<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Post-processing is causing RAM S to stop working</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/210851/post-processing-is-causing-ram-s-to-stop-working</link><description>WHen I click on Post-processing\ DXF file \ Column and footing, RAM SS stops working and I get the following message:
 This only happens when creating column/ foundation DXF file. Everything works fine when creating framing plans.
 Could you please</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Post-processing is causing RAM S to stop working</title><link>https://communities.bentley.com/thread/638206?ContentTypeID=1</link><pubDate>Tue, 09 Mar 2021 23:45:45 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:e18aa6d5-e1ff-4fcc-ac0e-1b5759e534dd</guid><dc:creator>Seth Guthrie</dc:creator><description>&lt;p&gt;I have seen some problems when the grids have unusual names (symbols in the grid ids for example).&lt;/p&gt;
&lt;p&gt;If you are trying to overwrite an existing .dxf file (especially one that is open) or create a file in a restricted folder, it might also cause it to crash. Test creating a totally new file to the local C:\ drive in a folder with full rights.&amp;nbsp;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
