Dear Bentley members,
I have tried Plate model in Midas Gen and staad pro, In Midas there was one option called Cutting line diagram for understanding the Plate bending diagram, Similarly is there any tool in Staad pro?. Or any method for understanding plate model in staad
Here is where you can find the option in STAAD.Pro v8i. However please note that Results Along Line has been completely rewritten in STAAD.Pro CONNECT Edition and this new algorithm overcomes the limitations that existed in the older algorithm. We highly recommend that you start using the STAAD.Pro CE and use the new Results Along Line feature. Also STAAD.Pro v8i is not supported anymore and so you should migrate to the STAAD.Pro CE anyway.
Sye sir, Can you explain how to corelate the stress value of plate with values shown in cut line diagram? on both sides there are value. and what is use of flip, move up or move down with an example..
