Members failing : Not able to enter Fyld Design parameter in IS800 LSD ( STAAD Pro Connect)
A part of my project is to make a PEB Industrial Shed using, built-up sections.
I am just considering the primary frame in design.
Problem :My all members are failing.
As per my understanding, it is because it is not assigning Fyld, in IS800 LSD. I came to know this as I can manually enter it from the code, but not using the design menu.
I tried design using IS800, but I am not able to enter Kx and Ky there.
Kindly help, attaching my file.IS 2.1.STD
Parents Reply Children
