*** ERROR *** ABOVE COMMAND IS NOT RECOGNIZED. LINE IGNORED.
i had proceed the time history analysis by using force...but the error is appear...the force = 10kN is my hydrodynamic forces calculated based on formula/equation..i had assumed the force always constant from 0s to 9s...my loading choose is time load..is it any error?
  • This should not be an error. Can you attach that STAAD.Pro model and TXT file with the loading data? Also, which STAAD.Pro version are you using?
  • https://drive.google.com/drive/folders/169e4FqKqcPwuzFbYCtaRChJrjj80Rl7B?usp=sharing
    this is my std file..both link are the same file....hope you can help to check the hydrodynamic force analysis is correct or not....because this is my first time to use in my academic learning and research during my university time...my version is STAAD.Pro V8i (SELECTseries6)....
  • I was able to run your model fine in the most recent STAAD.Pro version 22.06.00.138 fine. Try to copy the attached files into a new folder and see if you can run the analysis fine.
    2630.Structure1.std
    0.0000  10
    0.5000  10
    1.0000  10
    1.5000  10
    2.0000  10
    2.5000  10
    3.0000  10
    3.5000  10
    4.0000  10
    4.5000  10
    5.0000  10
    5.5000  10
    6.0000  10
    6.5000  10
    7.0000  10
    7.5000  10
    8.0000  10
    8.5000  10
    9.0000  10
  • Okay.. i will try the analysis... and is it my load case is correct follow time history analysis and definitions?
  • Can i ask actually what is the different between ground motion and time load? And what is the areival time?
