LOAD LIST SELECTION FOR PERFORMING ANALYSIS
I everyone,
I am try to find the way to tell staad pro to perform analysis for only repeat loads and ignore other basic loads. For example my model has primary load case 1, 2 and 3. After that I create some repeat loads 4,5,6 which refer to load case 1,2,3. And now I just want to analyze the repeat loads 4 5 6. I tried to put load list 4 to 6 before the Perform Analysis command but it does not seem to work. Any advice on this, please?
Parents Reply Children
  • hello Son Nguyen,
    It can be done in STAAD. Once you create the reference load cases then please create a primary load case. under that select repeat load and reference load as shown below.
    From here you can add them. This is a manual process. I am attaching one sample model.
    During creation of reference load there is an option to define load type as shown below.
    If you define the types then the program will allow you to use auto load combination option to generate repeat loads as shown below.
    You may try this also and let me know the outcome.
    Ref load +repeat load.STD
    Thanks & Regards,
    Abhisek Mandal
    Global Technical Support
    Answer Verified By: Son Nguyen
