As you can see in the image, the software gives me the possibility of applying steel reinforcements to the top and bottom flanges of the beam section, but I can't find an option to do the same with its web. Is it possible to do this? If so, how is it done?
Thanks in advance,
Ignacio
I don't think that there is a way to model a cover plates for webs of the beams in STAAD.Pro. You would need to create a custom section with a thicker web.
Answer Verified By: Ignacio Rojas
