Iam trying to design my steel roof truss using CHS (Circular hollow section) the difficult iam facing is to design its connection in Staad pro Connect Edition update 5,the connection available are only available for columns and beams.I need your help
Which design code do you want to use for the connection design? Could you attach that model?
TRUSS.txt
The design of Truss connections is currently limited to AISC .360 code only.
Ok thank you for the feedback
I want to use bolt connection,there are some lists of AISC 360 in Staad Pro Connect Edition,which code is capable of designing bolt connection of truss.
1.AISC 360 -16 (ASD)
2. AISC 360 - 16 (LRFD)
3. AISC 360 -10 (ASD)
4.AISC 360 - 10 (LRFD)
5.AISC 360 - 05 (ASD)
Only welded truss connection are available at this point of time.
Answer Verified By: Joseph Lucas Magare
