V22.05.00.131 Wind Load Routine
We have tried to compare the results of V22.04.00.40 & V22.05.00.131 prior to shift to the latest update - same STAAD file (no modifications).
As shown in the snapshot, significant post-processing output differences were found.
The largest differences noted were on the Wind Load Cases.
The STAAD Generated Wind Load values, however, were found to be the same.
So it must be a change in the calculation/routine that caused the significant difference.
Can anyone please clarify the wind load calculation procedure for Update 5?
