PDFPDF
Hi all,
I am designing for beam to beam connection with fin plate. I have attached the design reports.
Meanwhile, I have encountered the following error. Is it logical for the formula as in figures below?
I tried to duplicate the connection at my end in RAM Connection version 13.04.01.9. There I am getting different output and there is no minimum value.
Can you please check the connection in the latest version as above. If you still faces the problem please share the .rcnx file for further investigation.
Answer Verified By: Dickson
