Is there any method or way that RAM concept can control the load balance percentage fixed?
In the File - Strip Wizard mode the program can layout PT to achieve a user specified load balance percentage, but in the full 3D model we only report the balance load percentage based on the user Defined tendons (on the design strips layer). There are some tools to help like the Manual tendon layer - Calc profile tool.
The strip wizard allows the user to specify the minimum balance load percentage for a specific load case, defaulting to self-weight only. When plotting balanced load percentages this is based on the All DL combo by default.
