When in imported the accdb file in rcdc and select Columns&Walls option after it is showing columns only. not shearwall.
Can you help me this is my final year project. i dont know how to model column as pier. im sharing the e2k file.
drive.google.com/.../view
Hii have suggested to model column as pier (like wall) so that you will get two points for other members to connect. RCDC identified whether the member is column or wall based on D/B ratio. it doesn't matter how it is modelled in analysis file.just to avoid overlapping of column and wall (to avoid duplication of stiffness) i have suggested to model wall up to face of column.
