Ram Elements Concrete wall Module (Stand alone)
Ram Elements: I am currently trying to model a load bearing 8" concrete wall with 25'-0" opening. I have gravity loads acting in plane and wind load acting out of plane. I wanted to know if the concrete wall above the opening (about 4'-0") is designed as "beam" to support the gravity load above the opening. The additional opening reinforcement does not appear to be something being designed.
