Ram Elements - Foundation Module
More general feature questions than an issue encountered:
1) Would it be possible for ram elements foundation module to account for a shared pier where two columns are in close proximity to each other (such as where a PEMB portal frame is next to a main building column)?
 2) Would it be possible for ram elements foundation module to allow the user to set their reinforcement ratio? There are many situations in which the required pier size is much larger than the applied load and the allowance for 0.5Ag provided in ACI 318-14 10.3.1.2 would like to be utilized.
Thank you,
Parents Reply
  • Yes, perhaps I should have clarified that I am using the integrated module. Is it possible that the feature I am referencing above could be built in at a later date? On large projects with multiple columns that would be designed with a shared pier I would think:
    1) It would be troublesome to model the piers with links to the columns both since that would clutter the model and increase analysis and design time.
    2) The pier would need to be located at the resultant of the forces in the columns which would likely vary based on combined dead, live, snow, etc loads. It could be more accurately approximated if it was modeled at the resultant of controlling load combinations for the columns.
