In the new STAAD V22 Update 6, a Structure Wizard has been included in the Physical Modeler. Within the wizard there is a Modular Tank template defined in an .XML file. I would like to add additional templates to the Structure Wizard, including a modification of the Modular Tank as well as other structures. Is it possible to do this by creating new .XML files for each? Is there any tool or reference guide of command structure available to make this process easier?
In staad latest version this is preinstalled
Yes. You need to have Select Entitlements to use this.
Please share templates for overhead circular & rectangular water tanks
