I am facing this error "DENSITY NOT PROVIDED. SELFWEIGHT COMMAND IGNORED" and try everything I know and didn't work please help, The file has been attached F23.std
There are many plates which do not have material assigned in your model. First of all, please upgrade to the most recent STAAD.Pro CE version 22.06.00.138. Then open the model, go to Select -> Missing Property -> Missing Elasticity and assign the required material to those plates and members. Save the model and try to analyze it again.
I already try that and didn't work
Which STAAD.Pro version are you using?
22.06.00.138 and yet didn't work
Some syntax in the input files was not in the correct location. I.e. some of the material definitions, member properties and constants have to be moved before the SUPPORTS command in the input file:Also, GROUP DEFINITION needs to be moved before the ELEMENT PROPERTY:Once I have moved the syntax into the appropriate location, I assigned the CONECRETE material to all plates and members where it was missing. Also deleted the UNIT command in the LOAD CASE 2. Now the model should run fine.F23_MOD.std
Answer Verified By: Ibra H
