On Ram Elements, my design module takes the cross-sectional area of rod # 6 as 2.0 cm2, when it is actually 2.84 cm2. How do I change it
I see the correct result here. If you do not have v16.03.01 installed, please try updating and see if the same result is reported. Otherwise, please share your model file using our Secure File Upload and post the file name here after it is uploaded.
Answer Verified By: Ing_Abelardo_Uribe
Gracias por la respuesta. Como la estructura es tan simple, marque optimizar y entre al reporte y me da ese resultado. Que las 4#6 son 8,0 cm2. Despues entre al detallamiento y modifique los aceros longitudinales a #7, me regreso de nuevo a #6 cuando voy al reporte cambia el resultado, que las 4#6 son 11.35 cm2
Thanks for the reply. As the structure is so simple, check optimize and enter the report and it gives me that result. That the 4 # 6 is 8.0 cm2. After entering the detailing and modify the longitudinal steels to # 7, I go back to # 6 when I go to the report changes the result, that the 4 # 6 are 11.35 cm2
