During design of beam in rcdc,if i put a check of crack width the software will not design and it gives a message written "Cannot find column [StAstTop] but if i dont check for crack width the software works perfectly.Need a help on this problem because this problem does not occur in design of column, only in beams.
can you please check this feature in RCDC 10.00.00.278 version? If still the issue persists please upload the file here.
RCDC Version 23.00.03.63 Crack width check for beam can't performing and below error is appearing. Please check and revert
