RCDC v10, beam design - Beam continuum section - Beam are considered as cantilever, where there should be support on both sides. No option to add support as column. Can you please clarify
Hello, I would like to design with supports on both sides. I designed columns first in RCDC V10, then my etabs analysis fie (tables to access file) is used to design beams floor by floor. I am designing ground floor beams first. When I import the file and RCDC shows data of the beam (beam continuum), it shows some of the beams are cantilever when they should be supported on both sides by columns. I imported the column rcdc file and rcdc says, column size and column mark imported successfully. Now when I click on on the beam, it has only one support, when it should have 2 supports. See fig.
When I click on beam and hit add support option it gives me only option of B20. Can you please clarify this?
Parents Reply Children
