I have a 2 story building where the lower portion of the floor plan must cantilever out due to existing conditions. I modeled the cantilever using a combination of gravity extensions and stubs as shown in the floor plans. When I run RAM SS and go through the Frame module I am getting large nodal displacements on the order of between 500 and 2000 inches in the gravity load cases. The building behaves normally under wind and seismic so I must be missing something with the cantilever. Should I fix the base of these columns?
It looks like you might have a pin where you intended a fixed connection. Double check the beam fixity. While stub cantilevers default to being fixed at the backspan it's possible for this to be changed or reassigned as a pin leading to such problems. If the braces are tension only, then also see: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/3058/ram-frame---tension-only-faq
Can you change the beam fixity of a gravity member? Also these braces are not tension only.
Seth,
My nodes are connected to the diaphragm but it is still swinging like it is not connected. Can I upload the file for you to take a quick look?
Sure, sending the model always helps with diagnosis.
Thanks Seth. The file has been uploaded.
A Pseudo-flexible diaphragm has no stiffness. A 2-D frame connected to a pf diaphragm and pined at the base can easily fall over, or swing out in this case. As noted on the wiki, https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/3173/ram-frame---pseudo-flexible-diaphragms-faq, adding some small rotational fixity at the base is one good solution.
That seemed to fix it. Thank you for your help Seth!
