RCDC 8.0 unhandled exception when I design the column
Hello this is the problem I encountered in RCDC 8.0 Connect Edition it is an error when I design the column only but all the structural members has no problem, it gives unhandled exception when I click autodesign and when i Click the design calculations.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Item has already been added. Key in dictionary: '1'  Key being added: '1'
   at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
   at ColumnDesignTool.ScColumnWalldMan.QComputationForSlendernessACI()
   at ColumnDesignTool.ColDesignParameters.GetDesignCalcDataR0()
   at ColumnDesignTool.MDIParentmain.DesignCalculationsToolStripMenuItem_Click(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
RCDC
    Assembly Version: 1.0.0.0
    Win32 Version: 09.04.00.128
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/RCDC.exe
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SandDock.DLL
SCMap
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCMap.DLL
RCDCIO
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/RCDCIO.DLL
System.Web
    Win32 Version: 4.8.4330.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Data
    Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Automation
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/Automation.DLL
SCDBDesign
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCDBDesign.DLL
Bentley.Connect.Client.API
    Win32 Version: 10.00.19.31
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/Bentley.Connect.Client.API.DLL
Bentley.Connect.Client.Service.Interface
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/Bentley.Connect.Client.Service.Interface.DLL
System.ServiceModel
    Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Runtime.Serialization
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
SMDiagnostics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.ServiceModel.Internals
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
Microsoft.VisualStudio.Diagnostics.ServiceModelSink
    Win32 Version: 10.0.30319.1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualStudio.Diagnostics.ServiceModelSink/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Diagnostics.ServiceModelSink.dll
Bentley.Connect.Advisor.Api
    Win32 Version: 10.01.00.283
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/Bentley.Connect.Advisor.Api.DLL
Bentley.Connect.Advisor.ApiFactory
    Win32 Version: 10.01.00.130
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ApiFactory.dll
Bentley.Connect.Advisor.Logging
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Logging.DLL
log4net
    Assembly Version: 1.2.15.0
    Win32 Version: 1.2.15.0
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/log4net.DLL
Bentley.Connect.Advisor.OopWrapper
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.OopWrapper.dll
Bentley.Connect.Advisor.Api2
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Api2.DLL
Bentley.Connect.Advisor.ServiceContract
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ServiceContract.DLL
ScIO
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/ScIO.DLL
System.Data.SQLite
    Assembly Version: 1.0.110.0
    Win32 Version: 1.0.110.0
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/System.Data.SQLite.DLL
System.Transactions
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
SCMath
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCMath.DLL
System.EnterpriseServices
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
StyleManager
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/StyleManager.DLL
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
SCModel
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCModel.DLL
ColumnDesignTool
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/ColumnDesignTool.EXE
WaterTankDesignTool
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/WaterTankDesignTool.EXE
PileCapDesignTool
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/PileCapDesignTool.EXE
FootingDesignTool
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/FootingDesignTool.EXE
SlabDesignTool
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SlabDesignTool.EXE
BeamDesignTool
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/BeamDesignTool.EXE
bentley.managed.entliclib
    Win32 Version: 11.00.08.10
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/bentley.managed.entliclib.DLL
Bentley.Licensing.Client.API
    Win32 Version: 11.00.01.11
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicenseService/Bentley.Licensing.Client.API.dll
Bentley.Licensing.ServiceInterface
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicenseService/Bentley.Licensing.ServiceInterface.DLL
Common.Logging
    Assembly Version: 3.3.1.0
    Win32 Version: 3.3.1.0
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicenseService/Common.Logging.DLL
Common.Logging.Core
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicenseService/Common.Logging.Core.DLL
Bentley.Licensing.Common
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicenseService/Bentley.Licensing.Common.DLL
Bentley.Cloud.ThickClient
    Win32 Version: 1.0.0.51
    CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicenseService/Bentley.Cloud.ThickClient.DLL
WW
    Assembly Version: 2.0.6.4
    Win32 Version: 2.0.6.4
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/WW.DLL
BBSElements
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/BBSElements.DLL
WW.Cad
    Assembly Version: 2.0.23.10
    Win32 Version: 2.0.23.10
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/WW.Cad.DLL
System.Security
    Win32 Version: 4.8.4261.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
WW.License
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/WW.License.DLL
ScdMan
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/ScdMan.DLL
SCDwg
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCDwg.DLL
DXFViewer
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/DXFViewer.DLL
LoadComb
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/LoadComb.DLL
ObjectStructures
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/ObjectStructures.DLL
SCControls
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/SCControls.DLL
scisde
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/scisde.DLL
ReportGenerator
    CodeBase: file:///C:/Program%20Files/Bentley/Engineering/RCDC%20CONNECT%20Edition/ReportGenerator.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
