Is it possible to perform a buckling analysis on a concrete column in STAAD pro? If so, how is it done?
Thanks in advance!
Ignacio
Yes you can carry out a buckling analysis in STAAD.Pro for a concrete column. You will get the buckling load factor which when multiplied by the applied load would give you the buckling load.
The following wiki has useful information
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/24121/staad-pro-buckling-analysis
The following section of the help documentation has additional details
Answer Verified By: Ignacio Rojas
