2219 2221 2223 2224 2227 2229 2231 2253 TO 2255 -
    2259 TO 2261 2263 2267 2272 TO 2275 2280 2281 2284 2286 2288 2289 2292 2294 -
    2296 2318 TO 2320 2324 TO 2326 2328 2332 2337 TO 2340 2345 2346 2349 2351 -
    2353 2354 2357 2359 2361 2383 TO 2385 2389 TO 2391 2393 2397 2402 TO 2405 -
    2410 2411 2414 2416 2418 2419 2422 2424 2426 2448 TO 2450 2454 TO 2456 2458 -
    2462 2467 TO 2470 2475 2476 2479 2481 2483 2484 2487 2489 2491 2513 TO 2515 -
    2519 TO 2521 2523 2527 2532 TO 2535 2540 3347 3356 3365 3374 3383 3392 3401 -
    3410 3419 3428 3437 3446 3455 3464 PRIS YD 0.75 ZD 0.4
    2541 2544 2546 2548 2549 2552 2554 2556 2578 TO 2580 2584 TO 2586 2588 2592 -
    2597 TO 2600 2605 2606 2609 2611 2613 2614 2617 2619 2621 2643 TO 2645 2649 -
    2650 TO 2651 2653 2657 2662 TO 2665 2670 2671 2674 2676 2678 2679 2682 2684 -
    2686 2708 TO 2710 2714 TO 2716 2718 2722 2727 TO 2730 2735 2736 2739 2741 -
    2743 2744 2747 2749 2751 2773 TO 2775 2779 TO 2781 2783 2787 2792 TO 2795 -
    2800 2801 2804 2806 2808 2809 2812 2814 2816 2838 TO 2840 2844 TO 2846 2848 -
    2852 2857 TO 2860 2865 2866 2869 2871 2873 2874 2877 2879 2881 3473 3482 -
    3491 3500 3509 PRIS YD 0.75 ZD 0.4
    23 29 31 34 43 TO 45 47 TO 50 55 TO 60 67 68 70 72 75 76 78 80 884 -
    888 TO 890 896 TO 898 900 TO 903 908 TO 913 920 921 923 925 928 929 931 933 -
    947 951 TO 953 959 TO 961 963 TO 966 971 TO 976 983 984 986 988 991 992 994 -
    996 1010 1014 TO 1016 1022 TO 1024 1026 TO 1029 1034 TO 1039 1046 1047 1049 -
    1051 1054 1055 1057 1059 1073 1077 TO 1079 1085 TO 1087 1089 TO 1092 1097 -
    1098 TO 1102 1109 1110 1112 1114 1117 1118 1120 1122 1136 1140 TO 1142 1148 -
    1149 TO 1150 1152 TO 1155 1160 TO 1165 1172 1173 1175 1177 1180 1181 1183 -
    1185 1199 1203 TO 1205 1211 TO 1213 1215 TO 1218 1223 TO 1228 1235 1236 1238 -
    1240 1243 1244 1246 1248 1262 1266 TO 1268 1274 TO 1276 1278 TO 1281 1286 -
    1287 TO 1291 1298 1299 1301 1303 1306 1307 1309 1311 1325 1329 TO 1331 1337 -
    1338 TO 1339 1341 TO 1344 1349 TO 1354 1361 1362 1364 1366 1369 1370 1372 -
    1374 1388 1392 TO 1394 1400 TO 1402 1404 TO 1407 1412 TO 1417 1424 1425 1427 -
    1429 1432 1433 1435 1437 1451 1455 TO 1457 1463 TO 1465 1467 TO 1470 1475 -
    1476 TO 1480 1487 1488 1490 1492 1495 1496 1498 1500 1602 1606 TO 1608 1614 -
    1615 TO 1616 1618 TO 1621 1632 1633 1635 1637 1640 1641 1643 1645 1667 1671 -
    1672 TO 1673 1679 PRIS YD 0.9 ZD 0.45
    1680 1681 1683 TO 1686 1697 1698 1700 1702 1705 1706 1708 1710 1732 -
    1736 TO 1738 1744 TO 1746 1748 TO 1751 1762 1763 1765 1767 1770 1771 1773 -
    1775 1797 1801 TO 1803 1809 TO 1811 1813 TO 1816 1827 1828 1830 1832 1835 -
    1836 1838 1840 1862 1866 TO 1868 1874 TO 1876 1878 TO 1881 1892 1893 1895 -
    1897 1900 1901 1903 1905 1927 1931 TO 1933 1939 TO 1941 1943 TO 1946 1957 -
    1958 1960 1962 1965 1966 1968 1970 1992 1996 TO 1998 2004 TO 2006 -
    2008 TO 2011 2022 2023 2025 2027 2030 2031 2033 2035 2057 2061 TO 2063 2069 -
    2070 TO 2071 2073 TO 2076 2087 2088 2090 2092 2095 2096 2098 2100 2122 2126 -
    2127 TO 2128 2134 TO 2136 2138 TO 2141 2152 2153 2155 2157 2160 2161 2163 -
    2165 2187 2191 TO 2193 2199 TO 2201 2203 TO 2206 2217 2218 2220 2222 2225 -
    2226 2228 2230 2252 2256 TO 2258 2264 TO 2266 2268 TO 2271 2282 2283 2285 -
    2287 2290 2291 2293 2295 2317 2321 TO 2323 2329 TO 2331 2333 TO 2336 2347 -
    2348 2350 2352 2355 2356 2358 2360 2382 2386 TO 2388 2394 TO 2396 -
    2398 TO 2401 2412 2413 2415 2417 2420 2421 2423 2425 2447 2451 TO 2453 2459 -
    2460 TO 2461 2463 TO 2466 2477 2478 2480 2482 2485 2486 2488 2490 2512 2516 -
    2517 TO 2518 2524 TO 2526 2528 TO 2531 2542 2543 2545 2547 2550 2551 2553 -
    2555 2577 2581 TO 2583 PRIS YD 0.9 ZD 0.45
    2589 TO 2591 2593 TO 2596 2607 2608 2610 2612 2615 2616 2618 2620 2642 2646 -
    2647 TO 2648 2654 TO 2656 2658 TO 2661 2672 2673 2675 2677 2680 2681 2683 -
    2685 2707 2711 TO 2713 2719 TO 2721 2723 TO 2726 2737 2738 2740 2742 2745 -
    2746 2748 2750 2772 2776 TO 2778 2784 TO 2786 2788 TO 2791 2802 2803 2805 -
    2807 2810 2811 2813 2815 2837 2841 TO 2843 2849 TO 2851 2853 TO 2856 2867 -
    2868 2870 2872 2875 2876 2878 2880 PRIS YD 0.9 ZD 0.45
    MEMBER PROPERTY
    876 939 1002 1065 1128 1191 1254 1317 1380 1443 1506 1651 1716 1781 1846 1911 -
    1976 2041 2106 2171 2236 2301 2366 2431 2496 2561 2626 2691 2756 2821 -
    2886 PRIS YD 4.62 ZD 0.85
    877 878 940 941 1003 1004 1066 1067 1129 1130 1192 1193 1255 1256 1318 1319 -
    1381 1382 1444 1445 1507 1508 1652 1653 1717 1718 1782 1783 1847 1848 1912 -
    1913 1977 1978 2042 2043 2107 2108 2172 2173 2237 2238 2302 2303 2367 2368 -
    2432 2433 2497 2498 2562 2563 2627 2628 2692 2693 2757 2758 2822 2823 2887 -
    2888 PRIS YD 4.91 ZD 0.85
    879 942 1005 1068 1131 1194 1257 1320 1379 1383 1442 1446 1505 1509 1650 1654 -
    1715 1719 1780 1784 1845 1849 1910 1914 1975 1979 2040 2044 2105 2109 2170 -
    2174 2235 2239 2300 2304 2365 2369 2430 2434 2495 2499 2560 2564 2625 2629 -
    2690 2694 2755 2759 2820 2824 2885 2889 PRIS YD 4.8 ZD 0.85
    1510 TO 1597 1655 TO 1662 1720 TO 1727 1785 TO 1792 1850 TO 1857 1915 TO 1922 -
    1980 TO 1987 2045 TO 2052 2110 TO 2117 2175 TO 2182 2240 TO 2247 -
    2305 TO 2312 2370 TO 2377 2435 TO 2442 2500 TO 2507 2565 TO 2572 -
    2630 TO 2637 2695 TO 2702 2760 TO 2767 2825 TO 2832 2890 TO 2896 -
    2897 PRIS YD 3 ZD 0.6
    2898 TO 3145 PRIS YD 1.5 ZD 0.5
    872 935 998 1061 1124 1187 1250 1313 1376 1439 1502 1647 1712 1777 1842 1907 -
    1972 2037 2102 2167 2232 2297 2362 2427 2492 2557 2622 2687 2752 2817 -
    2882 PRIS YD 4.62 ZD 0.85
    873 874 936 937 999 1000 1062 1063 1125 1126 1188 1189 1251 1252 1314 1315 -
    1377 1378 1440 1441 1503 1504 1648 1649 1713 1714 1778 1779 1843 1844 1908 -
    1909 1973 1974 2038 2039 2103 2104 2168 2169 2233 2234 2298 2299 2363 2364 -
    2428 2429 2493 2494 2558 2559 2623 2624 2688 2689 2753 2754 2818 2819 2883 -
    2884 PRIS YD 3.8 ZD 0.85
    875 938 1001 1064 1127 1190 1253 1316 PRIS YD 4.8 ZD 0.85
    3239 TO 3241 3249 TO 3251 3258 TO 3260 3267 TO 3269 3276 TO 3278 3285 TO 3287 -
    3294 TO 3296 3303 TO 3305 3312 TO 3314 3321 TO 3323 3330 TO 3332 -
    3339 TO 3341 3348 TO 3350 3357 TO 3359 3366 TO 3368 3375 TO 3377 -
    3384 TO 3386 3393 TO 3395 3402 TO 3404 3411 TO 3413 3420 TO 3422 -
    3429 TO 3431 3438 TO 3440 3447 TO 3449 3456 TO 3458 3465 TO 3467 -
    3474 TO 3476 3483 TO 3485 3492 TO 3494 3501 TO 3503 3510 TO 3511 -
    3512 PRIS YD 2.85 ZD 0.35
    3242 3252 3261 3270 3279 3288 3297 3306 3315 3324 3333 3342 3351 3360 3369 -
    3378 3387 3396 3405 3414 3423 3432 3441 3450 3459 3468 3477 3486 3495 3504 -
    3513 PRIS YD 4.91 ZD 0.35
    3243 3245 TO 3247 3253 TO 3256 3262 TO 3265 3271 TO 3274 3280 TO 3283 3289 -
    3290 TO 3292 3298 TO 3301 3307 TO 3310 3316 TO 3319 3325 TO 3328 3334 TO 3337 -
    3343 TO 3346 3352 TO 3355 3361 TO 3364 3370 TO 3373 3379 TO 3382 -
    3388 TO 3391 3397 TO 3400 3406 TO 3409 3415 TO 3418 3424 TO 3427 -
    3433 TO 3436 3442 TO 3445 3451 TO 3454 3460 TO 3463 3469 TO 3472 -
    3478 TO 3481 3487 TO 3490 3496 TO 3499 3505 TO 3508 3514 TO 3516 -
    3517 PRIS YD 3 ZD 0.35
    6 7 18 880 TO 882 943 TO 945 1006 TO 1008 1069 TO 1071 1132 TO 1134 -
    1195 TO 1197 1258 TO 1260 1321 TO 1323 1384 TO 1386 1447 TO 1449 -
    1598 TO 1600 1663 TO 1665 1728 TO 1730 1793 TO 1795 1858 TO 1860 -
    1923 TO 1925 1988 TO 1990 2053 TO 2055 2118 TO 2120 2183 TO 2185 -
    2248 TO 2250 2313 TO 2315 2378 TO 2380 2443 TO 2445 2508 TO 2510 -
    2573 TO 2575 2638 TO 2640 2703 TO 2705 2768 TO 2770 2833 TO 2834 -
    2835 PRIS YD 2 ZD 2
    CONSTANTS
    BETA 90 MEMB 7 873 874 877 878 881 936 937 940 941 944 999 1000 1003 1004 -
    1007 1062 1063 1066 1067 1070 1125 1126 1129 1130 1133 1188 1189 1192 1193 -
    1196 1251 1252 1255 1256 1259 1314 1315 1318 1319 1322 1377 1378 1381 1382 -
    1385 1440 1441 1444 1445 1448 1503 1504 1507 1508 1599 1648 1649 1652 1653 -
    1664 1713 1714 1717 1718 1729 1778 1779 1782 1783 1794 1843 1844 1847 1848 -
    1859 1908 1909 1912 1913 1924 1973 1974 1977 1978 1989 2038 2039 2042 2043 -
    2054 2103 2104 2107 2108 2119 2168 2169 2172 2173 2184 2233 2234 2237 2238 -
    2249 2298 2299 2302 2303 2314 2363 2364 2367 2368 2379 2428 2429 2432 2433 -
    2444 2493 2494 2497 2498 2509 2558 2559 2562 2563 2574 2623 2624 2627 2628 -
    2639 2688 2689 2692 2693 2704 2753 2754 2757 2758 2769 2818 2819 2822 2823 -
    2834 2883 2884 2887 2888 3242 3252 3261 3270 3279 3288 3297 3306 3315 3324 -
    3333 3342 3351 3360 3369 3378 3387 3396 3405 3414 3423 3432 3441 3450 3459 -
    3468 3477 3486 3495 3504 3513
    MATERIAL CONCRETE ALL
    SUPPORTS
    30 31 42 552 TO 559 1920 TO 1927 2021 TO 2024 FIXED
    MEMBER RELEASE
    42 46 59 60 65 895 899 912 913 918 958 962 975 976 981 1021 1025 1038 1039 -
    1044 1084 1088 1101 1102 1107 1147 1151 1164 1165 1170 1210 1214 1227 1228 -
    1233 1273 1277 1290 1291 1296 1336 1340 1353 1354 1359 1399 1403 1416 1417 -
    1422 1462 1466 1479 1480 1485 1613 1617 1630 1678 1682 1695 1743 1747 1760 -
    1808 1812 1825 1873 1877 1890 1938 1942 1955 2003 2007 2020 2068 2072 2085 -
    2133 2137 2150 2198 2202 2215 2263 2267 2280 2328 2332 2345 2393 2397 2410 -
    2458 2462 2475 2523 2527 2540 2588 2592 2605 2653 2657 2670 2718 2722 2735 -
    2783 2787 2800 2848 2852 2865 START MY MZ
    59 60 73 81 912 913 926 934 975 976 989 997 1038 1039 1052 1060 1101 1102 -
    1115 1123 1164 1165 1178 1186 1227 1228 1241 1249 1290 1291 1304 1312 1353 -
    1354 1367 1375 1416 1417 1430 1438 1479 1480 1493 1501 1638 1646 1703 1711 -
    1768 1776 1833 1841 1898 1906 1963 1971 2028 2036 2093 2101 2158 2166 2223 -
    2231 2288 2296 2353 2361 2418 2426 2483 2491 2548 2556 2613 2621 2678 2686 -
    2743 2751 2808 2816 2873 2881 3244 3248 3257 3266 3275 3284 3293 3302 3311 -
    3320 3329 3338 3347 3356 3365 3374 3383 3392 3401 3410 3419 3428 3437 3446 -
    3455 3464 3473 3482 3491 3500 3509 END MY MZ
    DEFINE IS1893 2016 LOAD
    ZONE 0.36 RF 5 I 1.2 SS 2 ST 1 DM 0.05
    SELFWEIGHT 1
    MEMBER WEIGHT
    23 24 26 28 29 34 35 37 39 51 TO 58 65 884 TO 888 890 TO 893 904 TO 911 918 -
    947 TO 951 953 TO 956 967 TO 974 981 1010 TO 1014 1016 TO 1019 1030 TO 1037 -
    1044 1073 TO 1077 1079 TO 1082 1093 TO 1100 1107 1136 TO 1140 1142 TO 1145 -
    1156 TO 1163 1170 1199 TO 1203 1205 TO 1208 1219 TO 1226 1233 1262 TO 1266 -
    1268 TO 1271 1282 TO 1289 1296 1325 TO 1329 1331 TO 1334 1345 TO 1352 1359 -
    1388 TO 1392 1394 TO 1397 1408 TO 1415 1422 1451 TO 1455 1457 TO 1460 1471 -
    1472 TO 1478 1485 1602 TO 1606 1608 TO 1611 1622 TO 1625 1630 1667 TO 1671 -
    1673 TO 1676 1687 TO 1690 1695 1732 TO 1736 1738 TO 1741 1752 TO 1755 1760 -
    1797 TO 1801 1803 TO 1806 1817 TO 1820 1825 1862 TO 1866 1868 TO 1871 1882 -
    1883 TO 1885 1890 1927 TO 1931 1933 TO 1936 1947 TO 1950 1955 1992 TO 1996 -
    1998 TO 2001 2012 TO 2015 2020 2057 TO 2061 2063 TO 2066 2077 TO 2080 2085 -
    2122 TO 2126 2128 TO 2131 2142 TO 2145 2150 2187 TO 2191 2193 TO 2196 2207 -
    2208 TO 2210 2215 2252 TO 2256 2258 TO 2261 2272 TO 2275 2280 2317 TO 2321 -
    2323 TO 2326 2337 TO 2340 2345 2382 TO 2386 2388 TO 2391 2402 TO 2405 2410 -
    2447 TO 2451 2453 TO 2456 2467 TO 2470 2475 2512 TO 2516 2518 TO 2521 2532 -
    2533 TO 2535 2540 2577 TO 2581 2583 TO 2586 2597 TO 2600 2605 3244 3248 3257 -
    3266 3275 3284 3293 UNI 6
    3302 3311 3320 3329 3338 3347 3356 3365 3374 3383 3392 3401 3410 3419 3428 -
    3437 3446 3455 3464 3473 UNI 6
    2642 TO 2646 2648 TO 2651 2662 TO 2665 2670 2707 TO 2711 2713 TO 2716 2727 -
    2728 TO 2730 2735 2772 TO 2776 2778 TO 2781 2792 TO 2795 2800 2837 TO 2841 -
    2843 TO 2846 2857 TO 2860 2865 3482 3491 3500 3509 UNI 6
    59 60 912 913 975 976 1038 1039 1101 1102 1164 1165 1227 1228 1290 1291 1353 -
    1354 1416 1417 1479 1480 1607 1614 TO 1616 1672 1679 TO 1681 1737 -
    1744 TO 1746 1802 1809 TO 1811 1867 1874 TO 1876 1932 1939 TO 1941 1997 2004 -
    2005 TO 2006 2062 2069 TO 2071 2127 2134 TO 2136 2192 2199 TO 2201 2257 2264 -
    2265 TO 2266 2322 2329 TO 2331 2387 2394 TO 2396 2452 2459 TO 2461 2517 2524 -
    2525 TO 2526 2582 2589 TO 2591 2647 2654 TO 2656 2712 2719 TO 2721 2777 2784 -
    2785 TO 2786 2842 2849 TO 2851 UNI 5
    FLOOR WEIGHT
    YRANGE 0 100 FLOAD 4
    LOAD 1 LOADTYPE Seismic TITLE EQX+
    1893 LOAD X 1
    PERFORM ANALYSIS
    CHANGE
    LOAD 2 LOADTYPE Seismic TITLE EQX-
    1893 LOAD X -1
    PERFORM ANALYSIS
    CHANGE
    LOAD 3 LOADTYPE Seismic TITLE EQZ+
    1893 LOAD Z 1
    PERFORM ANALYSIS
    CHANGE
    LOAD 4 LOADTYPE Seismic TITLE EQZ-
    1893 LOAD Z -1
    PERFORM ANALYSIS
    CHANGE
    LOAD 5 LOADTYPE Dead TITLE DL
    SELFWEIGHT Y -1
    FLOOR LOAD
    YRANGE 0 100 FLOAD -1 GY
    MEMBER LOAD
    3266 3275 3284 3293 UNI GY -6
    3437 3446 3455 3464 3473 UNI GY -6
    2843 TO 2846 2857 TO 2860 2865 3482 3491 3500 3509 UNI GY -6
    2785 TO 2786 2842 2849 TO 2851 UNI GY -5
    LOAD 6 LOADTYPE Live TITLE LL
    FLOOR LOAD
    YRANGE 0 100 FLOAD -3 GY
    LOAD COMB 7 ULC, 1.5 DEAD + 1.5 LIVE
    5 1.5 6 1.5
    LOAD COMB 8 ULC, 1.2 DEAD + 1.2 LIVE
    5 1.2 6 1.2
    LOAD COMB 9 ULC, 1.2 DEAD + 1.2 LIVE + 1.2 SEISMIC (1)
    5 1.2 6 1.2 1 1.2
    LOAD COMB 10 ULC, 1.2 DEAD + 1.2 LIVE + 1.2 SEISMIC (2)
    5 1.2 6 1.2 2 1.2
    LOAD COMB 11 ULC, 1.2 DEAD + 1.2 LIVE + 1.2 SEISMIC (3)
    5 1.2 6 1.2 3 1.2
    LOAD COMB 12 ULC, 1.2 DEAD + 1.2 LIVE + 1.2 SEISMIC (4)
    5 1.2 6 1.2 4 1.2
    LOAD COMB 13 ULC, 1.2 DEAD + 1.2 LIVE + -1.2 SEISMIC (1)
    5 1.2 6 1.2 1 -1.2
    LOAD COMB 14 ULC, 1.2 DEAD + 1.2 LIVE + -1.2 SEISMIC (2)
    5 1.2 6 1.2 2 -1.2
    LOAD COMB 15 ULC, 1.2 DEAD + 1.2 LIVE + -1.2 SEISMIC (3)
    5 1.2 6 1.2 3 -1.2
    LOAD COMB 16 ULC, 1.2 DEAD + 1.2 LIVE + -1.2 SEISMIC (4)
    5 1.2 6 1.2 4 -1.2
    LOAD COMB 17 ULC, 1.5 DEAD
    5 1.5
    LOAD COMB 18 ULC, 1.5 DEAD + 1.5 SEISMIC (1)
    5 1.5 1 1.5
    LOAD COMB 19 ULC, 1.5 DEAD + 1.5 SEISMIC (2)
    5 1.5 2 1.5
    LOAD COMB 20 ULC, 1.5 DEAD + 1.5 SEISMIC (3)
    5 1.5 3 1.5
    LOAD COMB 21 ULC, 1.5 DEAD + 1.5 SEISMIC (4)
    5 1.5 4 1.5
    LOAD COMB 22 ULC, 1.5 DEAD + -1.5 SEISMIC (1)
    5 1.5 1 -1.5
    LOAD COMB 23 ULC, 1.5 DEAD + -1.5 SEISMIC (2)
    5 1.5 2 -1.5
    LOAD COMB 24 ULC, 1.5 DEAD + -1.5 SEISMIC (3)
    5 1.5 3 -1.5
    LOAD COMB 25 ULC, 1.5 DEAD + -1.5 SEISMIC (4)
    5 1.5 4 -1.5
    LOAD COMB 26 ULC, 0.9 DEAD
    5 0.9
    LOAD COMB 27 ULC, 0.9 DEAD + 1.5 SEISMIC (1)
    5 0.9 1 1.5
    LOAD COMB 28 ULC, 0.9 DEAD + 1.5 SEISMIC (2)
    5 0.9 2 1.5
    LOAD COMB 29 ULC, 0.9 DEAD + 1.5 SEISMIC (3)
    5 0.9 3 1.5
    LOAD COMB 30 ULC, 0.9 DEAD + 1.5 SEISMIC (4)
    5 0.9 4 1.5
    LOAD COMB 31 ULC, 0.9 DEAD + -1.5 SEISMIC (1)
    5 0.9 1 -1.5
    LOAD COMB 32 ULC, 0.9 DEAD + -1.5 SEISMIC (2)
    5 0.9 2 -1.5
    LOAD COMB 33 ULC, 0.9 DEAD + -1.5 SEISMIC (3)
    5 0.9 3 -1.5
    LOAD COMB 34 ULC, 0.9 DEAD + -1.5 SEISMIC (4)
    5 0.9 4 -1.5
    PERFORM ANALYSIS
    FINISH
Reply
  • Can you help me how to do it i don't know how to model shearwall in StaadPro Connect addition here is the command file
    INPUT WIDTH 79
    UNIT METER KN
    JOINT COORDINATES
    1 0 0 4.91; 2 0 0 1.08; 3 0 0 -5.935; 6 4.62 0 4.91; 7 4.62 0 -5.935;
    8 4.62 0 -9.735; 9 4.62 0 9.82; 10 11.74 0 4.91; 11 11.74 0 -5.935;
    12 11.74 0 -9.735; 13 11.74 0 9.82; 14 20.65 0 4.91; 15 20.65 0 -5.935;
    16 20.65 0 -9.735; 17 20.65 0 9.82; 18 27.77 0 4.91; 19 27.77 0 -5.935;
    20 27.77 0 -9.735; 22 32.25 0 4.91; 23 32.25 0 -5.935; 24 32.25 0 1.08;
    30 4.62 -3 -9.735; 31 4.62 -3 9.82; 42 27.77 -3 -9.735; 46 0 0 -2.4275;
    47 32.25 0 -2.4275; 48 -1.95 0 4.91; 49 -1.95 0 -5.935; 50 34.2 0 4.91;
    51 34.2 0 -5.935; 52 24.92 0 4.91; 53 24.92 0 9.82; 54 27.77 0 7.365;
    56 4.62 0 1.08; 57 11.74 0 1.08; 58 20.65 0 1.08; 59 27.77 0 1.08;
    60 4.62 0 -2.4275; 61 11.74 0 -2.428; 62 20.65 0 -2.428; 63 27.77 0 -2.428;
    464 2.31 0 -5.935; 465 11.74 0 -7.835; 466 20.65 0 -7.835; 467 30.01 0 -5.935;
    468 2.31 0 4.91; 469 11.74 0 7.365; 470 20.65 0 7.365; 471 30.01 0 4.91;
    552 2.31 -3 -5.935; 553 11.74 -3 -7.835; 554 20.65 -3 -7.835;
    555 30.01 -3 -5.935; 556 2.31 -3 4.91; 557 11.74 -3 7.365; 558 20.65 -3 7.365;
    559 30.01 -3 4.91; 560 0 3 4.91; 561 0 3 1.08; 562 0 3 -5.935; 563 4.62 3 4.91;
    564 4.62 3 -5.935; 565 4.62 3 -9.735; 566 4.62 3 9.82; 567 11.74 3 4.91;
    568 11.74 3 -5.935; 569 11.74 3 -9.735; 570 11.74 3 9.82; 571 20.65 3 4.91;
    572 20.65 3 -5.935; 573 20.65 3 -9.735; 574 20.65 3 9.82; 575 27.77 3 4.91;
    576 27.77 3 -5.935; 577 27.77 3 -9.735; 579 32.25 3 4.91; 580 32.25 3 -5.935;
    581 32.25 3 1.08; 582 0 3 -2.4275; 583 32.25 3 -2.4275; 584 -1.95 3 4.91;
    585 -1.95 3 -5.935; 586 34.2 3 4.91; 587 34.2 3 -5.935; 588 24.92 3 4.91;
    589 24.92 3 9.82; 592 4.62 3 1.08; 593 11.74 3 1.08; 594 20.65 3 1.08;
    595 27.77 3 1.08; 596 4.62 3 -2.4275; 597 11.74 3 -2.428; 598 20.65 3 -2.428;
    599 27.77 3 -2.428; 600 2.31 3 -5.935; 601 11.74 3 -7.835; 602 20.65 3 -7.835;
    603 30.01 3 -5.935; 604 2.31 3 4.91; 605 11.74 3 7.365; 606 20.65 3 7.365;
    607 30.01 3 4.91; 608 0 6 4.91; 609 0 6 1.08; 610 0 6 -5.935; 611 4.62 6 4.91;
    612 4.62 6 -5.935; 613 4.62 6 -9.735; 614 4.62 6 9.82; 615 11.74 6 4.91;
    616 11.74 6 -5.935; 617 11.74 6 -9.735; 618 11.74 6 9.82; 619 20.65 6 4.91;
    620 20.65 6 -5.935; 621 20.65 6 -9.735; 622 20.65 6 9.82; 623 27.77 6 4.91;
    624 27.77 6 -5.935; 625 27.77 6 -9.735; 627 32.25 6 4.91; 628 32.25 6 -5.935;
    629 32.25 6 1.08; 630 0 6 -2.4275; 631 32.25 6 -2.4275; 632 -1.95 6 4.91;
    633 -1.95 6 -5.935; 634 34.2 6 4.91; 635 34.2 6 -5.935; 636 24.92 6 4.91;
    637 24.92 6 9.82; 640 4.62 6 1.08; 641 11.74 6 1.08; 642 20.65 6 1.08;
    643 27.77 6 1.08; 644 4.62 6 -2.4275; 645 11.74 6 -2.428; 646 20.65 6 -2.428;
    647 27.77 6 -2.428; 648 2.31 6 -5.935; 649 11.74 6 -7.835; 650 20.65 6 -7.835;
    651 30.01 6 -5.935; 652 2.31 6 4.91; 653 11.74 6 7.365; 654 20.65 6 7.365;
    655 30.01 6 4.91; 656 0 9 4.91; 657 0 9 1.08; 658 0 9 -5.935; 659 4.62 9 4.91;
    660 4.62 9 -5.935; 661 4.62 9 -9.735; 662 4.62 9 9.82; 663 11.74 9 4.91;
    664 11.74 9 -5.935; 665 11.74 9 -9.735; 666 11.74 9 9.82; 667 20.65 9 4.91;
    668 20.65 9 -5.935; 669 20.65 9 -9.735; 670 20.65 9 9.82; 671 27.77 9 4.91;
    672 27.77 9 -5.935; 673 27.77 9 -9.735; 675 32.25 9 4.91; 676 32.25 9 -5.935;
    677 32.25 9 1.08; 678 0 9 -2.4275; 679 32.25 9 -2.4275; 680 -1.95 9 4.91;
    681 -1.95 9 -5.935; 682 34.2 9 4.91; 683 34.2 9 -5.935; 684 24.92 9 4.91;
    685 24.92 9 9.82; 688 4.62 9 1.08; 689 11.74 9 1.08; 690 20.65 9 1.08;
    691 27.77 9 1.08; 692 4.62 9 -2.4275; 693 11.74 9 -2.428; 694 20.65 9 -2.428;
    695 27.77 9 -2.428; 696 2.31 9 -5.935; 697 11.74 9 -7.835; 698 20.65 9 -7.835;
    699 30.01 9 -5.935; 700 2.31 9 4.91; 701 11.74 9 7.365; 702 20.65 9 7.365;
    703 30.01 9 4.91; 704 0 12 4.91; 705 0 12 1.08; 706 0 12 -5.935;
    707 4.62 12 4.91; 708 4.62 12 -5.935; 709 4.62 12 -9.735; 710 4.62 12 9.82;
    711 11.74 12 4.91; 712 11.74 12 -5.935; 713 11.74 12 -9.735; 714 11.74 12 9.82;
    715 20.65 12 4.91; 716 20.65 12 -5.935; 717 20.65 12 -9.735; 718 20.65 12 9.82;
    719 27.77 12 4.91; 720 27.77 12 -5.935; 721 27.77 12 -9.735; 723 32.25 12 4.91;
    724 32.25 12 -5.935; 725 32.25 12 1.08; 726 0 12 -2.4275; 727 32.25 12 -2.4275;
    728 -1.95 12 4.91; 729 -1.95 12 -5.935; 730 34.2 12 4.91; 731 34.2 12 -5.935;
    732 24.92 12 4.91; 733 24.92 12 9.82; 736 4.62 12 1.08; 737 11.74 12 1.08;
    738 20.65 12 1.08; 739 27.77 12 1.08; 740 4.62 12 -2.4275; 741 11.74 12 -2.428;
    742 20.65 12 -2.428; 743 27.77 12 -2.428; 744 2.31 12 -5.935;
    745 11.74 12 -7.835; 746 20.65 12 -7.835; 747 30.01 12 -5.935;
    748 2.31 12 4.91; 749 11.74 12 7.365; 750 20.65 12 7.365; 751 30.01 12 4.91;
    752 0 15 4.91; 753 0 15 1.08; 754 0 15 -5.935; 755 4.62 15 4.91;
    756 4.62 15 -5.935; 757 4.62 15 -9.735; 758 4.62 15 9.82; 759 11.74 15 4.91;
    760 11.74 15 -5.935; 761 11.74 15 -9.735; 762 11.74 15 9.82; 763 20.65 15 4.91;
    764 20.65 15 -5.935; 765 20.65 15 -9.735; 766 20.65 15 9.82; 767 27.77 15 4.91;
    768 27.77 15 -5.935; 769 27.77 15 -9.735; 771 32.25 15 4.91;
    772 32.25 15 -5.935; 773 32.25 15 1.08; 774 0 15 -2.4275; 775 32.25 15 -2.4275;
    776 -1.95 15 4.91; 777 -1.95 15 -5.935; 778 34.2 15 4.91; 779 34.2 15 -5.935;
    780 24.92 15 4.91; 781 24.92 15 9.82; 784 4.62 15 1.08; 785 11.74 15 1.08;
    786 20.65 15 1.08; 787 27.77 15 1.08; 788 4.62 15 -2.4275; 789 11.74 15 -2.428;
    790 20.65 15 -2.428; 791 27.77 15 -2.428; 792 2.31 15 -5.935;
    793 11.74 15 -7.835; 794 20.65 15 -7.835; 795 30.01 15 -5.935;
    796 2.31 15 4.91; 797 11.74 15 7.365; 798 20.65 15 7.365; 799 30.01 15 4.91;
    800 0 18 4.91; 801 0 18 1.08; 802 0 18 -5.935; 803 4.62 18 4.91;
    804 4.62 18 -5.935; 805 4.62 18 -9.735; 806 4.62 18 9.82; 807 11.74 18 4.91;
    808 11.74 18 -5.935; 809 11.74 18 -9.735; 810 11.74 18 9.82; 811 20.65 18 4.91;
    812 20.65 18 -5.935; 813 20.65 18 -9.735; 814 20.65 18 9.82; 815 27.77 18 4.91;
    816 27.77 18 -5.935; 817 27.77 18 -9.735; 819 32.25 18 4.91;
    820 32.25 18 -5.935; 821 32.25 18 1.08; 822 0 18 -2.4275; 823 32.25 18 -2.4275;
    824 -1.95 18 4.91; 825 -1.95 18 -5.935; 826 34.2 18 4.91; 827 34.2 18 -5.935;
    828 24.92 18 4.91; 829 24.92 18 9.82; 832 4.62 18 1.08; 833 11.74 18 1.08;
    834 20.65 18 1.08; 835 27.77 18 1.08; 836 4.62 18 -2.4275; 837 11.74 18 -2.428;
    838 20.65 18 -2.428; 839 27.77 18 -2.428; 840 2.31 18 -5.935;
    841 11.74 18 -7.835; 842 20.65 18 -7.835; 843 30.01 18 -5.935;
    844 2.31 18 4.91; 845 11.74 18 7.365; 846 20.65 18 7.365; 847 30.01 18 4.91;
    848 0 21 4.91; 849 0 21 1.08; 850 0 21 -5.935; 851 4.62 21 4.91;
    852 4.62 21 -5.935; 853 4.62 21 -9.735; 854 4.62 21 9.82; 855 11.74 21 4.91;
    856 11.74 21 -5.935; 857 11.74 21 -9.735; 858 11.74 21 9.82; 859 20.65 21 4.91;
    860 20.65 21 -5.935; 861 20.65 21 -9.735; 862 20.65 21 9.82; 863 27.77 21 4.91;
    864 27.77 21 -5.935; 865 27.77 21 -9.735; 867 32.25 21 4.91;
    868 32.25 21 -5.935; 869 32.25 21 1.08; 870 0 21 -2.4275; 871 32.25 21 -2.4275;
    872 -1.95 21 4.91; 873 -1.95 21 -5.935; 874 34.2 21 4.91; 875 34.2 21 -5.935;
    876 24.92 21 4.91; 877 24.92 21 9.82; 880 4.62 21 1.08; 881 11.74 21 1.08;
    882 20.65 21 1.08; 883 27.77 21 1.08; 884 4.62 21 -2.4275; 885 11.74 21 -2.428;
    886 20.65 21 -2.428; 887 27.77 21 -2.428; 888 2.31 21 -5.935;
    889 11.74 21 -7.835; 890 20.65 21 -7.835; 891 30.01 21 -5.935;
    892 2.31 21 4.91; 893 11.74 21 7.365; 894 20.65 21 7.365; 895 30.01 21 4.91;
    896 0 24 4.91; 897 0 24 1.08; 898 0 24 -5.935; 899 4.62 24 4.91;
    900 4.62 24 -5.935; 901 4.62 24 -9.735; 902 4.62 24 9.82; 903 11.74 24 4.91;
    904 11.74 24 -5.935; 905 11.74 24 -9.735; 906 11.74 24 9.82; 907 20.65 24 4.91;
    908 20.65 24 -5.935; 909 20.65 24 -9.735; 910 20.65 24 9.82; 911 27.77 24 4.91;
    912 27.77 24 -5.935; 913 27.77 24 -9.735; 915 32.25 24 4.91;
    916 32.25 24 -5.935; 917 32.25 24 1.08; 918 0 24 -2.4275; 919 32.25 24 -2.4275;
    920 -1.95 24 4.91; 921 -1.95 24 -5.935; 922 34.2 24 4.91; 923 34.2 24 -5.935;
    924 24.92 24 4.91; 925 24.92 24 9.82; 928 4.62 24 1.08; 929 11.74 24 1.08;
    930 20.65 24 1.08; 931 27.77 24 1.08; 932 4.62 24 -2.4275; 933 11.74 24 -2.428;
    934 20.65 24 -2.428; 935 27.77 24 -2.428; 936 2.31 24 -5.935;
    937 11.74 24 -7.835; 938 20.65 24 -7.835; 939 30.01 24 -5.935;
    940 2.31 24 4.91; 941 11.74 24 7.365; 942 20.65 24 7.365; 943 30.01 24 4.91;
    944 0 27 4.91; 945 0 27 1.08; 946 0 27 -5.935; 947 4.62 27 4.91;
    948 4.62 27 -5.935; 949 4.62 27 -9.735; 950 4.62 27 9.82; 951 11.74 27 4.91;
    952 11.74 27 -5.935; 953 11.74 27 -9.735; 954 11.74 27 9.82; 955 20.65 27 4.91;
    956 20.65 27 -5.935; 957 20.65 27 -9.735; 958 20.65 27 9.82; 959 27.77 27 4.91;
    960 27.77 27 -5.935; 961 27.77 27 -9.735; 963 32.25 27 4.91;
    964 32.25 27 -5.935; 965 32.25 27 1.08; 966 0 27 -2.4275; 967 32.25 27 -2.4275;
    968 -1.95 27 4.91; 969 -1.95 27 -5.935; 970 34.2 27 4.91; 971 34.2 27 -5.935;
    972 24.92 27 4.91; 973 24.92 27 9.82; 976 4.62 27 1.08; 977 11.74 27 1.08;
    978 20.65 27 1.08; 979 27.77 27 1.08; 980 4.62 27 -2.4275; 981 11.74 27 -2.428;
    982 20.65 27 -2.428; 983 27.77 27 -2.428; 984 2.31 27 -5.935;
    985 11.74 27 -7.835; 986 20.65 27 -7.835; 987 30.01 27 -5.935;
    988 2.31 27 4.91; 989 11.74 27 7.365; 990 20.65 27 7.365; 991 30.01 27 4.91;
    992 0 30 4.91; 993 0 30 1.08; 994 0 30 -5.935; 995 4.62 30 4.91;
    996 4.62 30 -5.935; 997 4.62 30 -9.735; 998 4.62 30 9.82; 999 11.74 30 4.91;
    1000 11.74 30 -5.935; 1001 11.74 30 -9.735; 1002 11.74 30 9.82;
    1003 20.65 30 4.91; 1004 20.65 30 -5.935; 1005 20.65 30 -9.735;
    1006 20.65 30 9.82; 1007 27.77 30 4.91; 1008 27.77 30 -5.935;
    1009 27.77 30 -9.735; 1011 32.25 30 4.91; 1012 32.25 30 -5.935;
    1013 32.25 30 1.08; 1014 0 30 -2.4275; 1015 32.25 30 -2.4275;
    1016 -1.95 30 4.91; 1017 -1.95 30 -5.935; 1018 34.2 30 4.91;
    1019 34.2 30 -5.935; 1020 24.92 30 4.91; 1021 24.92 30 9.82; 1024 4.62 30 1.08;
    1025 11.74 30 1.08; 1026 20.65 30 1.08; 1027 27.77 30 1.08;
    1028 4.62 30 -2.4275; 1029 11.74 30 -2.428; 1030 20.65 30 -2.428;
    1031 27.77 30 -2.428; 1032 2.31 30 -5.935; 1033 11.74 30 -7.835;
    1034 20.65 30 -7.835; 1035 30.01 30 -5.935; 1036 2.31 30 4.91;
    1037 11.74 30 7.365; 1038 20.65 30 7.365; 1039 30.01 30 4.91; 1040 0 33 4.91;
    1041 0 33 1.08; 1042 0 33 -5.935; 1043 4.62 33 4.91; 1044 4.62 33 -5.935;
    1045 4.62 33 -9.735; 1046 4.62 33 9.82; 1047 11.74 33 4.91;
    1048 11.74 33 -5.935; 1049 11.74 33 -9.735; 1050 11.74 33 9.82;
    1051 20.65 33 4.91; 1052 20.65 33 -5.935; 1053 20.65 33 -9.735;
    1054 20.65 33 9.82; 1055 27.77 33 4.91; 1056 27.77 33 -5.935;
    1057 27.77 33 -9.735; 1059 32.25 33 4.91; 1060 32.25 33 -5.935;
    1061 32.25 33 1.08; 1062 0 33 -2.4275; 1063 32.25 33 -2.4275;
    1064 24.92 33 4.91; 1065 24.92 33 9.82; 1068 4.62 33 1.08; 1069 11.74 33 1.08;
    1070 20.65 33 1.08; 1071 27.77 33 1.08; 1072 4.62 33 -2.4275;
    1073 11.74 33 -2.428; 1074 20.65 33 -2.428; 1075 27.77 33 -2.428;
    1076 2.31 33 -5.935; 1077 11.74 33 -7.835; 1078 20.65 33 -7.835;
    1079 30.01 33 -5.935; 1080 2.31 33 4.91; 1081 11.74 33 7.365;
    1082 20.65 33 7.365; 1083 30.01 33 4.91; 1084 0 36 4.91; 1085 0 36 1.08;
    1086 0 36 -5.935; 1087 4.62 36 4.91; 1088 4.62 36 -5.935; 1089 4.62 36 -9.735;
    1090 4.62 36 9.82; 1091 11.74 36 4.91; 1092 11.74 36 -5.935;
    1093 11.74 36 -9.735; 1094 11.74 36 9.82; 1095 20.65 36 4.91;
    1096 20.65 36 -5.935; 1097 20.65 36 -9.735; 1098 20.65 36 9.82;
    1099 27.77 36 4.91; 1100 27.77 36 -5.935; 1101 27.77 36 -9.735;
    1103 32.25 36 4.91; 1104 32.25 36 -5.935; 1105 32.25 36 1.08;
    1106 0 36 -2.4275; 1107 32.25 36 -2.4275; 1108 24.92 36 4.91;
    1109 24.92 36 9.82; 1112 4.62 36 1.08; 1113 11.74 36 1.08; 1114 20.65 36 1.08;
    1115 27.77 36 1.08; 1116 4.62 36 -2.4275; 1117 11.74 36 -2.428;
    1118 20.65 36 -2.428; 1119 27.77 36 -2.428; 1120 2.31 36 -5.935;
    1121 11.74 36 -7.835; 1122 20.65 36 -7.835; 1123 30.01 36 -5.935;
    1124 2.31 36 4.91; 1125 11.74 36 7.365; 1126 20.65 36 7.365;
    1127 30.01 36 4.91; 1128 0 39 4.91; 1129 0 39 1.08; 1130 0 39 -5.935;
    1131 4.62 39 4.91; 1132 4.62 39 -5.935; 1133 4.62 39 -9.735; 1134 4.62 39 9.82;
    1135 11.74 39 4.91; 1136 11.74 39 -5.935; 1137 11.74 39 -9.735;
    1138 11.74 39 9.82; 1139 20.65 39 4.91; 1140 20.65 39 -5.935;
    1141 20.65 39 -9.735; 1142 20.65 39 9.82; 1143 27.77 39 4.91;
    1144 27.77 39 -5.935; 1145 27.77 39 -9.735; 1147 32.25 39 4.91;
    1148 32.25 39 -5.935; 1149 32.25 39 1.08; 1150 0 39 -2.4275;
    1151 32.25 39 -2.4275; 1152 24.92 39 4.91; 1153 24.92 39 9.82;
    1156 4.62 39 1.08; 1157 11.74 39 1.08; 1158 20.65 39 1.08; 1159 27.77 39 1.08;
    1160 4.62 39 -2.4275; 1161 11.74 39 -2.428; 1162 20.65 39 -2.428;
    1163 27.77 39 -2.428; 1164 2.31 39 -5.935; 1165 11.74 39 -7.835;
    1166 20.65 39 -7.835; 1167 30.01 39 -5.935; 1168 2.31 39 4.91;
    1169 11.74 39 7.365; 1170 20.65 39 7.365; 1171 30.01 39 4.91; 1172 0 42 4.91;
    1173 0 42 1.08; 1174 0 42 -5.935; 1175 4.62 42 4.91; 1176 4.62 42 -5.935;
    1177 4.62 42 -9.735; 1178 4.62 42 9.82; 1179 11.74 42 4.91;
    1180 11.74 42 -5.935; 1181 11.74 42 -9.735; 1182 11.74 42 9.82;
    1183 20.65 42 4.91; 1184 20.65 42 -5.935; 1185 20.65 42 -9.735;
    1186 20.65 42 9.82; 1187 27.77 42 4.91; 1188 27.77 42 -5.935;
    1189 27.77 42 -9.735; 1191 32.25 42 4.91; 1192 32.25 42 -5.935;
    1193 32.25 42 1.08; 1194 0 42 -2.4275; 1195 32.25 42 -2.4275;
    1196 24.92 42 4.91; 1197 24.92 42 9.82; 1200 4.62 42 1.08; 1201 11.74 42 1.08;
    1202 20.65 42 1.08; 1203 27.77 42 1.08; 1204 4.62 42 -2.4275;
    1205 11.74 42 -2.428; 1206 20.65 42 -2.428; 1207 27.77 42 -2.428;
    1208 2.31 42 -5.935; 1209 11.74 42 -7.835; 1210 20.65 42 -7.835;
    1211 30.01 42 -5.935; 1212 2.31 42 4.91; 1213 11.74 42 7.365;
    1214 20.65 42 7.365; 1215 30.01 42 4.91; 1216 0 45 4.91; 1217 0 45 1.08;
    1218 0 45 -5.935; 1219 4.62 45 4.91; 1220 4.62 45 -5.935; 1221 4.62 45 -9.735;
    1222 4.62 45 9.82; 1223 11.74 45 4.91; 1224 11.74 45 -5.935;
    1225 11.74 45 -9.735; 1226 11.74 45 9.82; 1227 20.65 45 4.91;
    1228 20.65 45 -5.935; 1229 20.65 45 -9.735; 1230 20.65 45 9.82;
    1231 27.77 45 4.91; 1232 27.77 45 -5.935; 1233 27.77 45 -9.735;
    1235 32.25 45 4.91; 1236 32.25 45 -5.935; 1237 32.25 45 1.08;
    1238 0 45 -2.4275; 1239 32.25 45 -2.4275; 1240 24.92 45 4.91;
    1241 24.92 45 9.82; 1244 4.62 45 1.08; 1245 11.74 45 1.08; 1246 20.65 45 1.08;
    1247 27.77 45 1.08; 1248 4.62 45 -2.4275; 1249 11.74 45 -2.428;
    1250 20.65 45 -2.428; 1251 27.77 45 -2.428; 1252 2.31 45 -5.935;
    1253 11.74 45 -7.835; 1254 20.65 45 -7.835; 1255 30.01 45 -5.935;
    1256 2.31 45 4.91; 1257 11.74 45 7.365; 1258 20.65 45 7.365;
    1259 30.01 45 4.91; 1260 0 48 4.91; 1261 0 48 1.08; 1262 0 48 -5.935;
    1263 4.62 48 4.91; 1264 4.62 48 -5.935; 1265 4.62 48 -9.735; 1266 4.62 48 9.82;
    1267 11.74 48 4.91; 1268 11.74 48 -5.935; 1269 11.74 48 -9.735;
    1270 11.74 48 9.82; 1271 20.65 48 4.91; 1272 20.65 48 -5.935;
    1273 20.65 48 -9.735; 1274 20.65 48 9.82; 1275 27.77 48 4.91;
    1276 27.77 48 -5.935; 1277 27.77 48 -9.735; 1279 32.25 48 4.91;
    1280 32.25 48 -5.935; 1281 32.25 48 1.08; 1282 0 48 -2.4275;
    1283 32.25 48 -2.4275; 1284 24.92 48 4.91; 1285 24.92 48 9.82;
    1288 4.62 48 1.08; 1289 11.74 48 1.08; 1290 20.65 48 1.08; 1291 27.77 48 1.08;
    1292 4.62 48 -2.4275; 1293 11.74 48 -2.428; 1294 20.65 48 -2.428;
    1295 27.77 48 -2.428; 1296 2.31 48 -5.935; 1297 11.74 48 -7.835;
    1298 20.65 48 -7.835; 1299 30.01 48 -5.935; 1300 2.31 48 4.91;
    1301 11.74 48 7.365; 1302 20.65 48 7.365; 1303 30.01 48 4.91; 1304 0 51 4.91;
    1305 0 51 1.08; 1306 0 51 -5.935; 1307 4.62 51 4.91; 1308 4.62 51 -5.935;
    1309 4.62 51 -9.735; 1310 4.62 51 9.82; 1311 11.74 51 4.91;
    1312 11.74 51 -5.935; 1313 11.74 51 -9.735; 1314 11.74 51 9.82;
    1315 20.65 51 4.91; 1316 20.65 51 -5.935; 1317 20.65 51 -9.735;
    1318 20.65 51 9.82; 1319 27.77 51 4.91; 1320 27.77 51 -5.935;
    1321 27.77 51 -9.735; 1323 32.25 51 4.91; 1324 32.25 51 -5.935;
    1325 32.25 51 1.08; 1326 0 51 -2.4275; 1327 32.25 51 -2.4275;
    1328 24.92 51 4.91; 1329 24.92 51 9.82; 1332 4.62 51 1.08; 1333 11.74 51 1.08;
    1334 20.65 51 1.08; 1335 27.77 51 1.08; 1336 4.62 51 -2.4275;
    1337 11.74 51 -2.428; 1338 20.65 51 -2.428; 1339 27.77 51 -2.428;
    1340 2.31 51 -5.935; 1341 11.74 51 -7.835; 1342 20.65 51 -7.835;
    1343 30.01 51 -5.935; 1344 2.31 51 4.91; 1345 11.74 51 7.365;
    1346 20.65 51 7.365; 1347 30.01 51 4.91; 1348 0 54 4.91; 1349 0 54 1.08;
    1350 0 54 -5.935; 1351 4.62 54 4.91; 1352 4.62 54 -5.935; 1353 4.62 54 -9.735;
    1354 4.62 54 9.82; 1355 11.74 54 4.91; 1356 11.74 54 -5.935;
    1357 11.74 54 -9.735; 1358 11.74 54 9.82; 1359 20.65 54 4.91;
    1360 20.65 54 -5.935; 1361 20.65 54 -9.735; 1362 20.65 54 9.82;
    1363 27.77 54 4.91; 1364 27.77 54 -5.935; 1365 27.77 54 -9.735;
    1367 32.25 54 4.91; 1368 32.25 54 -5.935; 1369 32.25 54 1.08;
    1370 0 54 -2.4275; 1371 32.25 54 -2.4275; 1372 24.92 54 4.91;
    1373 24.92 54 9.82; 1376 4.62 54 1.08; 1377 11.74 54 1.08; 1378 20.65 54 1.08;
    1379 27.77 54 1.08; 1380 4.62 54 -2.4275; 1381 11.74 54 -2.428;
    1382 20.65 54 -2.428; 1383 27.77 54 -2.428; 1384 2.31 54 -5.935;
    1385 11.74 54 -7.835; 1386 20.65 54 -7.835; 1387 30.01 54 -5.935;
    1388 2.31 54 4.91; 1389 11.74 54 7.365; 1390 20.65 54 7.365;
    1391 30.01 54 4.91; 1392 0 57 4.91; 1393 0 57 1.08; 1394 0 57 -5.935;
    1395 4.62 57 4.91; 1396 4.62 57 -5.935; 1397 4.62 57 -9.735; 1398 4.62 57 9.82;
    1399 11.74 57 4.91; 1400 11.74 57 -5.935; 1401 11.74 57 -9.735;
    1402 11.74 57 9.82; 1403 20.65 57 4.91; 1404 20.65 57 -5.935;
    1405 20.65 57 -9.735; 1406 20.65 57 9.82; 1407 27.77 57 4.91;
    1408 27.77 57 -5.935; 1409 27.77 57 -9.735; 1411 32.25 57 4.91;
    1412 32.25 57 -5.935; 1413 32.25 57 1.08; 1414 0 57 -2.4275;
    1415 32.25 57 -2.4275; 1416 24.92 57 4.91; 1417 24.92 57 9.82;
    1420 4.62 57 1.08; 1421 11.74 57 1.08; 1422 20.65 57 1.08; 1423 27.77 57 1.08;
    1424 4.62 57 -2.4275; 1425 11.74 57 -2.428; 1426 20.65 57 -2.428;
    1427 27.77 57 -2.428; 1428 2.31 57 -5.935; 1429 11.74 57 -7.835;
    1430 20.65 57 -7.835; 1431 30.01 57 -5.935; 1432 2.31 57 4.91;
    1433 11.74 57 7.365; 1434 20.65 57 7.365; 1435 30.01 57 4.91; 1436 0 60 4.91;
    1437 0 60 1.08; 1438 0 60 -5.935; 1439 4.62 60 4.91; 1440 4.62 60 -5.935;
    1441 4.62 60 -9.735; 1442 4.62 60 9.82; 1443 11.74 60 4.91;
    1444 11.74 60 -5.935; 1445 11.74 60 -9.735; 1446 11.74 60 9.82;
    1447 20.65 60 4.91; 1448 20.65 60 -5.935; 1449 20.65 60 -9.735;
    1450 20.65 60 9.82; 1451 27.77 60 4.91; 1452 27.77 60 -5.935;
    1453 27.77 60 -9.735; 1455 32.25 60 4.91; 1456 32.25 60 -5.935;
    1457 32.25 60 1.08; 1458 0 60 -2.4275; 1459 32.25 60 -2.4275;
    1460 24.92 60 4.91; 1461 24.92 60 9.82; 1464 4.62 60 1.08; 1465 11.74 60 1.08;
    1466 20.65 60 1.08; 1467 27.77 60 1.08; 1468 4.62 60 -2.4275;
    1469 11.74 60 -2.428; 1470 20.65 60 -2.428; 1471 27.77 60 -2.428;
    1472 2.31 60 -5.935; 1473 11.74 60 -7.835; 1474 20.65 60 -7.835;
    1475 30.01 60 -5.935; 1476 2.31 60 4.91; 1477 11.74 60 7.365;
    1478 20.65 60 7.365; 1479 30.01 60 4.91; 1480 0 63 4.91; 1481 0 63 1.08;
    1482 0 63 -5.935; 1483 4.62 63 4.91; 1484 4.62 63 -5.935; 1485 4.62 63 -9.735;
    1486 4.62 63 9.82; 1487 11.74 63 4.91; 1488 11.74 63 -5.935;
    1489 11.74 63 -9.735; 1490 11.74 63 9.82; 1491 20.65 63 4.91;
    1492 20.65 63 -5.935; 1493 20.65 63 -9.735; 1494 20.65 63 9.82;
    1495 27.77 63 4.91; 1496 27.77 63 -5.935; 1497 27.77 63 -9.735;
    1499 32.25 63 4.91; 1500 32.25 63 -5.935; 1501 32.25 63 1.08;
    1502 0 63 -2.4275; 1503 32.25 63 -2.4275; 1504 24.92 63 4.91;
    1505 24.92 63 9.82; 1508 4.62 63 1.08; 1509 11.74 63 1.08; 1510 20.65 63 1.08;
    1511 27.77 63 1.08; 1512 4.62 63 -2.4275; 1513 11.74 63 -2.428;
    1514 20.65 63 -2.428; 1515 27.77 63 -2.428; 1516 2.31 63 -5.935;
    1517 11.74 63 -7.835; 1518 20.65 63 -7.835; 1519 30.01 63 -5.935;
    1520 2.31 63 4.91; 1521 11.74 63 7.365; 1522 20.65 63 7.365;
    1523 30.01 63 4.91; 1524 0 66 4.91; 1525 0 66 1.08; 1526 0 66 -5.935;
    1527 4.62 66 4.91; 1528 4.62 66 -5.935; 1529 4.62 66 -9.735; 1530 4.62 66 9.82;
    1531 11.74 66 4.91; 1532 11.74 66 -5.935; 1533 11.74 66 -9.735;
    1534 11.74 66 9.82; 1535 20.65 66 4.91; 1536 20.65 66 -5.935;
    1537 20.65 66 -9.735; 1538 20.65 66 9.82; 1539 27.77 66 4.91;
    1540 27.77 66 -5.935; 1541 27.77 66 -9.735; 1543 32.25 66 4.91;
    1544 32.25 66 -5.935; 1545 32.25 66 1.08; 1546 0 66 -2.4275;
    1547 32.25 66 -2.4275; 1548 24.92 66 4.91; 1549 24.92 66 9.82;
    1552 4.62 66 1.08; 1553 11.74 66 1.08; 1554 20.65 66 1.08; 1555 27.77 66 1.08;
    1556 4.62 66 -2.4275; 1557 11.74 66 -2.428; 1558 20.65 66 -2.428;
    1559 27.77 66 -2.428; 1560 2.31 66 -5.935; 1561 11.74 66 -7.835;
    1562 20.65 66 -7.835; 1563 30.01 66 -5.935; 1564 2.31 66 4.91;
    1565 11.74 66 7.365; 1566 20.65 66 7.365; 1567 30.01 66 4.91; 1568 0 69 4.91;
    1569 0 69 1.08; 1570 0 69 -5.935; 1571 4.62 69 4.91; 1572 4.62 69 -5.935;
    1573 4.62 69 -9.735; 1574 4.62 69 9.82; 1575 11.74 69 4.91;
    1576 11.74 69 -5.935; 1577 11.74 69 -9.735; 1578 11.74 69 9.82;
    1579 20.65 69 4.91; 1580 20.65 69 -5.935; 1581 20.65 69 -9.735;
    1582 20.65 69 9.82; 1583 27.77 69 4.91; 1584 27.77 69 -5.935;
    1585 27.77 69 -9.735; 1587 32.25 69 4.91; 1588 32.25 69 -5.935;
    1589 32.25 69 1.08; 1590 0 69 -2.4275; 1591 32.25 69 -2.4275;
    1592 24.92 69 4.91; 1593 24.92 69 9.82; 1596 4.62 69 1.08; 1597 11.74 69 1.08;
    1598 20.65 69 1.08; 1599 27.77 69 1.08; 1600 4.62 69 -2.4275;
    1601 11.74 69 -2.428; 1602 20.65 69 -2.428; 1603 27.77 69 -2.428;
    1604 2.31 69 -5.935; 1605 11.74 69 -7.835; 1606 20.65 69 -7.835;
    1607 30.01 69 -5.935; 1608 2.31 69 4.91; 1609 11.74 69 7.365;
    1610 20.65 69 7.365; 1611 30.01 69 4.91; 1612 0 72 4.91; 1613 0 72 1.08;
    1614 0 72 -5.935; 1615 4.62 72 4.91; 1616 4.62 72 -5.935; 1617 4.62 72 -9.735;
    1618 4.62 72 9.82; 1619 11.74 72 4.91; 1620 11.74 72 -5.935;
    1621 11.74 72 -9.735; 1622 11.74 72 9.82; 1623 20.65 72 4.91;
    1624 20.65 72 -5.935; 1625 20.65 72 -9.735; 1626 20.65 72 9.82;
    1627 27.77 72 4.91; 1628 27.77 72 -5.935; 1629 27.77 72 -9.735;
    1631 32.25 72 4.91; 1632 32.25 72 -5.935; 1633 32.25 72 1.08;
    1634 0 72 -2.4275; 1635 32.25 72 -2.4275; 1636 24.92 72 4.91;
    1637 24.92 72 9.82; 1640 4.62 72 1.08; 1641 11.74 72 1.08; 1642 20.65 72 1.08;
    1643 27.77 72 1.08; 1644 4.62 72 -2.4275; 1645 11.74 72 -2.428;
    1646 20.65 72 -2.428; 1647 27.77 72 -2.428; 1648 2.31 72 -5.935;
    1649 11.74 72 -7.835; 1650 20.65 72 -7.835; 1651 30.01 72 -5.935;
    1652 2.31 72 4.91; 1653 11.74 72 7.365; 1654 20.65 72 7.365;
    1655 30.01 72 4.91; 1656 0 75 4.91; 1657 0 75 1.08; 1658 0 75 -5.935;
    1659 4.62 75 4.91; 1660 4.62 75 -5.935; 1661 4.62 75 -9.735; 1662 4.62 75 9.82;
    1663 11.74 75 4.91; 1664 11.74 75 -5.935; 1665 11.74 75 -9.735;
    1666 11.74 75 9.82; 1667 20.65 75 4.91; 1668 20.65 75 -5.935;
    1669 20.65 75 -9.735; 1670 20.65 75 9.82; 1671 27.77 75 4.91;
    1672 27.77 75 -5.935; 1673 27.77 75 -9.735; 1675 32.25 75 4.91;
    1676 32.25 75 -5.935; 1677 32.25 75 1.08; 1678 0 75 -2.4275;
    1679 32.25 75 -2.4275; 1680 24.92 75 4.91; 1681 24.92 75 9.82;
    1684 4.62 75 1.08; 1685 11.74 75 1.08; 1686 20.65 75 1.08; 1687 27.77 75 1.08;
    1688 4.62 75 -2.4275; 1689 11.74 75 -2.428; 1690 20.65 75 -2.428;
    1691 27.77 75 -2.428; 1692 2.31 75 -5.935; 1693 11.74 75 -7.835;
    1694 20.65 75 -7.835; 1695 30.01 75 -5.935; 1696 2.31 75 4.91;
    1697 11.74 75 7.365; 1698 20.65 75 7.365; 1699 30.01 75 4.91; 1700 0 78 4.91;
    1701 0 78 1.08; 1702 0 78 -5.935; 1703 4.62 78 4.91; 1704 4.62 78 -5.935;
    1705 4.62 78 -9.735; 1706 4.62 78 9.82; 1707 11.74 78 4.91;
    1708 11.74 78 -5.935; 1709 11.74 78 -9.735; 1710 11.74 78 9.82;
    1711 20.65 78 4.91; 1712 20.65 78 -5.935; 1713 20.65 78 -9.735;
    1714 20.65 78 9.82; 1715 27.77 78 4.91; 1716 27.77 78 -5.935;
    1717 27.77 78 -9.735; 1719 32.25 78 4.91; 1720 32.25 78 -5.935;
    1721 32.25 78 1.08; 1722 0 78 -2.4275; 1723 32.25 78 -2.4275;
    1724 24.92 78 4.91; 1725 24.92 78 9.82; 1728 4.62 78 1.08; 1729 11.74 78 1.08;
    1730 20.65 78 1.08; 1731 27.77 78 1.08; 1732 4.62 78 -2.4275;
    1733 11.74 78 -2.428; 1734 20.65 78 -2.428; 1735 27.77 78 -2.428;
    1736 2.31 78 -5.935; 1737 11.74 78 -7.835; 1738 20.65 78 -7.835;
    1739 30.01 78 -5.935; 1740 2.31 78 4.91; 1741 11.74 78 7.365;
    1742 20.65 78 7.365; 1743 30.01 78 4.91; 1744 0 81 4.91; 1745 0 81 1.08;
    1746 0 81 -5.935; 1747 4.62 81 4.91; 1748 4.62 81 -5.935; 1749 4.62 81 -9.735;
    1750 4.62 81 9.82; 1751 11.74 81 4.91; 1752 11.74 81 -5.935;
    1753 11.74 81 -9.735; 1754 11.74 81 9.82; 1755 20.65 81 4.91;
    1756 20.65 81 -5.935; 1757 20.65 81 -9.735; 1758 20.65 81 9.82;
    1759 27.77 81 4.91; 1760 27.77 81 -5.935; 1761 27.77 81 -9.735;
    1763 32.25 81 4.91; 1764 32.25 81 -5.935; 1765 32.25 81 1.08;
    1766 0 81 -2.4275; 1767 32.25 81 -2.4275; 1768 24.92 81 4.91;
    1769 24.92 81 9.82; 1772 4.62 81 1.08; 1773 11.74 81 1.08; 1774 20.65 81 1.08;
    1775 27.77 81 1.08; 1776 4.62 81 -2.4275; 1777 11.74 81 -2.428;
    1778 20.65 81 -2.428; 1779 27.77 81 -2.428; 1780 2.31 81 -5.935;
    1781 11.74 81 -7.835; 1782 20.65 81 -7.835; 1783 30.01 81 -5.935;
    1784 2.31 81 4.91; 1785 11.74 81 7.365; 1786 20.65 81 7.365;
    1787 30.01 81 4.91; 1788 0 84 4.91; 1789 0 84 1.08; 1790 0 84 -5.935;
    1791 4.62 84 4.91; 1792 4.62 84 -5.935; 1793 4.62 84 -9.735; 1794 4.62 84 9.82;
    1795 11.74 84 4.91; 1796 11.74 84 -5.935; 1797 11.74 84 -9.735;
    1798 11.74 84 9.82; 1799 20.65 84 4.91; 1800 20.65 84 -5.935;
    1801 20.65 84 -9.735; 1802 20.65 84 9.82; 1803 27.77 84 4.91;
    1804 27.77 84 -5.935; 1805 27.77 84 -9.735; 1807 32.25 84 4.91;
    1808 32.25 84 -5.935; 1809 32.25 84 1.08; 1810 0 84 -2.4275;
    1811 32.25 84 -2.4275; 1812 24.92 84 4.91; 1813 24.92 84 9.82;
    1816 4.62 84 1.08; 1817 11.74 84 1.08; 1818 20.65 84 1.08; 1819 27.77 84 1.08;
    1820 4.62 84 -2.4275; 1821 11.74 84 -2.428; 1822 20.65 84 -2.428;
    1823 27.77 84 -2.428; 1824 2.31 84 -5.935; 1825 11.74 84 -7.835;
    1826 20.65 84 -7.835; 1827 30.01 84 -5.935; 1828 2.31 84 4.91;
    1829 11.74 84 7.365; 1830 20.65 84 7.365; 1831 30.01 84 4.91; 1832 0 87 4.91;
    1833 0 87 1.08; 1834 0 87 -5.935; 1835 4.62 87 4.91; 1836 4.62 87 -5.935;
    1837 4.62 87 -9.735; 1838 4.62 87 9.82; 1839 11.74 87 4.91;
    1840 11.74 87 -5.935; 1841 11.74 87 -9.735; 1842 11.74 87 9.82;
    1843 20.65 87 4.91; 1844 20.65 87 -5.935; 1845 20.65 87 -9.735;
    1846 20.65 87 9.82; 1847 27.77 87 4.91; 1848 27.77 87 -5.935;
    1849 27.77 87 -9.735; 1851 32.25 87 4.91; 1852 32.25 87 -5.935;
    1853 32.25 87 1.08; 1854 0 87 -2.4275; 1855 32.25 87 -2.4275;
    1856 24.92 87 4.91; 1857 24.92 87 9.82; 1860 4.62 87 1.08; 1861 11.74 87 1.08;
    1862 20.65 87 1.08; 1863 27.77 87 1.08; 1864 4.62 87 -2.4275;
    1865 11.74 87 -2.428; 1866 20.65 87 -2.428; 1867 27.77 87 -2.428;
    1868 2.31 87 -5.935; 1869 11.74 87 -7.835; 1870 20.65 87 -7.835;
    1871 30.01 87 -5.935; 1872 2.31 87 4.91; 1873 11.74 87 7.365;
    1874 20.65 87 7.365; 1875 30.01 87 4.91; 1876 0 90 4.91; 1877 0 90 1.08;
    1878 0 90 -5.935; 1879 4.62 90 4.91; 1880 4.62 90 -5.935; 1881 4.62 90 -9.735;
    1882 4.62 90 9.82; 1883 11.74 90 4.91; 1884 11.74 90 -5.935;
    1885 11.74 90 -9.735; 1886 11.74 90 9.82; 1887 20.65 90 4.91;
    1888 20.65 90 -5.935; 1889 20.65 90 -9.735; 1890 20.65 90 9.82;
    1891 27.77 90 4.91; 1892 27.77 90 -5.935; 1893 27.77 90 -9.735;
    1895 32.25 90 4.91; 1896 32.25 90 -5.935; 1897 32.25 90 1.08;
    1898 0 90 -2.4275; 1899 32.25 90 -2.4275; 1900 24.92 90 4.91;
    1901 24.92 90 9.82; 1904 4.62 90 1.08; 1905 11.74 90 1.08; 1906 20.65 90 1.08;
    1907 27.77 90 1.08; 1908 4.62 90 -2.4275; 1909 11.74 90 -2.428;
    1910 20.65 90 -2.428; 1911 27.77 90 -2.428; 1912 2.31 90 -5.935;
    1913 11.74 90 -7.835; 1914 20.65 90 -7.835; 1915 30.01 90 -5.935;
    1916 2.31 90 4.91; 1917 11.74 90 7.365; 1918 20.65 90 7.365;
    1919 30.01 90 4.91; 1920 4.62 -3 1.08; 1921 11.74 -3 1.08; 1922 20.65 -3 1.08;
    1923 27.77 -3 1.08; 1924 4.62 -3 -2.4275; 1925 11.74 -3 -2.428;
    1926 20.65 -3 -2.428; 1927 27.77 -3 -2.428; 1928 26.345 0 4.91;
    1929 26.345 0 9.82; 1930 26.345 0 7.365; 2021 26.345 -3 7.365;
    2022 26.345 -3 4.91; 2023 26.345 -3 9.82; 2024 27.77 -3 7.365;
    2025 27.77 0 9.82; 2026 24.92 0 7.365; 2027 27.77 3 7.365; 2028 26.345 3 4.91;
    2029 26.345 3 9.82; 2030 26.345 3 7.365; 2031 27.77 3 9.82; 2032 24.92 3 7.365;
    2033 27.77 6 7.365; 2034 26.345 6 4.91; 2035 26.345 6 9.82;
    2036 26.345 6 7.365; 2037 27.77 6 9.82; 2038 24.92 6 7.365; 2039 27.77 9 7.365;
    2040 26.345 9 4.91; 2041 26.345 9 9.82; 2042 26.345 9 7.365; 2043 27.77 9 9.82;
    2044 24.92 9 7.365; 2045 27.77 12 7.365; 2046 26.345 12 4.91;
    2047 26.345 12 9.82; 2048 26.345 12 7.365; 2049 27.77 12 9.82;
    2050 24.92 12 7.365; 2051 27.77 15 7.365; 2052 26.345 15 4.91;
    2053 26.345 15 9.82; 2054 26.345 15 7.365; 2055 27.77 15 9.82;
    2056 24.92 15 7.365; 2057 27.77 18 7.365; 2058 26.345 18 4.91;
    2059 26.345 18 9.82; 2060 26.345 18 7.365; 2061 27.77 18 9.82;
    2062 24.92 18 7.365; 2063 27.77 21 7.365; 2064 26.345 21 4.91;
    2065 26.345 21 9.82; 2066 26.345 21 7.365; 2067 27.77 21 9.82;
    2068 24.92 21 7.365; 2069 27.77 24 7.365; 2070 26.345 24 4.91;
    2071 26.345 24 9.82; 2072 26.345 24 7.365; 2073 27.77 24 9.82;
    2074 24.92 24 7.365; 2075 27.77 27 7.365; 2076 26.345 27 4.91;
    2077 26.345 27 9.82; 2078 26.345 27 7.365; 2079 27.77 27 9.82;
    2080 24.92 27 7.365; 2081 27.77 30 7.365; 2082 26.345 30 4.91;
    2083 26.345 30 9.82; 2084 26.345 30 7.365; 2085 27.77 30 9.82;
    2086 24.92 30 7.365; 2087 27.77 33 7.365; 2088 26.345 33 4.91;
    2089 26.345 33 9.82; 2090 26.345 33 7.365; 2091 27.77 33 9.82;
    2092 24.92 33 7.365; 2093 27.77 36 7.365; 2094 26.345 36 4.91;
    2095 26.345 36 9.82; 2096 26.345 36 7.365; 2097 27.77 36 9.82;
    2098 24.92 36 7.365; 2099 27.77 39 7.365; 2100 26.345 39 4.91;
    2101 26.345 39 9.82; 2102 26.345 39 7.365; 2103 27.77 39 9.82;
    2104 24.92 39 7.365; 2105 27.77 42 7.365; 2106 26.345 42 4.91;
    2107 26.345 42 9.82; 2108 26.345 42 7.365; 2109 27.77 42 9.82;
    2110 24.92 42 7.365; 2111 27.77 45 7.365; 2112 26.345 45 4.91;
    2113 26.345 45 9.82; 2114 26.345 45 7.365; 2115 27.77 45 9.82;
    2116 24.92 45 7.365; 2117 27.77 48 7.365; 2118 26.345 48 4.91;
    2119 26.345 48 9.82; 2120 26.345 48 7.365; 2121 27.77 48 9.82;
    2122 24.92 48 7.365; 2123 27.77 51 7.365; 2124 26.345 51 4.91;
    2125 26.345 51 9.82; 2126 26.345 51 7.365; 2127 27.77 51 9.82;
    2128 24.92 51 7.365; 2129 27.77 54 7.365; 2130 26.345 54 4.91;
    2131 26.345 54 9.82; 2132 26.345 54 7.365; 2133 27.77 54 9.82;
    2134 24.92 54 7.365; 2135 27.77 57 7.365; 2136 26.345 57 4.91;
    2137 26.345 57 9.82; 2138 26.345 57 7.365; 2139 27.77 57 9.82;
    2140 24.92 57 7.365; 2141 27.77 60 7.365; 2142 26.345 60 4.91;
    2143 26.345 60 9.82; 2144 26.345 60 7.365; 2145 27.77 60 9.82;
    2146 24.92 60 7.365; 2147 27.77 63 7.365; 2148 26.345 63 4.91;
    2149 26.345 63 9.82; 2150 26.345 63 7.365; 2151 27.77 63 9.82;
    2152 24.92 63 7.365; 2153 27.77 66 7.365; 2154 26.345 66 4.91;
    2155 26.345 66 9.82; 2156 26.345 66 7.365; 2157 27.77 66 9.82;
    2158 24.92 66 7.365; 2159 27.77 69 7.365; 2160 26.345 69 4.91;
    2161 26.345 69 9.82; 2162 26.345 69 7.365; 2163 27.77 69 9.82;
    2164 24.92 69 7.365; 2165 27.77 72 7.365; 2166 26.345 72 4.91;
    2167 26.345 72 9.82; 2168 26.345 72 7.365; 2169 27.77 72 9.82;
    2170 24.92 72 7.365; 2171 27.77 75 7.365; 2172 26.345 75 4.91;
    2173 26.345 75 9.82; 2174 26.345 75 7.365; 2175 27.77 75 9.82;
    2176 24.92 75 7.365; 2177 27.77 78 7.365; 2178 26.345 78 4.91;
    2179 26.345 78 9.82; 2180 26.345 78 7.365; 2181 27.77 78 9.82;
    2182 24.92 78 7.365; 2183 27.77 81 7.365; 2184 26.345 81 4.91;
    2185 26.345 81 9.82; 2186 26.345 81 7.365; 2187 27.77 81 9.82;
    2188 24.92 81 7.365; 2189 27.77 84 7.365; 2190 26.345 84 4.91;
    2191 26.345 84 9.82; 2192 26.345 84 7.365; 2193 27.77 84 9.82;
    2194 24.92 84 7.365; 2195 27.77 87 7.365; 2196 26.345 87 4.91;
    2197 26.345 87 9.82; 2198 26.345 87 7.365; 2199 27.77 87 9.82;
    2200 24.92 87 7.365; 2201 27.77 90 7.365; 2202 26.345 90 4.91;
    2203 26.345 90 9.82; 2204 26.345 90 7.365; 2205 27.77 90 9.82;
    2206 24.92 90 7.365;
    MEMBER INCIDENCES
    6 8 30; 7 9 31; 18 20 42; 23 7 8; 24 8 12; 26 11 15; 28 16 20; 29 20 19;
    31 23 47; 34 6 9; 35 9 13; 37 10 14; 39 17 53; 42 2 56; 43 3 46; 44 46 1;
    45 47 22; 46 46 60; 47 7 60; 48 11 61; 49 15 62; 50 19 63; 51 7 11; 52 15 19;
    53 6 10; 54 14 52; 55 3 49; 56 1 48; 57 22 50; 58 23 51; 59 49 48; 60 51 50;
    65 52 2026; 66 56 57; 67 56 6; 68 57 10; 69 57 58; 70 58 14; 71 58 59;
    72 59 18; 73 59 24; 74 60 61; 75 60 56; 76 61 57; 77 61 62; 78 62 58; 79 62 63;
    80 63 59; 81 63 47; 872 464 552; 873 465 553; 874 466 554; 875 467 555;
    876 468 556; 877 469 557; 878 470 558; 879 471 559; 880 565 8; 881 566 9;
    882 577 20; 884 564 565; 885 565 569; 886 568 572; 887 573 577; 888 577 576;
    889 580 583; 890 563 566; 891 566 570; 892 567 571; 893 574 589; 895 561 592;
    896 562 582; 897 582 560; 898 583 579; 899 582 596; 900 564 596; 901 568 597;
    902 572 598; 903 576 599; 904 564 568; 905 572 576; 906 563 567; 907 571 588;
    908 562 585; 909 560 584; 910 579 586; 911 580 587; 912 585 584; 913 587 586;
    918 588 2032; 919 592 593; 920 592 563; 921 593 567; 922 593 594; 923 594 571;
    924 594 595; 925 595 575; 926 595 581; 927 596 597; 928 596 592; 929 597 593;
    930 597 598; 931 598 594; 932 598 599; 933 599 595; 934 599 583; 935 600 464;
    936 601 465; 937 602 466; 938 603 467; 939 604 468; 940 605 469; 941 606 470;
    942 607 471; 943 613 565; 944 614 566; 945 625 577; 947 612 613; 948 613 617;
    949 616 620; 950 621 625; 951 625 624; 952 628 631; 953 611 614; 954 614 618;
    955 615 619; 956 622 637; 958 609 640; 959 610 630; 960 630 608; 961 631 627;
    962 630 644; 963 612 644; 964 616 645; 965 620 646; 966 624 647; 967 612 616;
    968 620 624; 969 611 615; 970 619 636; 971 610 633; 972 608 632; 973 627 634;
    974 628 635; 975 633 632; 976 635 634; 981 636 2038; 982 640 641; 983 640 611;
    984 641 615; 985 641 642; 986 642 619; 987 642 643; 988 643 623; 989 643 629;
    990 644 645; 991 644 640; 992 645 641; 993 645 646; 994 646 642; 995 646 647;
    996 647 643; 997 647 631; 998 648 600; 999 649 601; 1000 650 602; 1001 651 603;
    1002 652 604; 1003 653 605; 1004 654 606; 1005 655 607; 1006 661 613;
    1007 662 614; 1008 673 625; 1010 660 661; 1011 661 665; 1012 664 668;
    1013 669 673; 1014 673 672; 1015 676 679; 1016 659 662; 1017 662 666;
    1018 663 667; 1019 670 685; 1021 657 688; 1022 658 678; 1023 678 656;
    1024 679 675; 1025 678 692; 1026 660 692; 1027 664 693; 1028 668 694;
    1029 672 695; 1030 660 664; 1031 668 672; 1032 659 663; 1033 667 684;
    1034 658 681; 1035 656 680; 1036 675 682; 1037 676 683; 1038 681 680;
    1039 683 682; 1044 684 2044; 1045 688 689; 1046 688 659; 1047 689 663;
    1048 689 690; 1049 690 667; 1050 690 691; 1051 691 671; 1052 691 677;
    1053 692 693; 1054 692 688; 1055 693 689; 1056 693 694; 1057 694 690;
    1058 694 695; 1059 695 691; 1060 695 679; 1061 696 648; 1062 697 649;
    1063 698 650; 1064 699 651; 1065 700 652; 1066 701 653; 1067 702 654;
    1068 703 655; 1069 709 661; 1070 710 662; 1071 721 673; 1073 708 709;
    1074 709 713; 1075 712 716; 1076 717 721; 1077 721 720; 1078 724 727;
    1079 707 710; 1080 710 714; 1081 711 715; 1082 718 733; 1084 705 736;
    1085 706 726; 1086 726 704; 1087 727 723; 1088 726 740; 1089 708 740;
    1090 712 741; 1091 716 742; 1092 720 743; 1093 708 712; 1094 716 720;
    1095 707 711; 1096 715 732; 1097 706 729; 1098 704 728; 1099 723 730;
    1100 724 731; 1101 729 728; 1102 731 730; 1107 732 2050; 1108 736 737;
    1109 736 707; 1110 737 711; 1111 737 738; 1112 738 715; 1113 738 739;
    1114 739 719; 1115 739 725; 1116 740 741; 1117 740 736; 1118 741 737;
    1119 741 742; 1120 742 738; 1121 742 743; 1122 743 739; 1123 743 727;
    1124 744 696; 1125 745 697; 1126 746 698; 1127 747 699; 1128 748 700;
    1129 749 701; 1130 750 702; 1131 751 703; 1132 757 709; 1133 758 710;
    1134 769 721; 1136 756 757; 1137 757 761; 1138 760 764; 1139 765 769;
    1140 769 768; 1141 772 775; 1142 755 758; 1143 758 762; 1144 759 763;
    1145 766 781; 1147 753 784; 1148 754 774; 1149 774 752; 1150 775 771;
    1151 774 788; 1152 756 788; 1153 760 789; 1154 764 790; 1155 768 791;
    1156 756 760; 1157 764 768; 1158 755 759; 1159 763 780; 1160 754 777;
    1161 752 776; 1162 771 778; 1163 772 779; 1164 777 776; 1165 779 778;
    1170 780 2056; 1171 784 785; 1172 784 755; 1173 785 759; 1174 785 786;
    1175 786 763; 1176 786 787; 1177 787 767; 1178 787 773; 1179 788 789;
    1180 788 784; 1181 789 785; 1182 789 790; 1183 790 786; 1184 790 791;
    1185 791 787; 1186 791 775; 1187 792 744; 1188 793 745; 1189 794 746;
    1190 795 747; 1191 796 748; 1192 797 749; 1193 798 750; 1194 799 751;
    1195 805 757; 1196 806 758; 1197 817 769; 1199 804 805; 1200 805 809;
    1201 808 812; 1202 813 817; 1203 817 816; 1204 820 823; 1205 803 806;
    1206 806 810; 1207 807 811; 1208 814 829; 1210 801 832; 1211 802 822;
    1212 822 800; 1213 823 819; 1214 822 836; 1215 804 836; 1216 808 837;
    1217 812 838; 1218 816 839; 1219 804 808; 1220 812 816; 1221 803 807;
    1222 811 828; 1223 802 825; 1224 800 824; 1225 819 826; 1226 820 827;
    1227 825 824; 1228 827 826; 1233 828 2062; 1234 832 833; 1235 832 803;
    1236 833 807; 1237 833 834; 1238 834 811; 1239 834 835; 1240 835 815;
    1241 835 821; 1242 836 837; 1243 836 832; 1244 837 833; 1245 837 838;
    1246 838 834; 1247 838 839; 1248 839 835; 1249 839 823; 1250 840 792;
    1251 841 793; 1252 842 794; 1253 843 795; 1254 844 796; 1255 845 797;
    1256 846 798; 1257 847 799; 1258 853 805; 1259 854 806; 1260 865 817;
    1262 852 853; 1263 853 857; 1264 856 860; 1265 861 865; 1266 865 864;
    1267 868 871; 1268 851 854; 1269 854 858; 1270 855 859; 1271 862 877;
    1273 849 880; 1274 850 870; 1275 870 848; 1276 871 867; 1277 870 884;
    1278 852 884; 1279 856 885; 1280 860 886; 1281 864 887; 1282 852 856;
    1283 860 864; 1284 851 855; 1285 859 876; 1286 850 873; 1287 848 872;
    1288 867 874; 1289 868 875; 1290 873 872; 1291 875 874; 1296 876 2068;
    1297 880 881; 1298 880 851; 1299 881 855; 1300 881 882; 1301 882 859;
    1302 882 883; 1303 883 863; 1304 883 869; 1305 884 885; 1306 884 880;
    1307 885 881; 1308 885 886; 1309 886 882; 1310 886 887; 1311 887 883;
    1312 887 871; 1313 888 840; 1314 889 841; 1315 890 842; 1316 891 843;
    1317 892 844; 1318 893 845; 1319 894 846; 1320 895 847; 1321 901 853;
    1322 902 854; 1323 913 865; 1325 900 901; 1326 901 905; 1327 904 908;
    1328 909 913; 1329 913 912; 1330 916 919; 1331 899 902; 1332 902 906;
    1333 903 907; 1334 910 925; 1336 897 928; 1337 898 918; 1338 918 896;
    1339 919 915; 1340 918 932; 1341 900 932; 1342 904 933; 1343 908 934;
    1344 912 935; 1345 900 904; 1346 908 912; 1347 899 903; 1348 907 924;
    1349 898 921; 1350 896 920; 1351 915 922; 1352 916 923; 1353 921 920;
    1354 923 922; 1359 924 2074; 1360 928 929; 1361 928 899; 1362 929 903;
    1363 929 930; 1364 930 907; 1365 930 931; 1366 931 911; 1367 931 917;
    1368 932 933; 1369 932 928; 1370 933 929; 1371 933 934; 1372 934 930;
    1373 934 935; 1374 935 931; 1375 935 919; 1376 936 888; 1377 937 889;
    1378 938 890; 1379 939 891; 1380 940 892; 1381 941 893; 1382 942 894;
    1383 943 895; 1384 949 901; 1385 950 902; 1386 961 913; 1388 948 949;
    1389 949 953; 1390 952 956; 1391 957 961; 1392 961 960; 1393 964 967;
    1394 947 950; 1395 950 954; 1396 951 955; 1397 958 973; 1399 945 976;
    1400 946 966; 1401 966 944; 1402 967 963; 1403 966 980; 1404 948 980;
    1405 952 981; 1406 956 982; 1407 960 983; 1408 948 952; 1409 956 960;
    1410 947 951; 1411 955 972; 1412 946 969; 1413 944 968; 1414 963 970;
    1415 964 971; 1416 969 968; 1417 971 970; 1422 972 2080; 1423 976 977;
    1424 976 947; 1425 977 951; 1426 977 978; 1427 978 955; 1428 978 979;
    1429 979 959; 1430 979 965; 1431 980 981; 1432 980 976; 1433 981 977;
    1434 981 982; 1435 982 978; 1436 982 983; 1437 983 979; 1438 983 967;
    1439 984 936; 1440 985 937; 1441 986 938; 1442 987 939; 1443 988 940;
    1444 989 941; 1445 990 942; 1446 991 943; 1447 997 949; 1448 998 950;
    1449 1009 961; 1451 996 997; 1452 997 1001; 1453 1000 1004; 1454 1005 1009;
    1455 1009 1008; 1456 1012 1015; 1457 995 998; 1458 998 1002; 1459 999 1003;
    1460 1006 1021; 1462 993 1024; 1463 994 1014; 1464 1014 992; 1465 1015 1011;
    1466 1014 1028; 1467 996 1028; 1468 1000 1029; 1469 1004 1030; 1470 1008 1031;
    1471 996 1000; 1472 1004 1008; 1473 995 999; 1474 1003 1020; 1475 994 1017;
    1476 992 1016; 1477 1011 1018; 1478 1012 1019; 1479 1017 1016; 1480 1019 1018;
    1485 1020 2086; 1486 1024 1025; 1487 1024 995; 1488 1025 999; 1489 1025 1026;
    1490 1026 1003; 1491 1026 1027; 1492 1027 1007; 1493 1027 1013; 1494 1028 1029;
    1495 1028 1024; 1496 1029 1025; 1497 1029 1030; 1498 1030 1026; 1499 1030 1031;
    1500 1031 1027; 1501 1031 1015; 1502 1032 984; 1503 1033 985; 1504 1034 986;
    1505 1035 987; 1506 1036 988; 1507 1037 989; 1508 1038 990; 1509 1039 991;
    1510 3 7; 1511 1 6; 1512 12 11; 1513 16 15; 1514 14 17; 1515 10 13; 1516 19 23;
    1517 18 22; 1518 562 564; 1519 560 563; 1520 569 568; 1521 573 572;
    1522 571 574; 1523 567 570; 1524 576 580; 1525 575 579; 1526 610 612;
    1527 608 611; 1528 617 616; 1529 621 620; 1530 619 622; 1531 615 618;
    1532 624 628; 1533 623 627; 1534 658 660; 1535 656 659; 1536 665 664;
    1537 669 668; 1538 667 670; 1539 663 666; 1540 672 676; 1541 671 675;
    1542 706 708; 1543 704 707; 1544 713 712; 1545 717 716; 1546 715 718;
    1547 711 714; 1548 720 724; 1549 719 723; 1550 754 756; 1551 752 755;
    1552 761 760; 1553 765 764; 1554 763 766; 1555 759 762; 1556 768 772;
    1557 767 771; 1558 802 804; 1559 800 803; 1560 809 808; 1561 813 812;
    1562 811 814; 1563 807 810; 1564 816 820; 1565 815 819; 1566 850 852;
    1567 848 851; 1568 857 856; 1569 861 860; 1570 859 862; 1571 855 858;
    1572 864 868; 1573 863 867; 1574 898 900; 1575 896 899; 1576 905 904;
    1577 909 908; 1578 907 910; 1579 903 906; 1580 912 916; 1581 911 915;
    1582 946 948; 1583 944 947; 1584 953 952; 1585 957 956; 1586 955 958;
    1587 951 954; 1588 960 964; 1589 959 963; 1590 994 996; 1591 992 995;
    1592 1001 1000; 1593 1005 1004; 1594 1003 1006; 1595 999 1002; 1596 1008 1012;
    1597 1007 1011; 1598 1045 997; 1599 1046 998; 1600 1057 1009; 1602 1044 1045;
    1603 1045 1049; 1604 1048 1052; 1605 1053 1057; 1606 1057 1056; 1607 1060 1063;
    1608 1043 1046; 1609 1046 1050; 1610 1047 1051; 1611 1054 1065; 1613 1041 1068;
    1614 1042 1062; 1615 1062 1040; 1616 1063 1059; 1617 1062 1072; 1618 1044 1072;
    1619 1048 1073; 1620 1052 1074; 1621 1056 1075; 1622 1044 1048; 1623 1052 1056;
    1624 1043 1047; 1625 1051 1064; 1630 1064 2092; 1631 1068 1069; 1632 1068 1043;
    1633 1069 1047; 1634 1069 1070; 1635 1070 1051; 1636 1070 1071; 1637 1071 1055;
    1638 1071 1061; 1639 1072 1073; 1640 1072 1068; 1641 1073 1069; 1642 1073 1074;
    1643 1074 1070; 1644 1074 1075; 1645 1075 1071; 1646 1075 1063; 1647 1076 1032;
    1648 1077 1033; 1649 1078 1034; 1650 1079 1035; 1651 1080 1036; 1652 1081 1037;
    1653 1082 1038; 1654 1083 1039; 1655 1042 1044; 1656 1040 1043; 1657 1049 1048;
    1658 1053 1052; 1659 1051 1054; 1660 1047 1050; 1661 1056 1060; 1662 1055 1059;
    1663 1089 1045; 1664 1090 1046; 1665 1101 1057; 1667 1088 1089; 1668 1089 1093;
    1669 1092 1096; 1670 1097 1101; 1671 1101 1100; 1672 1104 1107; 1673 1087 1090;
    1674 1090 1094; 1675 1091 1095; 1676 1098 1109; 1678 1085 1112; 1679 1086 1106;
    1680 1106 1084; 1681 1107 1103; 1682 1106 1116; 1683 1088 1116; 1684 1092 1117;
    1685 1096 1118; 1686 1100 1119; 1687 1088 1092; 1688 1096 1100; 1689 1087 1091;
    1690 1095 1108; 1695 1108 2098; 1696 1112 1113; 1697 1112 1087; 1698 1113 1091;
    1699 1113 1114; 1700 1114 1095; 1701 1114 1115; 1702 1115 1099; 1703 1115 1105;
    1704 1116 1117; 1705 1116 1112; 1706 1117 1113; 1707 1117 1118; 1708 1118 1114;
    1709 1118 1119; 1710 1119 1115; 1711 1119 1107; 1712 1120 1076; 1713 1121 1077;
    1714 1122 1078; 1715 1123 1079; 1716 1124 1080; 1717 1125 1081; 1718 1126 1082;
    1719 1127 1083; 1720 1086 1088; 1721 1084 1087; 1722 1093 1092; 1723 1097 1096;
    1724 1095 1098; 1725 1091 1094; 1726 1100 1104; 1727 1099 1103; 1728 1133 1089;
    1729 1134 1090; 1730 1145 1101; 1732 1132 1133; 1733 1133 1137; 1734 1136 1140;
    1735 1141 1145; 1736 1145 1144; 1737 1148 1151; 1738 1131 1134; 1739 1134 1138;
    1740 1135 1139; 1741 1142 1153; 1743 1129 1156; 1744 1130 1150; 1745 1150 1128;
    1746 1151 1147; 1747 1150 1160; 1748 1132 1160; 1749 1136 1161; 1750 1140 1162;
    1751 1144 1163; 1752 1132 1136; 1753 1140 1144; 1754 1131 1135; 1755 1139 1152;
    1760 1152 2104; 1761 1156 1157; 1762 1156 1131; 1763 1157 1135; 1764 1157 1158;
    1765 1158 1139; 1766 1158 1159; 1767 1159 1143; 1768 1159 1149; 1769 1160 1161;
    1770 1160 1156; 1771 1161 1157; 1772 1161 1162; 1773 1162 1158; 1774 1162 1163;
    1775 1163 1159; 1776 1163 1151; 1777 1164 1120; 1778 1165 1121; 1779 1166 1122;
    1780 1167 1123; 1781 1168 1124; 1782 1169 1125; 1783 1170 1126; 1784 1171 1127;
    1785 1130 1132; 1786 1128 1131; 1787 1137 1136; 1788 1141 1140; 1789 1139 1142;
    1790 1135 1138; 1791 1144 1148; 1792 1143 1147; 1793 1177 1133; 1794 1178 1134;
    1795 1189 1145; 1797 1176 1177; 1798 1177 1181; 1799 1180 1184; 1800 1185 1189;
    1801 1189 1188; 1802 1192 1195; 1803 1175 1178; 1804 1178 1182; 1805 1179 1183;
    1806 1186 1197; 1808 1173 1200; 1809 1174 1194; 1810 1194 1172; 1811 1195 1191;
    1812 1194 1204; 1813 1176 1204; 1814 1180 1205; 1815 1184 1206; 1816 1188 1207;
    1817 1176 1180; 1818 1184 1188; 1819 1175 1179; 1820 1183 1196; 1825 1196 2110;
    1826 1200 1201; 1827 1200 1175; 1828 1201 1179; 1829 1201 1202; 1830 1202 1183;
    1831 1202 1203; 1832 1203 1187; 1833 1203 1193; 1834 1204 1205; 1835 1204 1200;
    1836 1205 1201; 1837 1205 1206; 1838 1206 1202; 1839 1206 1207; 1840 1207 1203;
    1841 1207 1195; 1842 1208 1164; 1843 1209 1165; 1844 1210 1166; 1845 1211 1167;
    1846 1212 1168; 1847 1213 1169; 1848 1214 1170; 1849 1215 1171; 1850 1174 1176;
    1851 1172 1175; 1852 1181 1180; 1853 1185 1184; 1854 1183 1186; 1855 1179 1182;
    1856 1188 1192; 1857 1187 1191; 1858 1221 1177; 1859 1222 1178; 1860 1233 1189;
    1862 1220 1221; 1863 1221 1225; 1864 1224 1228; 1865 1229 1233; 1866 1233 1232;
    1867 1236 1239; 1868 1219 1222; 1869 1222 1226; 1870 1223 1227; 1871 1230 1241;
    1873 1217 1244; 1874 1218 1238; 1875 1238 1216; 1876 1239 1235; 1877 1238 1248;
    1878 1220 1248; 1879 1224 1249; 1880 1228 1250; 1881 1232 1251; 1882 1220 1224;
    1883 1228 1232; 1884 1219 1223; 1885 1227 1240; 1890 1240 2116; 1891 1244 1245;
    1892 1244 1219; 1893 1245 1223; 1894 1245 1246; 1895 1246 1227; 1896 1246 1247;
    1897 1247 1231; 1898 1247 1237; 1899 1248 1249; 1900 1248 1244; 1901 1249 1245;
    1902 1249 1250; 1903 1250 1246; 1904 1250 1251; 1905 1251 1247; 1906 1251 1239;
    1907 1252 1208; 1908 1253 1209; 1909 1254 1210; 1910 1255 1211; 1911 1256 1212;
    1912 1257 1213; 1913 1258 1214; 1914 1259 1215; 1915 1218 1220; 1916 1216 1219;
    1917 1225 1224; 1918 1229 1228; 1919 1227 1230; 1920 1223 1226; 1921 1232 1236;
    1922 1231 1235; 1923 1265 1221; 1924 1266 1222; 1925 1277 1233; 1927 1264 1265;
    1928 1265 1269; 1929 1268 1272; 1930 1273 1277; 1931 1277 1276; 1932 1280 1283;
    1933 1263 1266; 1934 1266 1270; 1935 1267 1271; 1936 1274 1285; 1938 1261 1288;
    1939 1262 1282; 1940 1282 1260; 1941 1283 1279; 1942 1282 1292; 1943 1264 1292;
    1944 1268 1293; 1945 1272 1294; 1946 1276 1295; 1947 1264 1268; 1948 1272 1276;
    1949 1263 1267; 1950 1271 1284; 1955 1284 2122; 1956 1288 1289; 1957 1288 1263;
    1958 1289 1267; 1959 1289 1290; 1960 1290 1271; 1961 1290 1291; 1962 1291 1275;
    1963 1291 1281; 1964 1292 1293; 1965 1292 1288; 1966 1293 1289; 1967 1293 1294;
    1968 1294 1290; 1969 1294 1295; 1970 1295 1291; 1971 1295 1283; 1972 1296 1252;
    1973 1297 1253; 1974 1298 1254; 1975 1299 1255; 1976 1300 1256; 1977 1301 1257;
    1978 1302 1258; 1979 1303 1259; 1980 1262 1264; 1981 1260 1263; 1982 1269 1268;
    1983 1273 1272; 1984 1271 1274; 1985 1267 1270; 1986 1276 1280; 1987 1275 1279;
    1988 1309 1265; 1989 1310 1266; 1990 1321 1277; 1992 1308 1309; 1993 1309 1313;
    1994 1312 1316; 1995 1317 1321; 1996 1321 1320; 1997 1324 1327; 1998 1307 1310;
    1999 1310 1314; 2000 1311 1315; 2001 1318 1329; 2003 1305 1332; 2004 1306 1326;
    2005 1326 1304; 2006 1327 1323; 2007 1326 1336; 2008 1308 1336; 2009 1312 1337;
    2010 1316 1338; 2011 1320 1339; 2012 1308 1312; 2013 1316 1320; 2014 1307 1311;
    2015 1315 1328; 2020 1328 2128; 2021 1332 1333; 2022 1332 1307; 2023 1333 1311;
    2024 1333 1334; 2025 1334 1315; 2026 1334 1335; 2027 1335 1319; 2028 1335 1325;
    2029 1336 1337; 2030 1336 1332; 2031 1337 1333; 2032 1337 1338; 2033 1338 1334;
    2034 1338 1339; 2035 1339 1335; 2036 1339 1327; 2037 1340 1296; 2038 1341 1297;
    2039 1342 1298; 2040 1343 1299; 2041 1344 1300; 2042 1345 1301; 2043 1346 1302;
    2044 1347 1303; 2045 1306 1308; 2046 1304 1307; 2047 1313 1312; 2048 1317 1316;
    2049 1315 1318; 2050 1311 1314; 2051 1320 1324; 2052 1319 1323; 2053 1353 1309;
    2054 1354 1310; 2055 1365 1321; 2057 1352 1353; 2058 1353 1357; 2059 1356 1360;
    2060 1361 1365; 2061 1365 1364; 2062 1368 1371; 2063 1351 1354; 2064 1354 1358;
    2065 1355 1359; 2066 1362 1373; 2068 1349 1376; 2069 1350 1370; 2070 1370 1348;
    2071 1371 1367; 2072 1370 1380; 2073 1352 1380; 2074 1356 1381; 2075 1360 1382;
    2076 1364 1383; 2077 1352 1356; 2078 1360 1364; 2079 1351 1355; 2080 1359 1372;
    2085 1372 2134; 2086 1376 1377; 2087 1376 1351; 2088 1377 1355; 2089 1377 1378;
    2090 1378 1359; 2091 1378 1379; 2092 1379 1363; 2093 1379 1369; 2094 1380 1381;
    2095 1380 1376; 2096 1381 1377; 2097 1381 1382; 2098 1382 1378; 2099 1382 1383;
    2100 1383 1379; 2101 1383 1371; 2102 1384 1340; 2103 1385 1341; 2104 1386 1342;
    2105 1387 1343; 2106 1388 1344; 2107 1389 1345; 2108 1390 1346; 2109 1391 1347;
    2110 1350 1352; 2111 1348 1351; 2112 1357 1356; 2113 1361 1360; 2114 1359 1362;
    2115 1355 1358; 2116 1364 1368; 2117 1363 1367; 2118 1397 1353; 2119 1398 1354;
    2120 1409 1365; 2122 1396 1397; 2123 1397 1401; 2124 1400 1404; 2125 1405 1409;
    2126 1409 1408; 2127 1412 1415; 2128 1395 1398; 2129 1398 1402; 2130 1399 1403;
    2131 1406 1417; 2133 1393 1420; 2134 1394 1414; 2135 1414 1392; 2136 1415 1411;
    2137 1414 1424; 2138 1396 1424; 2139 1400 1425; 2140 1404 1426; 2141 1408 1427;
    2142 1396 1400; 2143 1404 1408; 2144 1395 1399; 2145 1403 1416; 2150 1416 2140;
    2151 1420 1421; 2152 1420 1395; 2153 1421 1399; 2154 1421 1422; 2155 1422 1403;
    2156 1422 1423; 2157 1423 1407; 2158 1423 1413; 2159 1424 1425; 2160 1424 1420;
    2161 1425 1421; 2162 1425 1426; 2163 1426 1422; 2164 1426 1427; 2165 1427 1423;
    2166 1427 1415; 2167 1428 1384; 2168 1429 1385; 2169 1430 1386; 2170 1431 1387;
    2171 1432 1388; 2172 1433 1389; 2173 1434 1390; 2174 1435 1391; 2175 1394 1396;
    2176 1392 1395; 2177 1401 1400; 2178 1405 1404; 2179 1403 1406; 2180 1399 1402;
    2181 1408 1412; 2182 1407 1411; 2183 1441 1397; 2184 1442 1398; 2185 1453 1409;
    2187 1440 1441; 2188 1441 1445; 2189 1444 1448; 2190 1449 1453; 2191 1453 1452;
    2192 1456 1459; 2193 1439 1442; 2194 1442 1446; 2195 1443 1447; 2196 1450 1461;
    2198 1437 1464; 2199 1438 1458; 2200 1458 1436; 2201 1459 1455; 2202 1458 1468;
    2203 1440 1468; 2204 1444 1469; 2205 1448 1470; 2206 1452 1471; 2207 1440 1444;
    2208 1448 1452; 2209 1439 1443; 2210 1447 1460; 2215 1460 2146; 2216 1464 1465;
    2217 1464 1439; 2218 1465 1443; 2219 1465 1466; 2220 1466 1447; 2221 1466 1467;
    2222 1467 1451; 2223 1467 1457; 2224 1468 1469; 2225 1468 1464; 2226 1469 1465;
    2227 1469 1470; 2228 1470 1466; 2229 1470 1471; 2230 1471 1467; 2231 1471 1459;
    2232 1472 1428; 2233 1473 1429; 2234 1474 1430; 2235 1475 1431; 2236 1476 1432;
    2237 1477 1433; 2238 1478 1434; 2239 1479 1435; 2240 1438 1440; 2241 1436 1439;
    2242 1445 1444; 2243 1449 1448; 2244 1447 1450; 2245 1443 1446; 2246 1452 1456;
    2247 1451 1455; 2248 1485 1441; 2249 1486 1442; 2250 1497 1453; 2252 1484 1485;
    2253 1485 1489; 2254 1488 1492; 2255 1493 1497; 2256 1497 1496; 2257 1500 1503;
    2258 1483 1486; 2259 1486 1490; 2260 1487 1491; 2261 1494 1505; 2263 1481 1508;
    2264 1482 1502; 2265 1502 1480; 2266 1503 1499; 2267 1502 1512; 2268 1484 1512;
    2269 1488 1513; 2270 1492 1514; 2271 1496 1515; 2272 1484 1488; 2273 1492 1496;
    2274 1483 1487; 2275 1491 1504; 2280 1504 2152; 2281 1508 1509; 2282 1508 1483;
    2283 1509 1487; 2284 1509 1510; 2285 1510 1491; 2286 1510 1511; 2287 1511 1495;
    2288 1511 1501; 2289 1512 1513; 2290 1512 1508; 2291 1513 1509; 2292 1513 1514;
    2293 1514 1510; 2294 1514 1515; 2295 1515 1511; 2296 1515 1503; 2297 1516 1472;
    2298 1517 1473; 2299 1518 1474; 2300 1519 1475; 2301 1520 1476; 2302 1521 1477;
    2303 1522 1478; 2304 1523 1479; 2305 1482 1484; 2306 1480 1483; 2307 1489 1488;
    2308 1493 1492; 2309 1491 1494; 2310 1487 1490; 2311 1496 1500; 2312 1495 1499;
    2313 1529 1485; 2314 1530 1486; 2315 1541 1497; 2317 1528 1529; 2318 1529 1533;
    2319 1532 1536; 2320 1537 1541; 2321 1541 1540; 2322 1544 1547; 2323 1527 1530;
    2324 1530 1534; 2325 1531 1535; 2326 1538 1549; 2328 1525 1552; 2329 1526 1546;
    2330 1546 1524; 2331 1547 1543; 2332 1546 1556; 2333 1528 1556; 2334 1532 1557;
    2335 1536 1558; 2336 1540 1559; 2337 1528 1532; 2338 1536 1540; 2339 1527 1531;
    2340 1535 1548; 2345 1548 2158; 2346 1552 1553; 2347 1552 1527; 2348 1553 1531;
    2349 1553 1554; 2350 1554 1535; 2351 1554 1555; 2352 1555 1539; 2353 1555 1545;
    2354 1556 1557; 2355 1556 1552; 2356 1557 1553; 2357 1557 1558; 2358 1558 1554;
    2359 1558 1559; 2360 1559 1555; 2361 1559 1547; 2362 1560 1516; 2363 1561 1517;
    2364 1562 1518; 2365 1563 1519; 2366 1564 1520; 2367 1565 1521; 2368 1566 1522;
    2369 1567 1523; 2370 1526 1528; 2371 1524 1527; 2372 1533 1532; 2373 1537 1536;
    2374 1535 1538; 2375 1531 1534; 2376 1540 1544; 2377 1539 1543; 2378 1573 1529;
    2379 1574 1530; 2380 1585 1541; 2382 1572 1573; 2383 1573 1577; 2384 1576 1580;
    2385 1581 1585; 2386 1585 1584; 2387 1588 1591; 2388 1571 1574; 2389 1574 1578;
    2390 1575 1579; 2391 1582 1593; 2393 1569 1596; 2394 1570 1590; 2395 1590 1568;
    2396 1591 1587; 2397 1590 1600; 2398 1572 1600; 2399 1576 1601; 2400 1580 1602;
    2401 1584 1603; 2402 1572 1576; 2403 1580 1584; 2404 1571 1575; 2405 1579 1592;
    2410 1592 2164; 2411 1596 1597; 2412 1596 1571; 2413 1597 1575; 2414 1597 1598;
    2415 1598 1579; 2416 1598 1599; 2417 1599 1583; 2418 1599 1589; 2419 1600 1601;
    2420 1600 1596; 2421 1601 1597; 2422 1601 1602; 2423 1602 1598; 2424 1602 1603;
    2425 1603 1599; 2426 1603 1591; 2427 1604 1560; 2428 1605 1561; 2429 1606 1562;
    2430 1607 1563; 2431 1608 1564; 2432 1609 1565; 2433 1610 1566; 2434 1611 1567;
    2435 1570 1572; 2436 1568 1571; 2437 1577 1576; 2438 1581 1580; 2439 1579 1582;
    2440 1575 1578; 2441 1584 1588; 2442 1583 1587; 2443 1617 1573; 2444 1618 1574;
    2445 1629 1585; 2447 1616 1617; 2448 1617 1621; 2449 1620 1624; 2450 1625 1629;
    2451 1629 1628; 2452 1632 1635; 2453 1615 1618; 2454 1618 1622; 2455 1619 1623;
    2456 1626 1637; 2458 1613 1640; 2459 1614 1634; 2460 1634 1612; 2461 1635 1631;
    2462 1634 1644; 2463 1616 1644; 2464 1620 1645; 2465 1624 1646; 2466 1628 1647;
    2467 1616 1620; 2468 1624 1628; 2469 1615 1619; 2470 1623 1636; 2475 1636 2170;
    2476 1640 1641; 2477 1640 1615; 2478 1641 1619; 2479 1641 1642; 2480 1642 1623;
    2481 1642 1643; 2482 1643 1627; 2483 1643 1633; 2484 1644 1645; 2485 1644 1640;
    2486 1645 1641; 2487 1645 1646; 2488 1646 1642; 2489 1646 1647; 2490 1647 1643;
    2491 1647 1635; 2492 1648 1604; 2493 1649 1605; 2494 1650 1606; 2495 1651 1607;
    2496 1652 1608; 2497 1653 1609; 2498 1654 1610; 2499 1655 1611; 2500 1614 1616;
    2501 1612 1615; 2502 1621 1620; 2503 1625 1624; 2504 1623 1626; 2505 1619 1622;
    2506 1628 1632; 2507 1627 1631; 2508 1661 1617; 2509 1662 1618; 2510 1673 1629;
    2512 1660 1661; 2513 1661 1665; 2514 1664 1668; 2515 1669 1673; 2516 1673 1672;
    2517 1676 1679; 2518 1659 1662; 2519 1662 1666; 2520 1663 1667; 2521 1670 1681;
    2523 1657 1684; 2524 1658 1678; 2525 1678 1656; 2526 1679 1675; 2527 1678 1688;
    2528 1660 1688; 2529 1664 1689; 2530 1668 1690; 2531 1672 1691; 2532 1660 1664;
    2533 1668 1672; 2534 1659 1663; 2535 1667 1680; 2540 1680 2176; 2541 1684 1685;
    2542 1684 1659; 2543 1685 1663; 2544 1685 1686; 2545 1686 1667; 2546 1686 1687;
    2547 1687 1671; 2548 1687 1677; 2549 1688 1689; 2550 1688 1684; 2551 1689 1685;
    2552 1689 1690; 2553 1690 1686; 2554 1690 1691; 2555 1691 1687; 2556 1691 1679;
    2557 1692 1648; 2558 1693 1649; 2559 1694 1650; 2560 1695 1651; 2561 1696 1652;
    2562 1697 1653; 2563 1698 1654; 2564 1699 1655; 2565 1658 1660; 2566 1656 1659;
    2567 1665 1664; 2568 1669 1668; 2569 1667 1670; 2570 1663 1666; 2571 1672 1676;
    2572 1671 1675; 2573 1705 1661; 2574 1706 1662; 2575 1717 1673; 2577 1704 1705;
    2578 1705 1709; 2579 1708 1712; 2580 1713 1717; 2581 1717 1716; 2582 1720 1723;
    2583 1703 1706; 2584 1706 1710; 2585 1707 1711; 2586 1714 1725; 2588 1701 1728;
    2589 1702 1722; 2590 1722 1700; 2591 1723 1719; 2592 1722 1732; 2593 1704 1732;
    2594 1708 1733; 2595 1712 1734; 2596 1716 1735; 2597 1704 1708; 2598 1712 1716;
    2599 1703 1707; 2600 1711 1724; 2605 1724 2182; 2606 1728 1729; 2607 1728 1703;
    2608 1729 1707; 2609 1729 1730; 2610 1730 1711; 2611 1730 1731; 2612 1731 1715;
    2613 1731 1721; 2614 1732 1733; 2615 1732 1728; 2616 1733 1729; 2617 1733 1734;
    2618 1734 1730; 2619 1734 1735; 2620 1735 1731; 2621 1735 1723; 2622 1736 1692;
    2623 1737 1693; 2624 1738 1694; 2625 1739 1695; 2626 1740 1696; 2627 1741 1697;
    2628 1742 1698; 2629 1743 1699; 2630 1702 1704; 2631 1700 1703; 2632 1709 1708;
    2633 1713 1712; 2634 1711 1714; 2635 1707 1710; 2636 1716 1720; 2637 1715 1719;
    2638 1749 1705; 2639 1750 1706; 2640 1761 1717; 2642 1748 1749; 2643 1749 1753;
    2644 1752 1756; 2645 1757 1761; 2646 1761 1760; 2647 1764 1767; 2648 1747 1750;
    2649 1750 1754; 2650 1751 1755; 2651 1758 1769; 2653 1745 1772; 2654 1746 1766;
    2655 1766 1744; 2656 1767 1763; 2657 1766 1776; 2658 1748 1776; 2659 1752 1777;
    2660 1756 1778; 2661 1760 1779; 2662 1748 1752; 2663 1756 1760; 2664 1747 1751;
    2665 1755 1768; 2670 1768 2188; 2671 1772 1773; 2672 1772 1747; 2673 1773 1751;
    2674 1773 1774; 2675 1774 1755; 2676 1774 1775; 2677 1775 1759; 2678 1775 1765;
    2679 1776 1777; 2680 1776 1772; 2681 1777 1773; 2682 1777 1778; 2683 1778 1774;
    2684 1778 1779; 2685 1779 1775; 2686 1779 1767; 2687 1780 1736; 2688 1781 1737;
    2689 1782 1738; 2690 1783 1739; 2691 1784 1740; 2692 1785 1741; 2693 1786 1742;
    2694 1787 1743; 2695 1746 1748; 2696 1744 1747; 2697 1753 1752; 2698 1757 1756;
    2699 1755 1758; 2700 1751 1754; 2701 1760 1764; 2702 1759 1763; 2703 1793 1749;
    2704 1794 1750; 2705 1805 1761; 2707 1792 1793; 2708 1793 1797; 2709 1796 1800;
    2710 1801 1805; 2711 1805 1804; 2712 1808 1811; 2713 1791 1794; 2714 1794 1798;
    2715 1795 1799; 2716 1802 1813; 2718 1789 1816; 2719 1790 1810; 2720 1810 1788;
    2721 1811 1807; 2722 1810 1820; 2723 1792 1820; 2724 1796 1821; 2725 1800 1822;
    2726 1804 1823; 2727 1792 1796; 2728 1800 1804; 2729 1791 1795; 2730 1799 1812;
    2735 1812 2194; 2736 1816 1817; 2737 1816 1791; 2738 1817 1795; 2739 1817 1818;
    2740 1818 1799; 2741 1818 1819; 2742 1819 1803; 2743 1819 1809; 2744 1820 1821;
    2745 1820 1816; 2746 1821 1817; 2747 1821 1822; 2748 1822 1818; 2749 1822 1823;
    2750 1823 1819; 2751 1823 1811; 2752 1824 1780; 2753 1825 1781; 2754 1826 1782;
    2755 1827 1783; 2756 1828 1784; 2757 1829 1785; 2758 1830 1786; 2759 1831 1787;
    2760 1790 1792; 2761 1788 1791; 2762 1797 1796; 2763 1801 1800; 2764 1799 1802;
    2765 1795 1798; 2766 1804 1808; 2767 1803 1807; 2768 1837 1793; 2769 1838 1794;
    2770 1849 1805; 2772 1836 1837; 2773 1837 1841; 2774 1840 1844; 2775 1845 1849;
    2776 1849 1848; 2777 1852 1855; 2778 1835 1838; 2779 1838 1842; 2780 1839 1843;
    2781 1846 1857; 2783 1833 1860; 2784 1834 1854; 2785 1854 1832; 2786 1855 1851;
    2787 1854 1864; 2788 1836 1864; 2789 1840 1865; 2790 1844 1866; 2791 1848 1867;
    2792 1836 1840; 2793 1844 1848; 2794 1835 1839; 2795 1843 1856; 2800 1856 2200;
    2801 1860 1861; 2802 1860 1835; 2803 1861 1839; 2804 1861 1862; 2805 1862 1843;
    2806 1862 1863; 2807 1863 1847; 2808 1863 1853; 2809 1864 1865; 2810 1864 1860;
    2811 1865 1861; 2812 1865 1866; 2813 1866 1862; 2814 1866 1867; 2815 1867 1863;
    2816 1867 1855; 2817 1868 1824; 2818 1869 1825; 2819 1870 1826; 2820 1871 1827;
    2821 1872 1828; 2822 1873 1829; 2823 1874 1830; 2824 1875 1831; 2825 1834 1836;
    2826 1832 1835; 2827 1841 1840; 2828 1845 1844; 2829 1843 1846; 2830 1839 1842;
    2831 1848 1852; 2832 1847 1851; 2833 1881 1837; 2834 1882 1838; 2835 1893 1849;
    2837 1880 1881; 2838 1881 1885; 2839 1884 1888; 2840 1889 1893; 2841 1893 1892;
    2842 1896 1899; 2843 1879 1882; 2844 1882 1886; 2845 1883 1887; 2846 1890 1901;
    2848 1877 1904; 2849 1878 1898; 2850 1898 1876; 2851 1899 1895; 2852 1898 1908;
    2853 1880 1908; 2854 1884 1909; 2855 1888 1910; 2856 1892 1911; 2857 1880 1884;
    2858 1888 1892; 2859 1879 1883; 2860 1887 1900; 2865 1900 2206; 2866 1904 1905;
    2867 1904 1879; 2868 1905 1883; 2869 1905 1906; 2870 1906 1887; 2871 1906 1907;
    2872 1907 1891; 2873 1907 1897; 2874 1908 1909; 2875 1908 1904; 2876 1909 1905;
    2877 1909 1910; 2878 1910 1906; 2879 1910 1911; 2880 1911 1907; 2881 1911 1899;
    2882 1912 1868; 2883 1913 1869; 2884 1914 1870; 2885 1915 1871; 2886 1916 1872;
    2887 1917 1873; 2888 1918 1874; 2889 1919 1875; 2890 1878 1880; 2891 1876 1879;
    2892 1885 1884; 2893 1889 1888; 2894 1887 1890; 2895 1883 1886; 2896 1892 1896;
    2897 1891 1895; 2898 56 1920; 2899 57 1921; 2900 58 1922; 2901 59 1923;
    2902 60 1924; 2903 61 1925; 2904 62 1926; 2905 63 1927; 2906 592 56;
    2907 593 57; 2908 594 58; 2909 595 59; 2910 596 60; 2911 597 61; 2912 598 62;
    2913 599 63; 2914 640 592; 2915 641 593; 2916 642 594; 2917 643 595;
    2918 644 596; 2919 645 597; 2920 646 598; 2921 647 599; 2922 688 640;
    2923 689 641; 2924 690 642; 2925 691 643; 2926 692 644; 2927 693 645;
    2928 694 646; 2929 695 647; 2930 736 688; 2931 737 689; 2932 738 690;
    2933 739 691; 2934 740 692; 2935 741 693; 2936 742 694; 2937 743 695;
    2938 784 736; 2939 785 737; 2940 786 738; 2941 787 739; 2942 788 740;
    2943 789 741; 2944 790 742; 2945 791 743; 2946 832 784; 2947 833 785;
    2948 834 786; 2949 835 787; 2950 836 788; 2951 837 789; 2952 838 790;
    2953 839 791; 2954 880 832; 2955 881 833; 2956 882 834; 2957 883 835;
    2958 884 836; 2959 885 837; 2960 886 838; 2961 887 839; 2962 928 880;
    2963 929 881; 2964 930 882; 2965 931 883; 2966 932 884; 2967 933 885;
    2968 934 886; 2969 935 887; 2970 976 928; 2971 977 929; 2972 978 930;
    2973 979 931; 2974 980 932; 2975 981 933; 2976 982 934; 2977 983 935;
    2978 1024 976; 2979 1025 977; 2980 1026 978; 2981 1027 979; 2982 1028 980;
    2983 1029 981; 2984 1030 982; 2985 1031 983; 2986 1068 1024; 2987 1069 1025;
    2988 1070 1026; 2989 1071 1027; 2990 1072 1028; 2991 1073 1029; 2992 1074 1030;
    2993 1075 1031; 2994 1112 1068; 2995 1113 1069; 2996 1114 1070; 2997 1115 1071;
    2998 1116 1072; 2999 1117 1073; 3000 1118 1074; 3001 1119 1075; 3002 1156 1112;
    3003 1157 1113; 3004 1158 1114; 3005 1159 1115; 3006 1160 1116; 3007 1161 1117;
    3008 1162 1118; 3009 1163 1119; 3010 1200 1156; 3011 1201 1157; 3012 1202 1158;
    3013 1203 1159; 3014 1204 1160; 3015 1205 1161; 3016 1206 1162; 3017 1207 1163;
    3018 1244 1200; 3019 1245 1201; 3020 1246 1202; 3021 1247 1203; 3022 1248 1204;
    3023 1249 1205; 3024 1250 1206; 3025 1251 1207; 3026 1288 1244; 3027 1289 1245;
    3028 1290 1246; 3029 1291 1247; 3030 1292 1248; 3031 1293 1249; 3032 1294 1250;
    3033 1295 1251; 3034 1332 1288; 3035 1333 1289; 3036 1334 1290; 3037 1335 1291;
    3038 1336 1292; 3039 1337 1293; 3040 1338 1294; 3041 1339 1295; 3042 1376 1332;
    3043 1377 1333; 3044 1378 1334; 3045 1379 1335; 3046 1380 1336; 3047 1381 1337;
    3048 1382 1338; 3049 1383 1339; 3050 1420 1376; 3051 1421 1377; 3052 1422 1378;
    3053 1423 1379; 3054 1424 1380; 3055 1425 1381; 3056 1426 1382; 3057 1427 1383;
    3058 1464 1420; 3059 1465 1421; 3060 1466 1422; 3061 1467 1423; 3062 1468 1424;
    3063 1469 1425; 3064 1470 1426; 3065 1471 1427; 3066 1508 1464; 3067 1509 1465;
    3068 1510 1466; 3069 1511 1467; 3070 1512 1468; 3071 1513 1469; 3072 1514 1470;
    3073 1515 1471; 3074 1552 1508; 3075 1553 1509; 3076 1554 1510; 3077 1555 1511;
    3078 1556 1512; 3079 1557 1513; 3080 1558 1514; 3081 1559 1515; 3082 1596 1552;
    3083 1597 1553; 3084 1598 1554; 3085 1599 1555; 3086 1600 1556; 3087 1601 1557;
    3088 1602 1558; 3089 1603 1559; 3090 1640 1596; 3091 1641 1597; 3092 1642 1598;
    3093 1643 1599; 3094 1644 1600; 3095 1645 1601; 3096 1646 1602; 3097 1647 1603;
    3098 1684 1640; 3099 1685 1641; 3100 1686 1642; 3101 1687 1643; 3102 1688 1644;
    3103 1689 1645; 3104 1690 1646; 3105 1691 1647; 3106 1728 1684; 3107 1729 1685;
    3108 1730 1686; 3109 1731 1687; 3110 1732 1688; 3111 1733 1689; 3112 1734 1690;
    3113 1735 1691; 3114 1772 1728; 3115 1773 1729; 3116 1774 1730; 3117 1775 1731;
    3118 1776 1732; 3119 1777 1733; 3120 1778 1734; 3121 1779 1735; 3122 1816 1772;
    3123 1817 1773; 3124 1818 1774; 3125 1819 1775; 3126 1820 1776; 3127 1821 1777;
    3128 1822 1778; 3129 1823 1779; 3130 1860 1816; 3131 1861 1817; 3132 1862 1818;
    3133 1863 1819; 3134 1864 1820; 3135 1865 1821; 3136 1866 1822; 3137 1867 1823;
    3138 1904 1860; 3139 1905 1861; 3140 1906 1862; 3141 1907 1863; 3142 1908 1864;
    3143 1909 1865; 3144 1910 1866; 3145 1911 1867; 3239 1930 2021; 3240 1928 2022;
    3241 1929 2023; 3242 54 2024; 3243 52 18; 3244 2026 53; 3245 2026 54;
    3246 53 2025; 3247 18 2025; 3248 2032 589; 3249 2030 1930; 3250 2028 1928;
    3251 2029 1929; 3252 2027 54; 3253 588 575; 3254 2032 2027; 3255 589 2031;
    3256 575 2031; 3257 2038 637; 3258 2036 2030; 3259 2034 2028; 3260 2035 2029;
    3261 2033 2027; 3262 636 623; 3263 2038 2033; 3264 637 2037; 3265 623 2037;
    3266 2044 685; 3267 2042 2036; 3268 2040 2034; 3269 2041 2035; 3270 2039 2033;
    3271 684 671; 3272 2044 2039; 3273 685 2043; 3274 671 2043; 3275 2050 733;
    3276 2048 2042; 3277 2046 2040; 3278 2047 2041; 3279 2045 2039; 3280 732 719;
    3281 2050 2045; 3282 733 2049; 3283 719 2049; 3284 2056 781; 3285 2054 2048;
    3286 2052 2046; 3287 2053 2047; 3288 2051 2045; 3289 780 767; 3290 2056 2051;
    3291 781 2055; 3292 767 2055; 3293 2062 829; 3294 2060 2054; 3295 2058 2052;
    3296 2059 2053; 3297 2057 2051; 3298 828 815; 3299 2062 2057; 3300 829 2061;
    3301 815 2061; 3302 2068 877; 3303 2066 2060; 3304 2064 2058; 3305 2065 2059;
    3306 2063 2057; 3307 876 863; 3308 2068 2063; 3309 877 2067; 3310 863 2067;
    3311 2074 925; 3312 2072 2066; 3313 2070 2064; 3314 2071 2065; 3315 2069 2063;
    3316 924 911; 3317 2074 2069; 3318 925 2073; 3319 911 2073; 3320 2080 973;
    3321 2078 2072; 3322 2076 2070; 3323 2077 2071; 3324 2075 2069; 3325 972 959;
    3326 2080 2075; 3327 973 2079; 3328 959 2079; 3329 2086 1021; 3330 2084 2078;
    3331 2082 2076; 3332 2083 2077; 3333 2081 2075; 3334 1020 1007; 3335 2086 2081;
    3336 1021 2085; 3337 1007 2085; 3338 2092 1065; 3339 2090 2084; 3340 2088 2082;
    3341 2089 2083; 3342 2087 2081; 3343 1064 1055; 3344 2092 2087; 3345 1065 2091;
    3346 1055 2091; 3347 2098 1109; 3348 2096 2090; 3349 2094 2088; 3350 2095 2089;
    3351 2093 2087; 3352 1108 1099; 3353 2098 2093; 3354 1109 2097; 3355 1099 2097;
    3356 2104 1153; 3357 2102 2096; 3358 2100 2094; 3359 2101 2095; 3360 2099 2093;
    3361 1152 1143; 3362 2104 2099; 3363 1153 2103; 3364 1143 2103; 3365 2110 1197;
    3366 2108 2102; 3367 2106 2100; 3368 2107 2101; 3369 2105 2099; 3370 1196 1187;
    3371 2110 2105; 3372 1197 2109; 3373 1187 2109; 3374 2116 1241; 3375 2114 2108;
    3376 2112 2106; 3377 2113 2107; 3378 2111 2105; 3379 1240 1231; 3380 2116 2111;
    3381 1241 2115; 3382 1231 2115; 3383 2122 1285; 3384 2120 2114; 3385 2118 2112;
    3386 2119 2113; 3387 2117 2111; 3388 1284 1275; 3389 2122 2117; 3390 1285 2121;
    3391 1275 2121; 3392 2128 1329; 3393 2126 2120; 3394 2124 2118; 3395 2125 2119;
    3396 2123 2117; 3397 1328 1319; 3398 2128 2123; 3399 1329 2127; 3400 1319 2127;
    3401 2134 1373; 3402 2132 2126; 3403 2130 2124; 3404 2131 2125; 3405 2129 2123;
    3406 1372 1363; 3407 2134 2129; 3408 1373 2133; 3409 1363 2133; 3410 2140 1417;
    3411 2138 2132; 3412 2136 2130; 3413 2137 2131; 3414 2135 2129; 3415 1416 1407;
    3416 2140 2135; 3417 1417 2139; 3418 1407 2139; 3419 2146 1461; 3420 2144 2138;
    3421 2142 2136; 3422 2143 2137; 3423 2141 2135; 3424 1460 1451; 3425 2146 2141;
    3426 1461 2145; 3427 1451 2145; 3428 2152 1505; 3429 2150 2144; 3430 2148 2142;
    3431 2149 2143; 3432 2147 2141; 3433 1504 1495; 3434 2152 2147; 3435 1505 2151;
    3436 1495 2151; 3437 2158 1549; 3438 2156 2150; 3439 2154 2148; 3440 2155 2149;
    3441 2153 2147; 3442 1548 1539; 3443 2158 2153; 3444 1549 2157; 3445 1539 2157;
    3446 2164 1593; 3447 2162 2156; 3448 2160 2154; 3449 2161 2155; 3450 2159 2153;
    3451 1592 1583; 3452 2164 2159; 3453 1593 2163; 3454 1583 2163; 3455 2170 1637;
    3456 2168 2162; 3457 2166 2160; 3458 2167 2161; 3459 2165 2159; 3460 1636 1627;
    3461 2170 2165; 3462 1637 2169; 3463 1627 2169; 3464 2176 1681; 3465 2174 2168;
    3466 2172 2166; 3467 2173 2167; 3468 2171 2165; 3469 1680 1671; 3470 2176 2171;
    3471 1681 2175; 3472 1671 2175; 3473 2182 1725; 3474 2180 2174; 3475 2178 2172;
    3476 2179 2173; 3477 2177 2171; 3478 1724 1715; 3479 2182 2177; 3480 1725 2181;
    3481 1715 2181; 3482 2188 1769; 3483 2186 2180; 3484 2184 2178; 3485 2185 2179;
    3486 2183 2177; 3487 1768 1759; 3488 2188 2183; 3489 1769 2187; 3490 1759 2187;
    3491 2194 1813; 3492 2192 2186; 3493 2190 2184; 3494 2191 2185; 3495 2189 2183;
    3496 1812 1803; 3497 2194 2189; 3498 1813 2193; 3499 1803 2193; 3500 2200 1857;
    3501 2198 2192; 3502 2196 2190; 3503 2197 2191; 3504 2195 2189; 3505 1856 1847;
    3506 2200 2195; 3507 1857 2199; 3508 1847 2199; 3509 2206 1901; 3510 2204 2198;
    3511 2202 2196; 3512 2203 2197; 3513 2201 2195; 3514 1900 1891; 3515 2206 2201;
    3516 1901 2205; 3517 1891 2205;
    DEFINE MATERIAL START
    ISOTROPIC CONCRETE
    E 2.17185e+07
    POISSON 0.17
    DENSITY 23.5616
    ALPHA 1e-05
    DAMP 0.05
    TYPE CONCRETE
    STRENGTH FCU 27579
    END DEFINE MATERIAL
    MEMBER PROPERTY INDIAN
    24 26 28 35 37 39 42 46 51 TO 54 65 66 69 71 73 74 77 79 81 885 TO 887 891 -
    892 TO 893 895 899 904 TO 907 918 919 922 924 926 927 930 932 934 948 TO 950 -
    954 TO 956 958 962 967 TO 970 981 982 985 987 989 990 993 995 997 -
    1011 TO 1013 1017 TO 1019 1021 1025 1030 TO 1033 1044 1045 1048 1050 1052 -
    1053 1056 1058 1060 1074 TO 1076 1080 TO 1082 1084 1088 1093 TO 1096 1107 -
    1108 1111 1113 1115 1116 1119 1121 1123 1137 TO 1139 1143 TO 1145 1147 1151 -
    1156 TO 1159 1170 1171 1174 1176 1178 1179 1182 1184 1186 1200 TO 1202 1206 -
    1207 TO 1208 1210 1214 1219 TO 1222 1233 1234 1237 1239 1241 1242 1245 1247 -
    1249 1263 TO 1265 1269 TO 1271 1273 1277 1282 TO 1285 1296 1297 1300 1302 -
    1304 1305 1308 1310 1312 1326 TO 1328 1332 TO 1334 1336 1340 1345 TO 1348 -
    1359 1360 1363 1365 1367 1368 1371 1373 1375 1389 TO 1391 1395 TO 1397 1399 -
    1403 1408 TO 1411 1422 1423 1426 1428 1430 1431 1434 1436 1438 1452 TO 1454 -
    1458 TO 1460 1462 1466 1471 TO 1474 1485 1486 1489 1491 1493 1494 1497 1499 -
    1501 1603 TO 1605 1609 TO 1611 1613 1617 1622 TO 1625 1630 1631 1634 1636 -
    1638 1639 1642 1644 1646 1668 TO 1670 1674 TO 1676 1678 3244 3248 3257 3266 -
    3275 3284 3293 3302 3311 3320 3329 3338 PRIS YD 0.75 ZD 0.4
    1682 1687 TO 1690 1695 1696 1699 1701 1703 1704 1707 1709 1711 1733 TO 1735 -
    1739 TO 1741 1743 1747 1752 TO 1755 1760 1761 1764 1766 1768 1769 1772 1774 -
    1776 1798 TO 1800 1804 TO 1806 1808 1812 1817 TO 1820 1825 1826 1829 1831 -
    1833 1834 1837 1839 1841 1863 TO 1865 1869 TO 1871 1873 1877 1882 TO 1885 -
    1890 1891 1894 1896 1898 1899 1902 1904 1906 1928 TO 1930 1934 TO 1936 1938 -
    1942 1947 TO 1950 1955 1956 1959 1961 1963 1964 1967 1969 1971 1993 TO 1995 -
    1999 TO 2001 2003 2007 2012 TO 2015 2020 2021 2024 2026 2028 2029 2032 2034 -
    2036 2058 TO 2060 2064 TO 2066 2068 2072 2077 TO 2080 2085 2086 2089 2091 -
    2093 2094 2097 2099 2101 2123 TO 2125 2129 TO 2131 2133 2137 2142 TO 2145 -
    2150 2151 2154 2156 2158 2159 2162 2164 2166 2188 TO 2190 2194 TO 2196 2198 -
    2202 2207 TO 2210 2215 2216 2219 2221 2223 2224 2227 2229 2231 2253 TO 2255 -
    2259 TO 2261 2263 2267 2272 TO 2275 2280 2281 2284 2286 2288 2289 2292 2294 -
    2296 2318 TO 2320 2324 TO 2326 2328 2332 2337 TO 2340 2345 2346 2349 2351 -
    2353 2354 2357 2359 2361 2383 TO 2385 2389 TO 2391 2393 2397 2402 TO 2405 -
    2410 2411 2414 2416 2418 2419 2422 2424 2426 2448 TO 2450 2454 TO 2456 2458 -
    2462 2467 TO 2470 2475 2476 2479 2481 2483 2484 2487 2489 2491 2513 TO 2515 -
    2519 TO 2521 2523 2527 2532 TO 2535 2540 3347 3356 3365 3374 3383 3392 3401 -
    3410 3419 3428 3437 3446 3455 3464 PRIS YD 0.75 ZD 0.4
    2541 2544 2546 2548 2549 2552 2554 2556 2578 TO 2580 2584 TO 2586 2588 2592 -
    2597 TO 2600 2605 2606 2609 2611 2613 2614 2617 2619 2621 2643 TO 2645 2649 -
    2650 TO 2651 2653 2657 2662 TO 2665 2670 2671 2674 2676 2678 2679 2682 2684 -
    2686 2708 TO 2710 2714 TO 2716 2718 2722 2727 TO 2730 2735 2736 2739 2741 -
    2743 2744 2747 2749 2751 2773 TO 2775 2779 TO 2781 2783 2787 2792 TO 2795 -
    2800 2801 2804 2806 2808 2809 2812 2814 2816 2838 TO 2840 2844 TO 2846 2848 -
    2852 2857 TO 2860 2865 2866 2869 2871 2873 2874 2877 2879 2881 3473 3482 -
    3491 3500 3509 PRIS YD 0.75 ZD 0.4
    23 29 31 34 43 TO 45 47 TO 50 55 TO 60 67 68 70 72 75 76 78 80 884 -
    888 TO 890 896 TO 898 900 TO 903 908 TO 913 920 921 923 925 928 929 931 933 -
    947 951 TO 953 959 TO 961 963 TO 966 971 TO 976 983 984 986 988 991 992 994 -
    996 1010 1014 TO 1016 1022 TO 1024 1026 TO 1029 1034 TO 1039 1046 1047 1049 -
    1051 1054 1055 1057 1059 1073 1077 TO 1079 1085 TO 1087 1089 TO 1092 1097 -
    1098 TO 1102 1109 1110 1112 1114 1117 1118 1120 1122 1136 1140 TO 1142 1148 -
    1149 TO 1150 1152 TO 1155 1160 TO 1165 1172 1173 1175 1177 1180 1181 1183 -
    1185 1199 1203 TO 1205 1211 TO 1213 1215 TO 1218 1223 TO 1228 1235 1236 1238 -
    1240 1243 1244 1246 1248 1262 1266 TO 1268 1274 TO 1276 1278 TO 1281 1286 -
    1287 TO 1291 1298 1299 1301 1303 1306 1307 1309 1311 1325 1329 TO 1331 1337 -
    1338 TO 1339 1341 TO 1344 1349 TO 1354 1361 1362 1364 1366 1369 1370 1372 -
    1374 1388 1392 TO 1394 1400 TO 1402 1404 TO 1407 1412 TO 1417 1424 1425 1427 -
    1429 1432 1433 1435 1437 1451 1455 TO 1457 1463 TO 1465 1467 TO 1470 1475 -
    1476 TO 1480 1487 1488 1490 1492 1495 1496 1498 1500 1602 1606 TO 1608 1614 -
    1615 TO 1616 1618 TO 1621 1632 1633 1635 1637 1640 1641 1643 1645 1667 1671 -
    1672 TO 1673 1679 PRIS YD 0.9 ZD 0.45
    1680 1681 1683 TO 1686 1697 1698 1700 1702 1705 1706 1708 1710 1732 -
    1736 TO 1738 1744 TO 1746 1748 TO 1751 1762 1763 1765 1767 1770 1771 1773 -
    1775 1797 1801 TO 1803 1809 TO 1811 1813 TO 1816 1827 1828 1830 1832 1835 -
    1836 1838 1840 1862 1866 TO 1868 1874 TO 1876 1878 TO 1881 1892 1893 1895 -
    1897 1900 1901 1903 1905 1927 1931 TO 1933 1939 TO 1941 1943 TO 1946 1957 -
    1958 1960 1962 1965 1966 1968 1970 1992 1996 TO 1998 2004 TO 2006 -
    2008 TO 2011 2022 2023 2025 2027 2030 2031 2033 2035 2057 2061 TO 2063 2069 -
    2070 TO 2071 2073 TO 2076 2087 2088 2090 2092 2095 2096 2098 2100 2122 2126 -
    2127 TO 2128 2134 TO 2136 2138 TO 2141 2152 2153 2155 2157 2160 2161 2163 -
    2165 2187 2191 TO 2193 2199 TO 2201 2203 TO 2206 2217 2218 2220 2222 2225 -
    2226 2228 2230 2252 2256 TO 2258 2264 TO 2266 2268 TO 2271 2282 2283 2285 -
    2287 2290 2291 2293 2295 2317 2321 TO 2323 2329 TO 2331 2333 TO 2336 2347 -
    2348 2350 2352 2355 2356 2358 2360 2382 2386 TO 2388 2394 TO 2396 -
    2398 TO 2401 2412 2413 2415 2417 2420 2421 2423 2425 2447 2451 TO 2453 2459 -
    2460 TO 2461 2463 TO 2466 2477 2478 2480 2482 2485 2486 2488 2490 2512 2516 -
    2517 TO 2518 2524 TO 2526 2528 TO 2531 2542 2543 2545 2547 2550 2551 2553 -
    2555 2577 2581 TO 2583 PRIS YD 0.9 ZD 0.45
    2589 TO 2591 2593 TO 2596 2607 2608 2610 2612 2615 2616 2618 2620 2642 2646 -
    2647 TO 2648 2654 TO 2656 2658 TO 2661 2672 2673 2675 2677 2680 2681 2683 -
    2685 2707 2711 TO 2713 2719 TO 2721 2723 TO 2726 2737 2738 2740 2742 2745 -
    2746 2748 2750 2772 2776 TO 2778 2784 TO 2786 2788 TO 2791 2802 2803 2805 -
    2807 2810 2811 2813 2815 2837 2841 TO 2843 2849 TO 2851 2853 TO 2856 2867 -
    2868 2870 2872 2875 2876 2878 2880 PRIS YD 0.9 ZD 0.45
    MEMBER PROPERTY
    876 939 1002 1065 1128 1191 1254 1317 1380 1443 1506 1651 1716 1781 1846 1911 -
    1976 2041 2106 2171 2236 2301 2366 2431 2496 2561 2626 2691 2756 2821 -
    2886 PRIS YD 4.62 ZD 0.85
    877 878 940 941 1003 1004 1066 1067 1129 1130 1192 1193 1255 1256 1318 1319 -
    1381 1382 1444 1445 1507 1508 1652 1653 1717 1718 1782 1783 1847 1848 1912 -
    1913 1977 1978 2042 2043 2107 2108 2172 2173 2237 2238 2302 2303 2367 2368 -
    2432 2433 2497 2498 2562 2563 2627 2628 2692 2693 2757 2758 2822 2823 2887 -
    2888 PRIS YD 4.91 ZD 0.85
    879 942 1005 1068 1131 1194 1257 1320 1379 1383 1442 1446 1505 1509 1650 1654 -
    1715 1719 1780 1784 1845 1849 1910 1914 1975 1979 2040 2044 2105 2109 2170 -
    2174 2235 2239 2300 2304 2365 2369 2430 2434 2495 2499 2560 2564 2625 2629 -
    2690 2694 2755 2759 2820 2824 2885 2889 PRIS YD 4.8 ZD 0.85
    1510 TO 1597 1655 TO 1662 1720 TO 1727 1785 TO 1792 1850 TO 1857 1915 TO 1922 -
    1980 TO 1987 2045 TO 2052 2110 TO 2117 2175 TO 2182 2240 TO 2247 -
    2305 TO 2312 2370 TO 2377 2435 TO 2442 2500 TO 2507 2565 TO 2572 -
    2630 TO 2637 2695 TO 2702 2760 TO 2767 2825 TO 2832 2890 TO 2896 -
    2897 PRIS YD 3 ZD 0.6
    2898 TO 3145 PRIS YD 1.5 ZD 0.5
    872 935 998 1061 1124 1187 1250 1313 1376 1439 1502 1647 1712 1777 1842 1907 -
    1972 2037 2102 2167 2232 2297 2362 2427 2492 2557 2622 2687 2752 2817 -
    2882 PRIS YD 4.62 ZD 0.85
    873 874 936 937 999 1000 1062 1063 1125 1126 1188 1189 1251 1252 1314 1315 -
    1377 1378 1440 1441 1503 1504 1648 1649 1713 1714 1778 1779 1843 1844 1908 -
    1909 1973 1974 2038 2039 2103 2104 2168 2169 2233 2234 2298 2299 2363 2364 -
    2428 2429 2493 2494 2558 2559 2623 2624 2688 2689 2753 2754 2818 2819 2883 -
    2884 PRIS YD 3.8 ZD 0.85
    875 938 1001 1064 1127 1190 1253 1316 PRIS YD 4.8 ZD 0.85
    3239 TO 3241 3249 TO 3251 3258 TO 3260 3267 TO 3269 3276 TO 3278 3285 TO 3287 -
    3294 TO 3296 3303 TO 3305 3312 TO 3314 3321 TO 3323 3330 TO 3332 -
    3339 TO 3341 3348 TO 3350 3357 TO 3359 3366 TO 3368 3375 TO 3377 -
    3384 TO 3386 3393 TO 3395 3402 TO 3404 3411 TO 3413 3420 TO 3422 -
    3429 TO 3431 3438 TO 3440 3447 TO 3449 3456 TO 3458 3465 TO 3467 -
    3474 TO 3476 3483 TO 3485 3492 TO 3494 3501 TO 3503 3510 TO 3511 -
    3512 PRIS YD 2.85 ZD 0.35
    3242 3252 3261 3270 3279 3288 3297 3306 3315 3324 3333 3342 3351 3360 3369 -
    3378 3387 3396 3405 3414 3423 3432 3441 3450 3459 3468 3477 3486 3495 3504 -
    3513 PRIS YD 4.91 ZD 0.35
    3243 3245 TO 3247 3253 TO 3256 3262 TO 3265 3271 TO 3274 3280 TO 3283 3289 -
    3290 TO 3292 3298 TO 3301 3307 TO 3310 3316 TO 3319 3325 TO 3328 3334 TO 3337 -
    3343 TO 3346 3352 TO 3355 3361 TO 3364 3370 TO 3373 3379 TO 3382 -
    3388 TO 3391 3397 TO 3400 3406 TO 3409 3415 TO 3418 3424 TO 3427 -
    3433 TO 3436 3442 TO 3445 3451 TO 3454 3460 TO 3463 3469 TO 3472 -
    3478 TO 3481 3487 TO 3490 3496 TO 3499 3505 TO 3508 3514 TO 3516 -
    3517 PRIS YD 3 ZD 0.35
    6 7 18 880 TO 882 943 TO 945 1006 TO 1008 1069 TO 1071 1132 TO 1134 -
    1195 TO 1197 1258 TO 1260 1321 TO 1323 1384 TO 1386 1447 TO 1449 -
    1598 TO 1600 1663 TO 1665 1728 TO 1730 1793 TO 1795 1858 TO 1860 -
    1923 TO 1925 1988 TO 1990 2053 TO 2055 2118 TO 2120 2183 TO 2185 -
    2248 TO 2250 2313 TO 2315 2378 TO 2380 2443 TO 2445 2508 TO 2510 -
    2573 TO 2575 2638 TO 2640 2703 TO 2705 2768 TO 2770 2833 TO 2834 -
    2835 PRIS YD 2 ZD 2
    CONSTANTS
    BETA 90 MEMB 7 873 874 877 878 881 936 937 940 941 944 999 1000 1003 1004 -
    1007 1062 1063 1066 1067 1070 1125 1126 1129 1130 1133 1188 1189 1192 1193 -
    1196 1251 1252 1255 1256 1259 1314 1315 1318 1319 1322 1377 1378 1381 1382 -
    1385 1440 1441 1444 1445 1448 1503 1504 1507 1508 1599 1648 1649 1652 1653 -
    1664 1713 1714 1717 1718 1729 1778 1779 1782 1783 1794 1843 1844 1847 1848 -
    1859 1908 1909 1912 1913 1924 1973 1974 1977 1978 1989 2038 2039 2042 2043 -
    2054 2103 2104 2107 2108 2119 2168 2169 2172 2173 2184 2233 2234 2237 2238 -
    2249 2298 2299 2302 2303 2314 2363 2364 2367 2368 2379 2428 2429 2432 2433 -
    2444 2493 2494 2497 2498 2509 2558 2559 2562 2563 2574 2623 2624 2627 2628 -
    2639 2688 2689 2692 2693 2704 2753 2754 2757 2758 2769 2818 2819 2822 2823 -
    2834 2883 2884 2887 2888 3242 3252 3261 3270 3279 3288 3297 3306 3315 3324 -
    3333 3342 3351 3360 3369 3378 3387 3396 3405 3414 3423 3432 3441 3450 3459 -
    3468 3477 3486 3495 3504 3513
    MATERIAL CONCRETE ALL
    SUPPORTS
    30 31 42 552 TO 559 1920 TO 1927 2021 TO 2024 FIXED
    MEMBER RELEASE
    42 46 59 60 65 895 899 912 913 918 958 962 975 976 981 1021 1025 1038 1039 -
    1044 1084 1088 1101 1102 1107 1147 1151 1164 1165 1170 1210 1214 1227 1228 -
    1233 1273 1277 1290 1291 1296 1336 1340 1353 1354 1359 1399 1403 1416 1417 -
    1422 1462 1466 1479 1480 1485 1613 1617 1630 1678 1682 1695 1743 1747 1760 -
    1808 1812 1825 1873 1877 1890 1938 1942 1955 2003 2007 2020 2068 2072 2085 -
    2133 2137 2150 2198 2202 2215 2263 2267 2280 2328 2332 2345 2393 2397 2410 -
    2458 2462 2475 2523 2527 2540 2588 2592 2605 2653 2657 2670 2718 2722 2735 -
    2783 2787 2800 2848 2852 2865 START MY MZ
    59 60 73 81 912 913 926 934 975 976 989 997 1038 1039 1052 1060 1101 1102 -
    1115 1123 1164 1165 1178 1186 1227 1228 1241 1249 1290 1291 1304 1312 1353 -
    1354 1367 1375 1416 1417 1430 1438 1479 1480 1493 1501 1638 1646 1703 1711 -
    1768 1776 1833 1841 1898 1906 1963 1971 2028 2036 2093 2101 2158 2166 2223 -
    2231 2288 2296 2353 2361 2418 2426 2483 2491 2548 2556 2613 2621 2678 2686 -
    2743 2751 2808 2816 2873 2881 3244 3248 3257 3266 3275 3284 3293 3302 3311 -
    3320 3329 3338 3347 3356 3365 3374 3383 3392 3401 3410 3419 3428 3437 3446 -
    3455 3464 3473 3482 3491 3500 3509 END MY MZ
    DEFINE IS1893 2016 LOAD
    ZONE 0.36 RF 5 I 1.2 SS 2 ST 1 DM 0.05
    SELFWEIGHT 1
    MEMBER WEIGHT
    23 24 26 28 29 34 35 37 39 51 TO 58 65 884 TO 888 890 TO 893 904 TO 911 918 -
    947 TO 951 953 TO 956 967 TO 974 981 1010 TO 1014 1016 TO 1019 1030 TO 1037 -
    1044 1073 TO 1077 1079 TO 1082 1093 TO 1100 1107 1136 TO 1140 1142 TO 1145 -
    1156 TO 1163 1170 1199 TO 1203 1205 TO 1208 1219 TO 1226 1233 1262 TO 1266 -
    1268 TO 1271 1282 TO 1289 1296 1325 TO 1329 1331 TO 1334 1345 TO 1352 1359 -
    1388 TO 1392 1394 TO 1397 1408 TO 1415 1422 1451 TO 1455 1457 TO 1460 1471 -
    1472 TO 1478 1485 1602 TO 1606 1608 TO 1611 1622 TO 1625 1630 1667 TO 1671 -
    1673 TO 1676 1687 TO 1690 1695 1732 TO 1736 1738 TO 1741 1752 TO 1755 1760 -
    1797 TO 1801 1803 TO 1806 1817 TO 1820 1825 1862 TO 1866 1868 TO 1871 1882 -
    1883 TO 1885 1890 1927 TO 1931 1933 TO 1936 1947 TO 1950 1955 1992 TO 1996 -
    1998 TO 2001 2012 TO 2015 2020 2057 TO 2061 2063 TO 2066 2077 TO 2080 2085 -
    2122 TO 2126 2128 TO 2131 2142 TO 2145 2150 2187 TO 2191 2193 TO 2196 2207 -
    2208 TO 2210 2215 2252 TO 2256 2258 TO 2261 2272 TO 2275 2280 2317 TO 2321 -
    2323 TO 2326 2337 TO 2340 2345 2382 TO 2386 2388 TO 2391 2402 TO 2405 2410 -
    2447 TO 2451 2453 TO 2456 2467 TO 2470 2475 2512 TO 2516 2518 TO 2521 2532 -
    2533 TO 2535 2540 2577 TO 2581 2583 TO 2586 2597 TO 2600 2605 3244 3248 3257 -
    3266 3275 3284 3293 UNI 6
    3302 3311 3320 3329 3338 3347 3356 3365 3374 3383 3392 3401 3410 3419 3428 -
    3437 3446 3455 3464 3473 UNI 6
    2642 TO 2646 2648 TO 2651 2662 TO 2665 2670 2707 TO 2711 2713 TO 2716 2727 -
    2728 TO 2730 2735 2772 TO 2776 2778 TO 2781 2792 TO 2795 2800 2837 TO 2841 -
    2843 TO 2846 2857 TO 2860 2865 3482 3491 3500 3509 UNI 6
    59 60 912 913 975 976 1038 1039 1101 1102 1164 1165 1227 1228 1290 1291 1353 -
    1354 1416 1417 1479 1480 1607 1614 TO 1616 1672 1679 TO 1681 1737 -
    1744 TO 1746 1802 1809 TO 1811 1867 1874 TO 1876 1932 1939 TO 1941 1997 2004 -
    2005 TO 2006 2062 2069 TO 2071 2127 2134 TO 2136 2192 2199 TO 2201 2257 2264 -
    2265 TO 2266 2322 2329 TO 2331 2387 2394 TO 2396 2452 2459 TO 2461 2517 2524 -
    2525 TO 2526 2582 2589 TO 2591 2647 2654 TO 2656 2712 2719 TO 2721 2777 2784 -
    2785 TO 2786 2842 2849 TO 2851 UNI 5
    FLOOR WEIGHT
    YRANGE 0 100 FLOAD 4
    LOAD 1 LOADTYPE Seismic TITLE EQX+
    1893 LOAD X 1
    PERFORM ANALYSIS
    CHANGE
    LOAD 2 LOADTYPE Seismic TITLE EQX-
    1893 LOAD X -1
    PERFORM ANALYSIS
    CHANGE
    LOAD 3 LOADTYPE Seismic TITLE EQZ+
    1893 LOAD Z 1
    PERFORM ANALYSIS
    CHANGE
    LOAD 4 LOADTYPE Seismic TITLE EQZ-
    1893 LOAD Z -1
    PERFORM ANALYSIS
    CHANGE
    LOAD 5 LOADTYPE Dead TITLE DL
    SELFWEIGHT Y -1
    FLOOR LOAD
    YRANGE 0 100 FLOAD -1 GY
    MEMBER LOAD
    3266 3275 3284 3293 UNI GY -6
    3437 3446 3455 3464 3473 UNI GY -6
    2843 TO 2846 2857 TO 2860 2865 3482 3491 3500 3509 UNI GY -6
    2785 TO 2786 2842 2849 TO 2851 UNI GY -5
    LOAD 6 LOADTYPE Live TITLE LL
    FLOOR LOAD
    YRANGE 0 100 FLOAD -3 GY
    LOAD COMB 7 ULC, 1.5 DEAD + 1.5 LIVE
    5 1.5 6 1.5
    LOAD COMB 8 ULC, 1.2 DEAD + 1.2 LIVE
    5 1.2 6 1.2
    LOAD COMB 9 ULC, 1.2 DEAD + 1.2 LIVE + 1.2 SEISMIC (1)
    5 1.2 6 1.2 1 1.2
    LOAD COMB 10 ULC, 1.2 DEAD + 1.2 LIVE + 1.2 SEISMIC (2)
    5 1.2 6 1.2 2 1.2
    LOAD COMB 11 ULC, 1.2 DEAD + 1.2 LIVE + 1.2 SEISMIC (3)
    5 1.2 6 1.2 3 1.2
    LOAD COMB 12 ULC, 1.2 DEAD + 1.2 LIVE + 1.2 SEISMIC (4)
    5 1.2 6 1.2 4 1.2
    LOAD COMB 13 ULC, 1.2 DEAD + 1.2 LIVE + -1.2 SEISMIC (1)
    5 1.2 6 1.2 1 -1.2
    LOAD COMB 14 ULC, 1.2 DEAD + 1.2 LIVE + -1.2 SEISMIC (2)
    5 1.2 6 1.2 2 -1.2
    LOAD COMB 15 ULC, 1.2 DEAD + 1.2 LIVE + -1.2 SEISMIC (3)
    5 1.2 6 1.2 3 -1.2
    LOAD COMB 16 ULC, 1.2 DEAD + 1.2 LIVE + -1.2 SEISMIC (4)
    5 1.2 6 1.2 4 -1.2
    LOAD COMB 17 ULC, 1.5 DEAD
    5 1.5
    LOAD COMB 18 ULC, 1.5 DEAD + 1.5 SEISMIC (1)
    5 1.5 1 1.5
    LOAD COMB 19 ULC, 1.5 DEAD + 1.5 SEISMIC (2)
    5 1.5 2 1.5
    LOAD COMB 20 ULC, 1.5 DEAD + 1.5 SEISMIC (3)
    5 1.5 3 1.5
    LOAD COMB 21 ULC, 1.5 DEAD + 1.5 SEISMIC (4)
    5 1.5 4 1.5
    LOAD COMB 22 ULC, 1.5 DEAD + -1.5 SEISMIC (1)
    5 1.5 1 -1.5
    LOAD COMB 23 ULC, 1.5 DEAD + -1.5 SEISMIC (2)
    5 1.5 2 -1.5
    LOAD COMB 24 ULC, 1.5 DEAD + -1.5 SEISMIC (3)
    5 1.5 3 -1.5
    LOAD COMB 25 ULC, 1.5 DEAD + -1.5 SEISMIC (4)
    5 1.5 4 -1.5
    LOAD COMB 26 ULC, 0.9 DEAD
    5 0.9
    LOAD COMB 27 ULC, 0.9 DEAD + 1.5 SEISMIC (1)
    5 0.9 1 1.5
    LOAD COMB 28 ULC, 0.9 DEAD + 1.5 SEISMIC (2)
    5 0.9 2 1.5
    LOAD COMB 29 ULC, 0.9 DEAD + 1.5 SEISMIC (3)
    5 0.9 3 1.5
    LOAD COMB 30 ULC, 0.9 DEAD + 1.5 SEISMIC (4)
    5 0.9 4 1.5
    LOAD COMB 31 ULC, 0.9 DEAD + -1.5 SEISMIC (1)
    5 0.9 1 -1.5
    LOAD COMB 32 ULC, 0.9 DEAD + -1.5 SEISMIC (2)
    5 0.9 2 -1.5
    LOAD COMB 33 ULC, 0.9 DEAD + -1.5 SEISMIC (3)
    5 0.9 3 -1.5
    LOAD COMB 34 ULC, 0.9 DEAD + -1.5 SEISMIC (4)
    5 0.9 4 -1.5
    PERFORM ANALYSIS
    FINISH
