Ram Elements Concrete Column Module - Not importing loads from analysis
I am trying to design a concrete pedestal below a moment frame steel column. I did model the correct concrete section and dimensions, but the concrete column design module does not seem to import the loads. Seems like it does not fill up the load cases even after entering the DL, LL, W, and EQ loads manually. Please note that I have all the load cases generated. Any solution to this issue?
Thanks and Regards,
Faaz
