I've been using RAM Connection Standalone (CONNECT Edition, v13 Update 4) for some one-off base plate designs for a project I'm working on. In order to do this, I created a connection group with a few base plate configurations. I've been searching online for a way to export the connection group database so that I could send it to a colleague if I needed to, but I haven't found out a good way to do it. Any ideas?
- Alex
I think you can just copy the folder over. To check the path use File - Settings - General Configuration - User folders.
Answer Verified By: Alex Dundore
What about RAM Connection through STAAD, How we find the DataBases folder?
Custom connection templates are stored in this folder: C:\Users\<user.name>\AppData\Local\Bentley\Engineering\STAAD.Pro CONNECT Edition\Default\RamConnection
Awesome. Thank you!
