Staad pro shows "cannot generate load for command" while assigning floor load for an irregular slab.
Tried to make those inclined beams in a group and then tried to assign a floor load of (-2.5 kN/m2) to that floor. but didn't work then.
The marked portion is where the load needed to be applied. Please give the answer.
Thank you.
Please attach the model.
parassini project.std
this is the work file
There are many members in your model which are not intersecting each other correctly. Select all members, go to Geometry, click on the Intersecting Beams icon and select the option Intersect Selected Beams. This will fix the connectivity issues and the floor load should be generated fine.
Thank you for your answer. But still couldn't assign a load to the inclined slab. It keeps on showing errors. Please tell me why is it happening
Please help me to resolve this issue
Please see the attached model where the floor load has been applied.parassini project_mod.std
Thank you, sir. this has helped me to clear my doubt.
