Dear sir,
I am having a bridge span of 120m and I want to run a moving load as per IRC. While trying, only one vehicle is running from one end to another end. How to create a trailing vehicle with a specific nose to tail spacing option. Is there any provision is there?? Or we have to enter it as a separate generation. Kindly advise.
Thanks in Advance.
One way would be model both the first and the trailing vehicle wheel loads as part of the same vehicle type. You need to specify appropriate distances between the wheels. Alternately you may have two separate vehicles and include both as part of the same load generation. The initial positions would be different for the 2 vehicles to make one come after the other.
Answer Verified By: Alagu Pandi R
Thanks sir. I have already used it as per second way you mentioned. It is working fine.
