Can Someone tell me why the RCDC is showing up a message, "unable to read analysis data"?AT_RCDC.STD
I have 22.05 connect edition and RCDC CONNECT Edition V9 Update 4.
Many thanks.
With the same versions I was able to import it.
can you please do the below steps and let me know if it works?
1. Create a new folder in desktop.
2. Copy the .std file and paste in the new folder.
3. Open the STAAD file.
4. Run Analysis.
5. Try importing in RCDC.
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
Hi Abhishek,
Thanks. I followed the above steps. I still see the same issue. I attached the snapshot of the post processing too.
Please create a service request. We need to take remote of your system to check the issue.
communities.bentley.com/.../service-request-manager
Thanks Abhisek.
I have created the service request. Thanks again for your continuous support.
Hione question i have,what is the intention of keeping structure disconnected?this is causing issue in identifying beam propagation as columns are not identified below beams in disconnected area.please confirm.
