Can I toggle the units displayed in load case details or when I double click to edit a load case? My work around is changing units at the end of the input file
Go to Geometry -. Input Units:
Hi. I am traying to make that but when I open the input file, I find the same units. How to change the units in input file?. For examble, I worked in Kip - inches but I whanted after change to Pounds - Feet. Please Help me. I will be aware, thanks in advance.
In input file also you will see different unit commands all over the places if you change the input unit frequently. If you want to change unit in existing file steps mentioned in the wiki may be followed.
Changing units for existing input data in STAAD.Pro
