What are the acceptable inputs for IModel.GetGenericTable(string input) in RAM DataAccess for RAM Structural Systems?
I was hoping to be able to have access to more RAM Data through this method.
This interface is associated with custom, user-defined tables and will not get you access to data that is not exposed by other interfaces. You might use such a generic table to collect model data using other interfaces and then use the information in a custom post-processing workflow that you develop.
The GetGenericTable interface will not help retrieve the information that you mention in this forum. Unfortunately, the information that you mention there is not exposed through RAM DataAccess.
Answer Verified By: Norman Noe
Unfortunate, but very well said. Thank you for the feedback! Is this information available anywhere in working local files (ProgramData/Appdata) that can be deserialized, or is it a lost cause?
I think using the DataExtractor (RAM Modeler - Post-Processing - Extract Data) to export that information to Excel as noted by Seth in the previous forum is the best way to get the information.
