Hi so I exported my .std file as a .dfx file to import into another design software. When I exported it to dfx the structure is blocked by the node numbers and beam numbers. When the file is imported to another design software the node numbers are beam numbers cannot be removed. I cannot edit the file using Autodesk as I only have the viewer installed. Is there any way to solve this?
So you're importing the dxf file into another structural analysis program, like RISA 3D, Robot Structural Analysis, or SAP2000? That doesn't seem like the best way to transfer data so I want to be sure I've got that straight before I give advice.
